Question about Philips Magnavox 9P6034C 60" Rear Projection Television
Remote does not work and cannot find one that does.
I have an older tv/vcr. The remote will no longer work and I cannot find one that will work because it is a combinatio tv/vcr. Do you still have one I can purchase or do you know of one that will work.
  • 585 Answers
I actually have some, what is the model#
roety
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Posted on Jul 31, 2009
Model VWM-290 VCR THAT HAS RF-30 CODE
RF codes are generally associated with older VCR's that used to output signals via the TV aerial system. It's when you used to tune the TV to the VCR channel. I think if you press a couple of numbers such as 4 and 9 on the remote it will then say RF-49. In which case if you have an old analogue tuner on your TV you could then tune it to channel 49 and see the VCR picture. Generally it's no longer used for the reason of digital TV, but also due to the fact you could not get a stereo sound with it and the picture wasn't as good as via a scart socket.
Apr 16, 2015 | Televison & Video
I hava psvr71 vcr and a new Sharp Asquos tv and I cannot get the vcr to record. It will play back but not record.
The VCR doesn't have a digital tuner. It has an analogue tuner. So it won't pick up the digital TV transmissions. You need a Freeview box connected to the house aerial system, and then connected to the VCR by a SCART lead. Put the VCR on one of the AV channels so it "sees" the signal from the Freeview box as a predicament for its own tuner.
Some older TVs had a video out function. This no longer applies to new TVs.
Sep 15, 2014 | Proscan New Original PSVR71 Remote Control
How do I program the Toshiba CT-90325 remote to control the Toshiba SD-V280 VCR/DVD player?
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes used for devices too are given, in the order of device brand name list in alphabetical order. Do a search by type in the brand name of your device, at its search box, and press "Enter". Or, pull up older posts.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Jul 23, 2014 | Toshiba Original CT-90325 TV Remote...
I have a EWC19T3 tv/vcr/dvd combo my ex-boyfriend threw the remote and shattered it. I have a philips/magnavox universal remote but I've tried all the codes listed for emerson (which is a lot) and none of...
Unfortunately, the remote you picked up may be incompatible with your current TV. (I found older universal remotes didn't work with my newest set that had a digital tuner. These were remotes that worked with ~20 year old tvs (analog only). Similarly a new remote might not work with an older TV. Then you get stuck with the result you have.)
Remotes.com has a substitute remote that has all of the functions of the original remote: http://www.remotes.com/remotes/servlet/rs?a=Search&o=c&uid=0&m=EWC19T3&uuid=12792355576670
This one will work.
Your TV has Select, volume and channel change buttons on the front of the TV. So a tedious way to deal with the problem is to move to the TV to change channels. The Volume controls are under the DVD tray. Select (toggle TV/VCR, DVD, and external input) is the first one on the left under the VCR cassette slot. The channel up/down is to the right of the Select.
I wish that I could be of more help.
(However, you might try the Philips Remote Code Finder: http://www.urc.philips.com/ and select your country and click on the right arrow. Then find your remote model and see if you can get a single number for your TV. On the newer remotes I looked at, it only returned a code of 0917 for All Emerson devices.)
Jul 14, 2010 | Emerson EWC19T3 19 in. TV/VCR/DVD Combo
IMagnavox TV stuck on VCR mode
Youre gonna need the original replacement remote , heres a link to get your replacement :
http://www.replacementremotes.com/
Dec 01, 2009 | Philips Magnavox 27MS343S 27" TV
INeed a remote for older Admiral tv/VCR combination.
buy a universal remote called all in one it will run any electronics in your home and sells for under fifteen dollars at any walmart. Cheaper some places. I don't know where u are but if u have a Big Lots u can buy from there for about seven dollars
May 03, 2009 | Televison & Video
Up and down arrows on channel or menu selections not working.
All the functions of in putting and selections channel are done by one stage of a tv. take your tv to a w/shop, it wll require change of components,
get a diagram from
www.universal.remote.net/zenith.html
further help will be provided
Dec 06, 2008 | Zenith B25A02Z TV
Admiral tv/vcr, innovage jumbo remote
YOU CAN USE EMERSON CODES FOR YOUR ADMIRAL TV AND TV / VCR COMBOS, MY COMCAST REMOTE ACCEPTED 11911. SOME REMOTES NEED FIVE NUMBERS AND MY ADMIRAL ONLY HAS THREE. SO I USED AN EMERSON CODE AND IT WORKED MOST OF THE BELLS, NOT ALL WHISTLES WORKED BUT I DIDN'T HAVE TO GET UP TO TURN IT ON, CHANGE THE CHANNEL OR THE VOLUME. MY KIDS WON'T DO IT ANY MORE!!
GOOD LUCK!!!!!
Dec 26, 2007 | Televison & Video
Remote code orion tv/vcr # tvcr0950bw
I have an Orion TV/VCR combo with a Philis Universal remote. I had to use the Sansui codes for the combo. My code for my Orion was 632.
Dec 06, 2007 | Orion1934 19" TV
JVC HR-S3901 S-VHS / Switching from TV to VCR no longer works . . .
Ifyou do not see the VCR/TV button switch on the front panel, then its a problem most likly with the firmware in the microprocessor. If you do see the VCR/TV indicator switching in or on the front panel display, most likly a defective RF modulator/switcher or RF antenna pack. You may still be able to get one from like MCM or tritronics or PTS corp can rebuild it for you. I have seen this type of break down many times with VCR's as we used to do hundreds of VCR repairs a day as we did factory service for several companies in the NY/NJ area. Good Luck Please do not forget to rate this thread.
Dec 10, 2006 | JVC HR-S3901 S-VHS VCR
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
15 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
