Home | PC Laptops | ACER Aspire 5720
PC Laptops
Problem for PC Laptops
Generic problem for all PC Laptops
ACER Aspire 5720
By Alek986 on Nov 23, 2007
I have ACER aspire 5720 with Windows VISTA, I like to instal XP on it. Where can I find drivers for XP.
Clarification Request
Posted by huutri on Sep 10, 2008
They are asking for username and password when I try to go in to the acerpanam link.
Same Problem
May 06, 2009
-   i hav installed xp on my laptop, but nt gettin drivers 4 it....4m where can i get the drivers?????-   irinetani
Mar 04, 2009
-   I bought an Acer Aspire 5920 with Windows Vista preinstalled.
I want to install Windows XP Professional SP2 but I can't !!!
I insert the Windows XP CD to install Windows and the Setup program says that "Windows did not find a hard disk" -   htainlinn
Feb 25, 2009
-   I WANT TO REMOVE WINDOWS VISTA AND INSTALL XP
BUT I NEED DRIVERS FOR THE ACER ASPIRE 5720Z
PLEASE HELP-   debric61
Feb 21, 2009
-   i have a acer travelmate 5720 model laptop - windows xp driver i needed -   baski32
Feb 20, 2009
-   hi, I have acer aspire 5720z, and when i downgraded to XPand install all of the drivers the laptop become very hot, I'm not sure where is the problem but when turn back to vista the problem disappear -   Guest
Best Solution
posted on Apr 27, 2008
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
acer 5720g nvidia 8400m gs graphic driver for xp
Solution #2
posted on Nov 25, 2007
Very Helpful)
jakey_too
Rank: Apprentice
Rating: 88%, 20 votes
The XP Drivers are on Acer PanAm website:
http://www.acerpanam.com/flex/acerdrivers/bin/drivers.html?CFID=4394128&CFTOKEN=56207662
If you do a clean XP install from formatted hard drive, a standard XP install disk will not recognize the controller: you also need SATA drivers for F6 install from Intel download site.
Apart from that, all is straightforward: the proof is that I am writing this on an Aspire 5720 running XP! Good Luck.
Comments:
Nov 28, 2007
- Eirikg,
What drivers do not work?
The only problem I had was with the webcam drivers: there are several on the Acer PanAm site but I did not use any of them; I ended up using generic Microsoft driver instead.
You can get the chipset drivers and SATA drivers for F6 Windows XP install from the Intel download site.
Although I did not need to on the Aspire 5720, I also use driver detective from http://www.drivershq.com. You can identify what drivers you have and what you need also source any missing ones..
Good Luck...
Was this helpful?
Yes
No
Solution #3
posted on Apr 03, 2008
Helpful)
MadNad
Rank: Apprentice
Rating: 95%, 10 votes
Hi All,
We are a workshop in Spain & I have had several problems with "Down grading" to XP. There is essentially one problem which causes an issue with the XP installation & that is if the the BIOS has a "Fixed" sata configuration. By that I mean you cannot change it to some sort of IDE or P-ATA (Symantics). Our current problems are with an Acer 5720 & an HP Pavilion DV9700. The Acer solution is exactly as "kraken3000" had mentioned before:
1. On POST (Powerup). enter BIOS by pressing F2
2. Tab along to the second option "Main"
3. Goto last option "SATA mode" & press enter.
4. From the small selection display select "IDE mode"
5. Save & exit the BIOS. This will then set the SATA mode for XP to be recognise.
DONOT set this back to SATA Mode after you install the XP as it will NOT boot. This setting must be kept untill you "Upgrade" (If ever) to Vista. The HP is another story...
Visit the Acer Panam site & download & install the XP drivers & your good to go...
I hope that this was of help...& good luck folks
Was this helpful?
Yes
No
3 people thought this was helpful
Solution #4
posted on Jan 19, 2008
Helpful)
kraken3000
Rank: Apprentice
Rating: 92%, 4 votes
I have the answer
i'm sorry i don't speak english, but I hope that you understand me, to reconocer the hard disk serial ata, only enter to the BIOS, and change the option SHD or something to IDE, then you can intall windows XP without driver if you have a dude this is my mail kraken3000@hotmail.com
Was this helpful?
Yes
No
Solution #5
posted on Aug 06, 2008
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Where can i download the sata driver???
Solution #6
posted on Nov 29, 2007
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Check this pdf to download, it's Aspire 5720 Drivers Vista and XP
http://www.acerpanam.com/synapse/forms/AcerDrivers/Aspire%205720.pdf?CFID=5092948&CFTOKEN=79644376
Solution #7
posted on Mar 28, 2008
Helpful)
Andregeek
Rank: Apprentice
Rating: 86%, 4 votes
install a windows xp sp2 sata integrated cd.
i just intergrated sata on my xp cd and it worked totally fine
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #8
posted on Oct 29, 2008
Somewhat Helpful)
abo sabri
Rank: Apprentice
Rating: 75%, 1 votes
Was this helpful?
Yes
No
Solution #9
posted on Sep 18, 2008
Somewhat Helpful)
ngrito
Rank: Apprentice
6yu6uhanjarnjarjajuaqdgtrbnagnjyza
Was this helpful?
Yes
No
Solution #10
posted on Dec 11, 2007
Somewhat Helpful)
saeid1979d
Rank: Apprentice
not at all
Was this helpful?
Yes
No
Solution #11
posted on Dec 02, 2008
Not Rated)
oDgo
Rank: Apprentice
Rating: 0%, 0 votes
Hi Guys.
Just try this >> ftp://ftp.work.acer-euro.com/notebook/travelmate_5720/driver/
Was this helpful?
Yes
No
Solution #12
posted on Oct 23, 2008
Not Rated)
Adelogo
Rank: Apprentice
Rating: 0%, 0 votes
I have the same problem as posted by Alek986 on november 23, 2007
Was this helpful?
Yes
No
Solution #13
posted on Oct 14, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Hey guys!
Im running 5720z with MS XP PRO SP1. I have problems with the sound, but I think I've downloaded wrong HD audio driver. All other drivers I got by searching on google, with keywords as: 5720z xp drivers. The panam site is a good one. I must warn you guys; u cant have both vista(original OS) and XP on the 5720. Did not work for me. Can only run xp, but I think its because I installed XP on a "fake" partion. If u want both OS' working, you probably need 2 hard drives, one for each operating system.
I ensure you, XP on 5720 is liek heaven. My laptop is now much faster, and xp is more easier than vista.
Good luck :)
Popular Solutions for PC Laptops
Questions and Unsolved Problems for PC Laptops
Answer
I need a fair priced powerful laptop
Answer
Answer
got a laptop from a friend, who had a vodafone dogle, im now trying to use a o2 dongle, but it keeps... (More)
Answer
my IBM laptop been pour out the water from the kayborad I need find some where to repair my laptop... (More)
26 Other Users Have The Same Problem - Continued
Comment by gerel, posted on Feb 20, 2009
Please advise, where I can find Win XP for aspire 5720 notebook.
Comment by Guest, posted on Feb 02, 2009
any one can inform where can i find the drivers of acer aspire 5715z
Comment by almousa85, posted on Jan 02, 2009
Dear alek
where did u find the drivers of acer aspire 5720 ...Windows XP. monitor and wireless drivers.
Comment by Guest, posted on Dec 30, 2008
need windows Xp drivers for Aspire 5720 ICL 50
Comment by uiraglub, posted on Dec 04, 2008
i had vista on my notebook acer aspire 5720 and now i have istalled xp and i can t find the device drivers for xp
Comment by Guest, posted on Sep 07, 2008
I need an assistance of getting a direct solution to securing/downloading Windows Xp compatible drivers and utilities for Acer Aspire 5720z.
Pls help in this regard
Comment by princessade, posted on Sep 01, 2008
Realtek HDA driver
Acer Crystal Eye Webcam driver
Broadcom Netlink Gigabyte Ethernet driver
Intel Pro Wireless 3945ABG driver
Comment by Guest, posted on Jul 25, 2008
installed windows xp
search at google for drivers
Comment by comp1977, posted on Jun 05, 2008
where?
Comment by kyzkiz, posted on Apr 19, 2008
I have acer aspire 5720G with windows Vista and i hate that. Where i can find drivers for windows XP?
Comment by Nikofunboy, posted on Mar 21, 2008
plaese help me
i have ACER aspire 5720 , win vista is on notebook but i need win XP .
whate install win xp on my notebook .
niko_funboy@yahoo.com niko.funboy@hotmail.com
Comment by Guest, posted on Mar 09, 2008
OKay People!!! I Have the Same problem.. BuTTTT I can split the problem into TWO: 1st-SATA drivers needed for Windows XP Setup in the first place - solution to that - making a 1.44 floppy drivers and pressing F6 throughout the installation of xp - Where to find the SATA you ask? in any Acer's support website... (or you can google "acer aspire 5720 Sata drivers) 2nd-finding truly compatable Device drivers after installing xp - solution - now you can use acer panam support website like my freinds wrote earlier... it's working!
Comment by equilibrum, posted on Feb 18, 2008
i whant to install xp ,because i don`t like how vista workes.where do i find drivers for my laptop for xp
Comment by Guest, posted on Dec 20, 2007
Hi All, I've followed the steps exactlly as mentioned in the link and after repairing the Vista system, it was supposed to restart in Vista, it didn't and it kept restarting in XP, so I tried to change the setup of the system to SATA again which made the XP crashes. Beside all the drivers that are mentioned in the other link don't work at all. Please if any body reached to the real solution to this problem just tell us how and we'll follow. Thanks and waiting for a serious fix.
Comment by Guest, posted on Dec 18, 2007
I have ACER aspire 5720 with Windows VISTA, I like to instal XP on it. Where can I find drivers for XP. (free of charge if posible)
Comment by aacos2, posted on Dec 12, 2007
I have the same problem with my aspire 5720, i got all the drivers but when i search for them and point to the right location is sais there are no driversa there.
Do i need Service Pack 2?
Comment by Guest, posted on Dec 11, 2007
does anyone know what the sata driver for xp is called, I don't even know who manufactured the HD (acer, WD, etc..??)
Comment by saeid1979d, posted on Dec 11, 2007
hi i have an Aspire 5720 with windows vista, considering that windows vista is not compatible with virgin internet so i had to change the windows to XP but now i have problem with the drivers as they have been made to work on windows vista not XP.
Comment by elbi, posted on Dec 11, 2007
Yes i have a same problem
Comment by Db04bpv, posted on Dec 04, 2007
I have an Acer Aspire 5720z, i installed Win XP Home Edition, but i didn't find drivers for SATA. When i try to change in AHCI mode in Bios, the screen became blue, and the computer restart. I have the drivers for floppy, but how can i use them without a floppy disk ?
Comment by Eirikg, posted on Nov 27, 2007
I have just installed xp. And i have downloaded the drivers on acer pan-am site. But most of the drivers doesn`t work. where can i find drivers that works?
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For PC Laptops:
Top PC Laptop Experts
Rank: Guru Guru
Solutions: 482
Experience: Experienced a lot in computer troubleshooting. Knowledgeable about cellular phones.
Ask Me
Find more PC Laptop Experts
Top Computer & Laptop Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
