Question about Dyson Vacuums
My dyson keeps switching off after about 3mins and its suppose to be fully charged it onlyy 2years ol
    Master:
  • 742 Answers
Customer service
Posted on Nov 11, 2017
3 Suggested Answers
SOURCE: my dyson handheld charges fully,
I get the same problem, even having bought a brand new battery. :(
Posted on Jan 22, 2015
emissionwiz
  • 81400 Answers
SOURCE: Dyson cordless v6 vacuum keeps shutting off. Fully charged. Max button off.
I would suspect the battery pack is defective.
Posted on Dec 30, 2016
My dyson v8 is fully charged but keeps cutting out I've checked and no blockages can u help
If the warranty is out, throw it away. If you still have warranty coverage, call Dyson.
Jun 11, 2017 | Dyson Vacuums
My Dyson v8 stick vacuum isn't charging.
Hello, this is Ava with Think Crucial.
If your vacuum doesn't turn on, make sure that plug is fully inserted into a fully functional electronic outlet. If it still not turning on after verifying this, it could be that the power switch is malfuntioning. You may need to replace the power switch by opening up the handle of your vacuum. I suggest to refer to your manual on how to replace the power cord or contact Dyson for troubleshooting steps. 1-844-679-1647
You can purchase a wide variety of high quality Dyson replacement parts for your Dyson Vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=dyson
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Apr 25, 2017 | Dyson Vacuums
Dyson does not turn on. It has been charged enough.
You can purchase a wide variety of high quality Dyson replacement parts for your Dyson vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
Ava B.
Jan 04, 2017 | Dyson Vacuums
Does the dyson v6 have to be plugged into an outlet when not in use
Yes, to keep it trickle charged, so it is fully charge for when you want to use it. If you are not using it very often, and you don't mind it running out of power during a vacuuming session 'no'.
Dec 28, 2016 | Dyson Vacuums
I have a stick dyson DC35. It runs out of power after being fully charged. I have cleaned filter and cleaned all parts numerous times, but still have the problem.
The battery may only be capable of partially charging but indicates it is fully charged, something like 100% of 50%. It may be time for replacement.
May 02, 2016 | Dyson DC35 Digital Slim Stick Broom/Hand...
When is the DC16 red light supposed to change to green?
You can see the manual for the DC16 here: (
https://www.dyson.co.uk/medialibrary/Files/Dyson/Support/downloads/UK/floorcare/Manuals/dc16_uk_manual_cb_120710%20pdf.pdf )
Following the troubleshooting manual on page 6, fully charging the battery takes about 3 hours, for a run time of 6 minutes, so I'm not sure where 10 minutes comes from. The battery ships partially charged and was supposed to have been charged 3+ hours before a first use to get a full cleaning span.
It's also noted that you can get red lights if the temperature is out of an optimal range, and if the filter is not seated properly, so these would be things to check as well.
On the general checking list - look at the contacts for the battery and for the charger, make sure nothing is bent or corroded. Corrosion can be generally treated with use of some fine sandpaper or steel wool - be sure to blow the area clear of any steel wool fibers if you go that route. A better electrical contact sometimes will allow charging to get above a threshold voltage that will let the 'I'm charged' light turn green.
Good Luck! :-)
Jul 20, 2014 | Dyson DC16 Root 6 Bagless Handheld...
Dyson DC44 Animal Handheld Vacuum, keeps cutting out
dyson-dc44-animal-handheld-vacuum-keeps-ehecv3x4uj13pgwprhzrjmma-4-1.jpgThe battery falls slightly loose, so you have to fasten it securely to the body of the vacuum. I learned this from another user here on Fixya. He uses electric tape. I used one of those rubber bracelets that kids wear. Worked perfectly!
Mar 10, 2014 | Dyson DC44 Animal Handheld Vacuum Cleaner
My dc 16 rechargeable vacuum won't work
far as i know the dyson dc 16 root 6 vacuum uses a lithium ion battery with a charge of 21.6 volts. it could be that either your battery isnt storing the right amount of power anymore and you may need to replace it. check on the specifications to confirm how much volts the battery is supposed to have. too little volts may be enough for things like lights to switch on, but not enough for the motor to start up.
Oct 27, 2009 | Vacuums
Vacuums Logo
29 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
