SOURCE: I have an fisher and
Hi and welcome to FixYa, I am Kelly Diagnostic Mode To enter diagnostic modes, press and hold the MENU button - then press the UP button for 4 seconds. The PC temperature will be displayed on the LCD. The actual temperature of the PC is shown. Note Temperatures are shown in Degrees Centigrade. PC Sensor Temperature ____ - By pressing the Up button once more, this will indicate the FC sensor temperature. Note: The "min" indicates minus 12°C FC Sensor Temperature - By pressing the Up button once more, this will indicate the Defrost sensor temperature. Defrost Sensor Temperature - By pressing the Up button once more, this will indicate the input/Output Status. Input/Output Status - Press UP one and two more time, both LCDs display 87.5 but should be ignored Spare/ Blanks - Press UP one more time and fault history will be shown. Fault History To exit diagnostic mode press MENU button FAULT CODES: A wrench symbol and LCD fault code will appear automatically if there is a fault in the temperature measuring system, defrost system, fans or low ambient heater. When the PC door is opened an alarm will sound, the number of beeps also indicates the fault code. Pressing any of the control buttons can deactivate these alarms Fault Code 1 Reason: On last power up, the power module failed self test. Primary Action: Replace power module Fault Code 2 Reason: The previous 2 defrosts were aborted after 30 minutes Primary Action: Check defrost element Fault Code 3 Reason: The resistance of all the temperature sensors is outside the normal range (>45K Ohms) Primary Action: Check 6 -way Rast connector at power module Fault Code 4 Reason: The resistance of all the temperature sensors is outside the normal range (
Primary Action: Check 6 -way Rast connector at power module Fault Code 5 Reason: The resistance of the FC sensors is outside the normal range (>45K Ohms) Primary Action: Check sensor connector at power module Fault Code 6 Reason: The resistance of the FC sensors is outside the normal range (
Primary Action: Check sensor connector at power module Fault Code 7 Reason: The resistance of the Defrost sensor is outside the normal range (>45K Ohms) Primary Action: Check sensor connector at power module Fault Code 8 Reason: The resistance of the Defrost sensor is outside the normal range (
Primary Action: Check sensor connector Fault Code 9 Reason: The resistance of the PC sensors is outside the normal range (>45K Ohms) Primary Action: Check sensor connector Fault Code 10 Reason: The resistance of the PC sensors is outside the normal range (
Primary Action: Check sensor connector Fault Code 11 Reason: The current for the LAH, PC &FC Fan is lower than expected Primary Action: Check the 6 way fan/LAH, connector at module. Fault Code 12 Reason: The current for the LAH, PC &FC Fan is higher than expected Primary Action: Check the 6 way fan/LAH, connector at module. Fault Code 13 Reason: LAH is drawing less current than expected. Primary Action: LAH open circuit Fault Code 14 Reason: LAH is drawing higher current than expected. Primary Action: Check wiring connection Fault Code 15 Reason: PC fan is drawing less current than expected. Primary Action: PC fan open circuit Fault Code 16 Reason: PC fan is drawing higher than expected current Primary Action: Check fan wiring or connections Fault Code 17 Reason: FC fan is drawing less current than expected. Primary Action: FC fan open circuit Fault Code 18 Reason: FC fan is drawing higher current than expected. Primary Action: Check FC fan & wiring circuit Thanks for choosing FixYa, Kelly
You should enter the diagnostic mode to determin your fault:
There are also Ice maker faults that are NOT included above. This should get you started and if everything passes above diagnosis the problem is most likely in your ice maker circuit. The reason I did not include ice maker faults is because they do not cause alarms.
SOURCE: Hi, my admiral side by
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong.
If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
SOURCE: I have a Baumatic integrated
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Sounds like the cold control has stuck . Unplug the two wires from the cold control and plug them together. Turn one wire over and plug it into the other. away from the cold control.
The cold control is the knob in the ref that turns it on and off and has numbers on it. (Thermostat)
If it runs then that cold control (Thernostat) is the problem.
If that doesn't work DO THIS:
The relay on the compressor may need replaced
A relay starts the compressor with a higher voltage and then quickly kicks out
Thats what is happening with yours
Its best for a tech to replace The relay but you can do it
Take your model number to your Local Appliance parts store they will have a diagram
showing you how to install the relay. Its called a hard start relay
also try hooking the two wires together on the cold control to route around the cold control.
Be sure the BACK COVER is in place and hasnt been accidently removed.
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
MORE TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS____
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Most overlooked dryer energy saving problem EVER!
http://www.fixya.com/support/r5739846-most_overlooked_dryer_energy_savingr
REF THERMOMETERS TIPS
http://www.fixya.com/support/r10177561-second_biggest_refrigerator_energy
Thank you for using fixya
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
SOURCE: my beko ap930 fridge freezerhas stopped freezing
FREEZER FAN MOTOR MAY NEED REPLACED. THE EASIEST WAY IS TO TAKE OFF THE BACK PANEL IN FREEZER AND REMOVE THE FAN
MOTOR, TAKE IT TO THE NEAREST APPLIANCE PARTS STORE WITH YOUR MODEL NO.
EASY JOB.
need more help go here:
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
SOURCE: The temperature alarm is beeping and the fridge
press and hold "temp alarm"
button for about three second, then when the green light goes out you are all good. it shouldn't beep again.
if the doors have been open for a long time then press "Max Cool" it will quickly drop the fridge and freezer temps to lowest possible setting o quickly cool food down after warming up in the room-temperature air. "Max Cool" automatically turns off after 12 hours, so just leave it overnight and you should be fine.
