SOURCE: LOAD IT
pull out the spring at the end of the gun. turn the staple gun upside down. Lay the staples in the track pointed side up, push in the spring slide so that it locks. You are ready to staple.
SOURCE: Nothing happens when you load paper to staple.
assuming it is plugged into a good power source and turned on (no offense intended, just getting the obvious out of the way - and I've fallen victim to the obvious myself before), look inside where you put the paper - is there a trigger mechanism? Most electric staplers have them (the paper hits the trigger and the stapler fires), and some allow you to set the sensitivity of the trigger. If yours allows you to adjust the sensitivity, try adjusting it. If it's not adjustable, the trigger probably needs to be replaced (under heavy use, they may need to be replaced every year or so).
SOURCE: I have a Swingline Optima Heavy duty manual
You may nave too many staples remove half of them and see it that helps
SOURCE: I just received the Swingline
I can solve it!!!!!!!!! Remove the clear tape at the front of the stapler...the tape you cannot see, and push from the back of the stapler! Please note on the bottom of the box......it reminds you that this stapler does not come with paper or staples!!!
SOURCE: I have recently been given a Powershot 8000
With the staple exit facing toward you (don't squeeze the handle), find the small black square at the bottom (opposite end) from staple exit. Grasp both sides. Pull away from gun (not down). Chamber will open.
Swingline heavy duty staplers provide the power to staple up to 120 pages of 20-lb. paper easily and consistently. The all-metal construction of these staplers makes them an indispensible office tool. However, the way to load staples into a Swingline heavy duty stapler differs from the method for loading most other manual staplers and can cause a little confusion.
Difficulty:Easy
Instructions
