Duo Therm RV roof air conditioning. I can hear it running but after a few minuites it shuts down and there is no air flow.
    President:
  • 2,559 Answers
The unit is going into thermal overload and shutting down,it needs to be cleaned,properly charged,and possible fan replacement.
Thermal overload is a protection feature used to prevent further damage by allowing the unit to shut down when to much heat is detected inside the compressor.
The best thing to do is have a service tech service the unit.
Posted on Jul 29, 2009
Duo Therm 3109228.001
sounds like thermostat issue not communicating with relay modeule
Aug 01, 2014 | Dometic 3109228.001 Duo Therm Comfort...
I HAVE DOMETIC DUO-THERM PENGUIN ROOF AIR CONDITIONING ON RV. THE UNIT WILL RUN WHEN PLUGGED INTO ELECTRICITY BUT WHEN GENERATOR POWERED THE AC UNIT KILLS THE GENERATOR ENGINE. WHAT COULD IT BE?
What size & type generator? On start up the AC unit can draw as much as 17-18 amps in some cases, and if your generator is not designed for a quick draw like that it will die.
Jan 25, 2013 | Dometic Rooftop RV Air Conditioner
Installing rv roof airconditioner heat strip
I see what you see also in the manual. The difference is the Heat Strip package that part is optional and the 600212-001 with the optional heat strips becomes the new 600315-001 I talked to Dometic Duo-Therm and the models are the same but they both are not heat pumps but the new heat strip package comes on when told to go into heat mode when you change the thermostat to heat. The part you purchased will fit both model numbers you listed for your roof top air conditioner. Thanks, Sea Breeze
May 09, 2010 | Heating & Cooling
Duo Therm Penguin model 610115.311 AC unit no-power
Actually you should have fried you converter. What is the voltage reading you get for the air conitioner? supply? One should run off the generator and the other on shore powerIs it set up that way?.
Sep 28, 2009 | Heating & Cooling
Have duo therm
Hi, You are getting low on refrigerant. The A/C cranks up, vaporizes all of the refrigerant available to it and the compressor shuts down. The fan continues to run.
Best regards, --W/D--
Aug 04, 2009 | Dometic Rooftop RV Air Conditioner
Both roof top units on RV cool for awhile the go off
May be low voltage problem or bad connection this may cause controller to shut one or both down. Need to talk to RV dealer for assistance on this system.
Jun 28, 2009 | Dometic Rooftop RV Air Conditioner
Don't panic, but I have a question about my 40 year old duo therm RV roof top AC. I know, it shouldn't be working, but it does. My problem is it will kick on, compressor starts to work and puts out cold...
When you say relay I'm assuming the contactor. Does it shut off again when you let go of the contacts (relay)? Most likely it's low on refrigerant and the low pressure switch is shutting it down.
Feb 26, 2009 | Dometic Rooftop RV Air Conditioner
Heating & Cooling Logo
22 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
