Question about Grilling
Have propane campfire and want to use coleman l6 oz. cannister. Where can I buy an adapter and 5 ft. of hose? It is set up for a large propane tank, like a backyard grill. Need it for car camping and do not want the big tank and the hazard of it in the car.
True value and ace hardware if the dont have in stock they will order parts needed if avalible
Posted on Dec 21, 2011
    Problem Solver:
  • 15 Answers
Try Camping world -
Posted on Aug 25, 2009
Can a 20lb tank be hooked up to a Coleman 2 Burner Stove 5430A
Yes. There are multiple adapters made to fit this application. Your local walmart most likely will have them. http://www.walmart.com/ip/Coleman-5-High-Pressure-Propane-Hose-and-Adapter/19897422
Sep 18, 2013 | Coleman 2 Burner Propane Stove 5430E700
Coleman 5423b701
Try Coleman directly.
The Coleman Company, Inc.
3600 North Hydraulic
Wichita, KS 67219
1-800-835-3278
Sep 01, 2013 | Coleman Camping Stove 2 Burner Propane W/...
I have a small weber gas grill but im sick and tired of using the small propane is there an adapter i can get that connects to the large tanks?
Depending on your make and model, you should be able to obtain an adapter hose that will permit you to use a standard (larger) propane tank.
Try the Coleman website at http://www.coleman.com/coleman/colemancom/detail.asp?product_id=2000005042&categoryid=27400&brand=
These adapters are usually available at camping supplies stores like Dicks Sporting Goods, Cabelas, and even at Walmarts or Target.
Jun 05, 2011 | Vacuums
I love,love,love my baby webber. I bought it when they first came out. I can only use the tall, blue propane bottle. I seen some where that they were using the short, wide, green one. My wire guide...
The easiest solution to this problem is to remove the screw securing the wire tank holder in place, and then just bend the holder a little bit wider so that it will fit the slightly larger 16 oz green tanks found in the camping section of most stores.
You can even buy buy a hose connector adapter for it so that you can hook it up to a large home barbeque type propane tank if you want. See the following consumer reviews of that unit for more details and ideas:
http://www.amazon.com/Weber-Baby-100-Portable-Grill/dp/B0000E6GHI
Thank you and good luck.
May 22, 2011 | Weber Baby Q Grill
Fire code says I cannot use my regular size gas grill with 20 lb tank, so I want to use with 16.4 oz tank. How do I adapt?
Can't different set up. The 16.4 oz is butane. The bigun is propane, 2 different animals. What fire code would prevent you from using one of the new fangled tanks with the safety device witin?
Feb 26, 2010 | Coleman Roadtrip Grill LXE 9949-750
No propane flow to grill using bulk bottle system.
the office that is open on the bottom of the burner sound like a spider has taken home to.. the hole.... This happened to mine. a small pipe cleaner or wire will break it up...try that. also did you feel the top of the tank regulator and see if it has froze. try turning the tank upside down and turn the unit on.... this may also help by forcing the spider debris out.
Jun 05, 2009 | Coleman Roadtrip Grill LXE 9949-750
Cannot conect regulator to small 16.4 oz propane tank
It must have some sort of packing spacer you need to remove from the hose to attach the tank. LOL
Apr 11, 2009 | Coleman Roadtrip Grill LXE 9949-750
How to shut off a coleman 16.4 oz propane cylinder
These cylinders seal themselves, just remove it by unscrewing it. Never store grill with cylinder still attached, then it could leak out leaving you an empty bottle or worst, exploding if near an ignition source.
Sep 19, 2008 | Coleman Campfire Grill
Propane tank
yes, you need to buy an accessory cord that connects your tank to the regulator
Jul 03, 2008 | Coleman Roadtrip Grill LXE 9949-750
Grilling Logo
82 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
