Question about Radio Shack Pro-96 Scanner
My Pro-96 Suddenly Doesn't Pick Up Transmissions
I've had and LOVED my Pro-96 for almost a year, but for no reason I can find, it won't stop at any transmissions of any frequencies. It scans and scans and scans, and it WILL stop at my pre-programmed frequencies but ONLY if I cut the squelch all the way up, but all I hear at that point is the annoying "squelchy" sound. I haven't done anything out of the ordinary (like change type of batteries, etc., and I haven't intentionally locked out any new channels). Any ideas? I am just sick, because none of the Radio Shacks in Chattanooga, TN that I've been to have a clue where to send me for repair.
  • 2 more comments
  • jaytetra Feb 07, 2008
    hi i have been thinking about buying a pro 96 scanner but i live in the uk sheffield what sort off things could i listern to and where would i be best buying one from.Thanks jason dee235.dee235@virgin.net
  • Anonymous Apr 14, 2008
    Same Problem here in Colorado. Won' t trunk and follow channels. Had to return to Radio Shack to fix under warrant - never said how it was fixed. Aprrox 1 1/2 years later - same problem. Re-checked all frequencies and all are correct. Will not stop and follow trunked frequencies. ???????
  • Jumbojet Feb 24, 2009
    I have the same problem. I only get audio white noise with sqelch back. I am going to look inside for broken ant. connection to the main board. At present time scanner does not recieve anything. I have already tried both resetting and initilizing the scanner. Since the Pro-96 was manufactured by GRE, i will contact them if i have no luck. I will post back if i find the answer.
  • Jumbojet Mar 06, 2009
    Hi HarleyCJ7 and Pro 96 People, Back Again. I checked the ant. conection all fine. GRE would not talk to me, for they do not service Radio Shack scanners. Radio Shack service tech says that he thinks the reciever has gone ca-put. Would cost possibly $200 or so to fix. However i'm cheap LOL. I had no power to it for about 1 week. Today i had my scanner on playing with it trying to figure what was going on with this little radio device. After playing with it for about a half hour, BANG i was recieving the local TMR data frequency. I checked VHF and it was recieving that also. I turned it off and back on and you guessed it, Gone again. Played with it again and presto back again. Turning the trunk off and on some how got it working again. Now the display goes out sometimes. Turn it off and back on and All is fine. This happened 2 more times. Its now been about 3 hrs. and it is working fine. Go figure. Harley, i hope this helps you out. I would try no power for a week or so then get it out and play with the Program and trunk buttons to see if it starts recieving again. I know i'm a happy camper right now. Good Luck!!!
On scan mode press (man) for manual then pgm then trunk. screen should read not trunked press mode. if it does say that then press scan, and it should work. but if it doesn't say not trunked then press mode until it does say not trunked, then press scan. should work.
Posted on Feb 07, 2009
Mine was doing the same.... well I could attach it to the base ant. and all was fine on the rubber ant. ... nothing..
I had programed the unit with ARC96 when the trouble started... I switched back to win 96 and all was fine.
Posted on Mar 08, 2009
Is the antenna loose. The wire connecting it to the board inside can break off and no signal will get to the radio. Some times you can move the antenna around and it will make contact, try that with the noaa weather station on.
Posted on Aug 27, 2008
    New Friend:
  • 160 Answers
Your att could be on
Posted on Jul 06, 2008
I have had the same problem occasionally, and I figured it out pretty much by accident. If you inadvertantly hit the ATT button while scanning, it will turn on the attenuator?. This will usually drastically reduce if not stop completely the receiving of signals normally.
Manually go through each frequency looking for the "A" to display on the top line of the display. If it shows up on a channel, hit the ATT key and turn it off.
If one of your data channels had the attenuator turned on, You problably will not receive anything at all. Give it a try.
Posted on Feb 15, 2008
  • 204 Answers
Hi, just a quick thought on your problem. You might have a broken antenna. They come with the rubber duck ant. and sometimes it will break internally. Or if that's the loaded trunktracker the attenuator might have gotten turned on. That's like turning the gain way down.Check that info out in your manual. Page 70 of your manual. Hope this helps,, Mechanic
Posted on Jan 24, 2008
Transmission won t shift out second gear
no year,? and no JEEP MODEL ?
scan it the PCM sets codes for all tranny fails.
scan it, with any scan tool' (96 and newer)
no year, no joy,, older cars are different , they do light blinks.
so no year. cant help,. see my posts asking others that 1000 times.
Jan 09, 2014 | Jeep Cars & Trucks
I have a uniden bearcat scanner and cant pick up my local police dept. I put the frequency in and still dont hear anything. I have a bc145xl 16 channel scanning radio and want to know if its compatible...
If you programmed the correct frequency, you should be getting reception. Check www.RadioReference.com to verify the frequency. Otherwise, you may be too far from the transmitter to receive signals. Try your scanner in other locations, check your antenna, and try receiving the PD on another scanner.
The MARCS - Ohio Multi-Agency Radio Communications system - is a Motorola Type II SmartZone Omnilink Trunking system that utilizes APCO-25 digital transmissions. Your BC145XL is not compatible with trunking or digital systems. In order to follow the MARCS you will need one of the following scanners:
GRE PSR-500, PSR-600
Radio Shack PRO-106, PRO-197, PRO-96, PRO-2096
Uniden BC250D, BC785D, BC296D, BC796D, BCD396T, BCD396T, BCD996T, BCD996XT, or the brand new HomePatrol-1
Bill B.
Listening in since the 60's
Nov 11, 2010 | Radio Communications
Need a manual to program radio freq for a RCA four band veractor tuned scanner, this is not a gps but a radio scanner model # 16S400
Please excuse me if I've already answered your question -- it sounds familiar. The RCA 16S400 is a 70's-vintage crystal based scanner that covers the VHF-Low, VHF-High, and UHF bands using frequency-specific crystals. It is not programmable, but rather requires one crystal for each frequency to be scanned/tuned. It uses Regency-type crystals which can usually be found on eBay at reasonable prices.
Bill B.
Oct 13, 2010 | Radio Shack Pro-96 Scanner
Pro-96 Scanner: My pro 96 scanner says all channels locked and it ...
If there is no frequencies on your scanner it will lock all channels out. if all your frequencies are on one bank and you accidentally hit that bank number and turn it off it will lock out all channels. If that's the case just hit that bank no. back on and they will unlock.
May 17, 2010 | Radio Shack Pro-96 Scanner
I have the pro 96 for about 2 years and I can hear the squelch sound but its not picking up chatter.
Try turning the squelch to minimum, press Scan, or you may have to program it. To program, Press PGM, select the channel you want, press PGM, use the number key and ./DELAY to enter the frequency including the decimal point you want to store, if you make a mistake press CLR, press the ENTER button to store it. You can get your frequency's for your state at www.RadioReference.com ...hope this was helpful..
May 15, 2010 | Radio Shack Pro-96 Scanner
Turn it on, press the manual button,then rotate the squelch knob until you hear silent,press scan and wait to see if you hear transmissions,if not ,you may need to re-program it, to re-program, press manual,enter the channel number,press manual,enter the frequency you want including the decimal point, press E. If you make a mistake,press CLR to erase. You can get the frequency for your state at RadioFreq.com or RadioReferance.com. hope this helps..
Mar 29, 2010 | Radio Shack Pro-96 Scanner
Pro 96 scanner only scans bank 3 and 4. i am sure
While it's scanning, press any keyboard number (0 thru 9) to activate/deactivate scanning on the corresponding bank.
Need the full manual for your scanner? You can download/print it here:
http://support.radioshack.com/support_electronics/doc71/71778.pdf
For a comprehensive database of active frequencies and systems in your are,visit:
BillB
Jan 09, 2010 | Radio Shack Pro-96 Scanner
Pro-96 Scanner Not Receiving Philadelphia Fire Department Radio
Well I would check up on their current frequency. They may have changed frequencies overnight. It does happen. Here is a handy website to check out. Look around and hope it helps you.
http://www.radioreference.com/apps/db/
Mar 03, 2009 | Radio Shack Pro-96 Scanner
Wanted manual realistic 2010scanner
The realistic 2000 series scanners do not have a "VFO" (variable frequency occilator) in the true meaning of the sence. This basicly means that they can only scan the channels or memories that you have programmed.
You can however set a low frequency (like 144 Mhz) and a high frequency (like 145 Mhz) and the scanner will "bounce" between the two, picking up anything in between.
Do you have the operating manual? If not, here is a copy
Turn on your Pro-2010 by rotating [VOLUME] clockwise. (When first turned on, your Pro-2010 may start scanning).
Rotate [SQUELCH] fully counterclockwise. You'll hear a rushing noise from the speaker. Slowly rotate [SQUELCH] clockwise until the noise just stops.
You're now ready to start entering frequencies.
Programming Frequencies
Before programming frequencies, make sure your Pro-2010 is turned on and the SQUELCH is adjusted.
Suppose you want to program Channel 1 to receive 162.55 MHz. Here's how you would do it:
1. Press [MANUAL] and select channel 1. You can do this in two ways:
press [MANUAL] continuously until the Display indicates Channel 1 or
by pressing [1] [MANUAL].
2. Press [PROGRAM] to enter the programming mode.
3. Enter the desired frequency. In this case, press the [1] [6] [2] [.]
[5] [5] keys. Check the display to make sure the frequency it shows
is the one you meant to program. If it is, press the [ENTER] key.
4. To add more frequencies, just press [PROGRAM] to advance to the next
channel and follow the steps above.
5. If you ever want to change the frequency entered for a specific
channel, just enter the new frequency "over" the old frequency using
steps 1, 2, and 3.
Make a mistake while entering the frequency? Just press [CLEAR], enter the correct frequency and press [ENTER]. If you're entering a new frequency in place of an old one, the old frequency won't be "erased" when you press [CLEAR]. It will remain stored on that channel until you correctly enter a
new frequency and press [ENTER].
You'll hear a "peep" sound as you press the various keys. This lets you know the key has been properly "entered" into your Pro-2010.
Using the Scanning Function
Your Pro-2010 will automatically scan all the channels you've programmed and stop whenever it finds a signal. To scan channels, just press the [SCAN] key.
To stop scanning, just press [MANUAL] and you can select specific channels
you want to listen to.
IMPORTANT! Your Pro-2010 won't scan unless SQUELCH is set to the point where no sound is heard if a signal isn't being received.
Delay Function
When your Pro-2010 is scanning, it will stop whenever it finds a signal on a channel. As soon as the signal ends, the scanning function will resume. Most communications heard will be two-way. To make sure you don't miss any replies, press [DELAY]. This will cause your Pro-2010 to stay on a channel for two seconds after the end of a transmission, giving you time to hear any reply. To release the Delay function, just press [DELAY] again. The Delay indicator will show on the display when the Delay function is used.
Lockout Function
You may want your Pro-2010 to "skip over" certain frequencies while it's scanning (such as continuously transmitted weather broadcasts). To "lock out" such channels, follow these steps:
1. Press [MANUAL] to stop scanning. Continue to press [MANUAL] to
advance to the channel you want to lock out.
2. When you reach the channel, press [LOCK OUT]. The display will show
[o] to indicate this channel will be skipped over during scanning.
3. To release the lockout, press [MANUAL] to stop scanning. Advance to
the channel that is locked out and press [LOCK OUT] once again. [o]
will disappear from the display.
If you use the lockout function on all channels, scanning will be impossible - you'll only be able to change channels using [MANUAL].
Speed Selection
Your Pro-2010 will normally scan channels at a rate of four channels per second. If you press [SPEED], channels will be scanned at a rate of nine per second. Press [SPEED] again to return to a rate of four channels per second.
Priority Function
You might want to scan other channels yet not miss a call on a channel of particular interest to you (police, fire, ambulance, etc.). The Priority function will let you scan other channels - but if a call is received on the Priority channel, your Pro-2010 will automatically switch to the
Priority channel!
1. Only Channel 1 can be used as Priority Channel: Key in the desired
Priority frequency into Channel 1.
2. Priority function works only when the unit is in Scan or Manual mode.
3. Press [PRIORITY] to start Priority function. A [P] will appear on the
display.
4. Press [MANUAL] or [SCAN] to listen to other channels. Your Pro-2020
will check the Priority channel and switch to it if a signal is
received on it.
5. To cancel Priority function, press [PRIORITY] again. the [P] will
SEARCHING WITH YOUR PRO-2010
One great feature of your Pro-2010 is its ability to "search" for frequencies being used. This means you can hear all the action on the airwaves in your area! To use this great feature, just follow these steps:
1. Press [PROGRAM] key.
2. Press [LIMIT] key. Enter the lower limit of frequency range to be
searched (such as 45.00 MHz). Press [ENTER].
3. Press [LIMIT] key again. Enter the upper limit of frequency range to
be searched (such as 46.00 MHz). Press [ENTER].
4. Press either [up arrow] or [down arrow] to start Search. [Down arrow]
will start search from the highest frequency and go down. [Up arrow]
will start from the lowest frequency and go up.
5. You can control the speed of the search by using the [SPEED] key to
accelerate or to slow down the search.
6. Search will stop when a frequency is found with a signal. To restart search, press [up arrow] or [down arrow]. In Program Mode, search range will be displayed each time [LIMIT] is pressed. It is impossible to change the lower frequency only: to change lower frequency you must change higher frequency first. The higher frequency can be changed any time.
Storing Frequencies
If you want to enter some of the frequencies found during search, do this:
1. Press [MONITOR] when your Pro-2010 finds a frequency you want to store.
2. Use [MANUAL] key to select a channel to enter the frequency your Pro-
2010 found. The display will show the frequency currently stored on
the channel, but don't worry - the old frequency will be erased when
you start to enter the new one.
3. Press [PROGRAM].
4. Press [MONITOR] again. The new frequency found during the search will
be displayed.
5. Press [ENTER] to put the new frequency into the channel in place of
the old frequency.
6. Press either [up arrow] or [down arrow] to resume the search. To
return to manual or program operation, press [MANUAL] or [PROGRAM].
To resume the search from one of the limit frequencies, press [LIMIT]
and then [up arrow] or [down arrow].
Error Indications
Sometimes when you try to enter a frequency for a channel or as a search range limit, you may find an ------ on the display. This means the frequency is in error and you won't be able to enter it into your Pro-2010. Such frequency errors usually mean you've entered a frequency outside the ranges your Pro-2010 operates on (such as 225.00 MHz) or you've put the decimal point in the wrong place (14.682 MHz instead of 146.82 MHz). Check carefully to find your mistake and then press [CLEAR]. You can now enter the correct frequency.
Hope this helps,
M3ODQ
Feb 01, 2009 | Radio Communications
Pro 96 Rebanding Issue
http://www.radioreference.com/forums/showthread.php?t=100208&highlight=custom+tables
You need to program custom tables into the Pro-96. Visit the link above.
ChLO ChHI Step Offset Base
440 559 25.000 440 851.025000
000 719 25.000 0 851.012500
720 759 25.000 0 848.000000
815 831 25.000 0 846.625000
958 958 25.000 958 868.975000
961 1022 25.000 0 843.400000
Mar 15, 2008 | Radio Shack Pro-96 Scanner
Radio Shack Pro-96 Scanner Logo
635 people viewed this question
Top Radio Shack Radio Communications Experts
John
John
Greg Cann
Greg Cann
Jason
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
