Question about Brother MFC-5840CN All-In-One InkJet Printer
Machine error 46 - Brother MFC-5840CN All-In-One InkJet Printer
  • kaleibar Jul 29, 2009
    It is a Brother MFC 5840cn
  • rakesh1905 May 11, 2010
    Please tell us the make and model of the device.
    President:
  • 2,306 Answers
46 says the waste ink box is full, you can reset it, but it could leak all over. Best to have a shop replace it and reset the counter.
Posted on Jul 29, 2009
Error 46
Errol 46, that's reset,
Jan 28, 2014 | Brother MFC 490cw Color Inkjet...
Unable to clean 46. this error display in lcd of brother dcp585cw printer. how to solve me this problem.
Machine Error 46 - Purged Ink Box Full MFC620CN/420CN/410CN/210C and FAX2440C
The machine counts all purge (cleaning) operations in order to prevent the internal ink absorber box from overflowing with purged ink. An "initial purge", for example, advances the purge counter by 187 + 420 = 607. When the purge counter approaches 6400, an internal "Machine Error 46" is generated. Further purge operations are prohibited, and therefore the printer becomes unuseable.
When an internal Machine Error 46 is generated, the user will see an "Unable to Clean" external message and will be unable to use the printer. The "Unable to Clean" external message can relate to many different internal error codes however.
The user can establish the internal Machine Error Code as follows: pull the mains cable out of the machine (power off), hold down the Menu/Set key, re-insert the mains cable into the machine (power on). The internal Machine Error Code will be displayed.
If there is a Machine Error 46, it is necessary to dismantle the printer, replace the ink absorber box (or possibly break the ink absorber box open and clean its absorbent sponges under a tap), re-assemble the printer and reset the purge counter to zero.
Resetting purge counter MFC620CN/420CN/410CN/210C and FAX2440C
1) Enter machine maintenance mode (on MFC210C all four photo/copy/fax/scan lights flash in maintenance mode). Care is needed in maintenance mode, otherwise critical settings may be inadvertently corrupted.
FAX models with numerical keypads: Press the Menu/Set, *, 2, 8, 6 and 4 keys within two seconds. (if you fail to complete the correct key sequence within two seconds, press the Stop key to try again).
Other (non-FAX) models: Press the Menu/Set and Black Start keys. Next press the "up arrow" key four times to enter the maintenance mode).
2) Press the 8 then 0 keys in the initial stage of the maintenance mode to call up the machine's log information list (function code 80).
3) Press the Black Start key several times to scroll through the log information list to reach the purge counter. The purge counter is the 25th item in the list.
4) Press the 2, 7, 8, and 3 keys in this order to reset the purge count to zero.
5) Press the Stop/Exit key to return to the initial stage of the maintenance mode.
6) Press the 9 key twice to return to the standby state.
Jun 26, 2011 | Brother DCP585cw AllInOne InkJet Printer
Error 46 what is it
Here is the answer to your MFC code 46
Nov 24, 2010 | Brother MFC-5840CN All-In-One InkJet...
DCP-110c is showing machine error 46. I have followed instructions as per cene765 solution #1 withput success. I get as far as 'maintenance 80 display. Pressed 'mono start' many times but still displays...
Many thanks - I fixed the error 46 by following the helful solution provided below.
mydcp110c
Rank: Apprentice
Rating: 86%, 8 votes
Hello!
Here is the "Unable to Clean" (code 46) solution:
The machine counts all purge (cleaning) operations in order to prevent the internal ink absorber box from overflowing with purged ink. An “initial purge”, for example, advances the purge counter by 187 + 420 = 607. When the purge counter approaches 6400, an internal "Machine Error 46" is generated. Further purge operations are prohibited, and therefore the printer becomes unuseable.
When an internal Machine Error 46 is generated, the user will see an “Unable to Clean” external message and will be unable to use the printer. The “Unable to Clean” external message can relate to many different internal error codes however.
Solution no. 1. (DCP-110C):
The proper reset code sequence to reset DCP printers without numeric keypad should be as follows:
1. press buttons Set, Menu, Mono Start one by one, followed by up arrow key four times.this should all be done as short a time as possible, around 3 seconds.
2. enter maintenance mode 80 by pressing the up/down arrow key and set key to select numbers 8 and 0
3. press up arrow key several times to get to the Purge item
4. enter 2, 7, 8 and 3 using arrow/set keys to reset the counter
5. press Stop/Exit key to go to root of maintenance mode
6. enter 9,9 to exit maintenance mode
Dec 11, 2009 | Brother DCP-110C All-In-One InkJet Printer
DCP-330C: Can`t do anything while displaying Error 46
The error 46 means the waste ink tank is full, reset will only give you an ink mess when it overflows. The method you are using is for a different model machine, and won't get you to service mode on your machine.
Aug 21, 2009 | Brother DCP-330C All-In-One InkJet Printer
Machine error 46
Here is the answer to the Machine Error 46 (have just fixed my own MFC210C):
Machine Error 46 – Purged Ink Box Full MFC620CN/420CN/410CN/210C and FAX2440C
Other (non-FAX) models: Press the Menu/Set and Black Start keys. Next press the “up arrow” key four times to enter the maintenance mode).
Carry on printing !!
thanks.
Jul 08, 2009 | Brother MFC 210C All-In-One InkJet Printer
Error 46 in brother mfc-440cn
Machine Error 46 ("Unable to Clean") indicates that the wasteink is full. Basicly it gives you two options - have it replaced (a semi-complicated performance which requires buying a spare part and change it yourself) or have it sent to service. If you do not have any warranty on the machine, the more suitable would probably be to just replace the machine instead, since it's relatively cheap compared to both service costs and having the wasteink replaced, but you instead get a full new warranty on your new machine.
Unfortunately, there's nothing you yourself can do to remove this error, without actually changing an item inside the machine.
Jun 04, 2009 | Brother MultiFunction Center MFC-440CN...
Error-46
Machine error 46 ("Unable to Clean") indicates the wasteink "sponge" as full, which disables the machine's ability to clean. To fix this, you could get the needed part from a Brother parts dealer and enter the servicemode to reset the counters. However, the more reasonable thing to do would be to just change to another machine. You could also have the machine sent to service, but that most likely would not be worth the trouble. The error is pretty common on old Brother inkjets, so it'll come back eventually even if you replace the part. Newer machines should not have this problem.
Jun 03, 2009 | Brother MFC 420CN All-In-One InkJet...
Error 46 and says unable to clean. can u help me plz
According to the manual, the unable to clean error means a mechanical problem or a foreign object in the machine: Open the scanner cover and remove
any foreign obstacles inside the
machine. If the error message
continues, disconnect the machine
from the power source for several
minutes then reconnect it.
http://welcome.solutions.brother.com/BSC/public/files/dlf/doc002010/BH3eDCPWLAN_UkEngUsr.pdf
Apr 24, 2009 | Brother DCP-340CW All-In-One InkJet...
Brother MFC-5840CN All-In-One InkJet Printer Logo
150 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
