Question about Kodak ESP 5 Printer
Have error message stating printerhead missinh or installedincorrectly or has come loose I took printhead reinserted it but still got error m
    President:
  • 2,777 Answers
If you have reinstalled the print head then you will need to power down the unit, unplug it from the wall / power strip for a good two minutes and re-power it back up. This should force the machine to do a software reboot and hopefully reinitialize the printhead. If it does not the machine will need actual repairs as the printhead sensor could have failed. If this is an HP printer call them at 800-474-6836, if it's another brand please let me know and I can get you the info.
Thanks
Tim
Posted on Jul 29, 2009
  • Tim Grayson
    Tim Grayson Oct 11, 2010
    Please if possible come back to the question here and rate it 4 thumbs. It looks like the answer helped you, but for some reason it doesn't rate it 4 thumbs unless you come back a second time and specify 4 out of 4 thumbs. I hope you will do this for me. Thanks Tim
Lexmark c782 ps printer has printerhead error..108.10
hi
If this is the firsttime the error has occurred, try turning the printer off. Let it sit turned off for atleast 20 seconds before powering it back on. If powering the printer offand back on clears the error, continue using the printer but watchit to see if any printhead errors return. If your printer continues todisplay a Printhead Error message, make sure it is plugged straight tothe wall and not through a surge device or power strip. Power strips anduninterrupted power supplies can cause a low amperage problem in your printer.This can trigger a printhead error even if the printer has worked on this surgedevice for months.
If theprinter continues to post a 930 Printhead Error, it thinks thewrong printhead unit is installed. If the printer was recentlyserviced, make sure the correct parts were used. This is especially true if theparts replaced were either the printhead unit or the printer's engine/systemboard. It is in one of these two parts that the printer is detecting theproblem. Note: If you are the personrepairing such a printer, please be aware that parts from different,though similar, printer models may not be compatible with this printer.Also make sure to check the laser cable going from the printer's engine boardto the printhead unit, as it reads that signal. If the printer was notrecently serviced before this error occurred and powering the printer off andon does not help, the printhead unit and possibly the laser cable or theengine/system board to this printer may need to be replaced.
If the printer continues topost a 931 Printhead Error, it thinks there is an error in the signalgoing to the laser or the Hsync part of the printhead assembly. If the printer continues topost a 932 Printhead Error, it thinks there is an Hsync error occurringin the printhead assembly. If the printer continues topost a 933 Printhead Error, it thinks there is a failure in either theHsync signal or with the mirror motor unit of the printhead. If the printer continues topost a 934 Printhead Error, it thinks there is a "lock"failure with the mirror motor assembly within the printhead assembly. If the printer continues topost a 935 Printhead Error, it thinks the mirror motor unit within theprinthead unit cannot reach its operating speed.
If powering the printer offand on does not clear any of these errors and it is alreadyconnected directly to the wall, your printer may require service. Itcould have a defective printhead unit or there might be a problem with theengine board or one of the printhead cables. Note:If you are the person repairing such a printer, check all of the cablesgoing from the printer's engine board to the printhead unit for any damage.Also check the continuity across these cables.
May 31, 2011 | Lexmark Office Equipment & Supplies
The printer just says printerhead error. And prints fuzzy.
You probably have a faulty cartridge, try changing your cartridges and see if the error message clears. The printhead is on your cartridge.
Jun 07, 2010 | Lexmark X6170 All-In-One InkJet Printer
I get an error message that printerhead is bad and it is new.
A common problem with newly installed printheads, (especially if refurbed), is small particles of dust in the printhead nozzel. If you can, take the head out and examine it carefully under excellent lighting to determine if there might be some blockage.
Apr 10, 2010 | Kodak ESP 5 Printer
"PrinterHeads" problem reported. So I replaced with brand new ones. Same Message. Call HP....the have me restart to make sure. Same Message. Then HP says it's junk...no fix. True?
Unfortunately it is true. What happens if you get that error on one printhead and your replace the printhead and get the same error message... its the firmware in the printer that is bad. At that point if the printer is still under warranty the unit would be replaced along with the printheads. If not then unfortunately you would be looking at getting a new printer
Apr 06, 2010 | HP Officejet Pro L7580 All-In-One InkJet...
PrinterHeads, replaced, but to no avail
did you remove the strip from the printhead before installation
Printhead system error code 3807 Can't get printer up and running. How do i fix it?
For that problem kindly try doing the ff:
* Re-seat the inks both color and black then try printing
* Re-seat the Printhead of the printer then print again
* Try cleaning the printhead then print a demo page
* if problem still persist call 1800 421 6699 and the technical rep will replace the printhead
Hope this will help
Thanks
Byron
Oct 28, 2009 | Kodak ESP 5 Printer
Canon smartbase MP360 "put in cartridge" does this means buy a new in this case printerhead. The printer was printing fine before this error message came up and printing stopped. Amazing another clean...
Print heads cans wear out. Put in cartridge sound more like a low ink level. Check ink levels and reseat the ink cartridges. Still no? I'd suggest having the print nozzles checked by a repair center or Canon.
Oct 05, 2009 | Canon SmartBase MP360 All-In-One InkJet...
Print Qued--No Print--Cartridge Error Problem--?Prinerheads?
It sounds like you need a new printhead, with that error the printhead is defective. The printhead is BC21E around $40.00
Jun 25, 2009 | Canon BJC 2100 InkJet Printer
Printerhead problems, error codes and only black prints
Need a new printhead. Call Kodak, they know this problem exists.
Jan 19, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Service printhead error 108
Error Code(s) Printhead Color
106, 111, 115, 171, 172 Cyan
107, 112, 116, 173, 174 Magenta
108, 113, 117, 175, 176 Yellow
109, 110, 114, 169, 170 Black
Power off the printer, take the Magenta cartridge out, take a lint and dust-free cloth or tissue and clean the hysinc mirror and the printerhead lens. I just did it and it took me three minutes to clean with toilet paper rolled up like a cigarette.
My printer is back on line. The hysinc mirror and printerhead lens is in the printer not on the magenta cartridge. Reinstall the print cartridge and power on. This has happened to me before with a different color.
here is the Lexmark c750 support link:
http://support.lexmark.com
I hope this helps. - This is from Joey V on fixyourownprinter dot com
Oct 13, 2008 | Lexmark C752 Printer
Kodak ESP 5 Printer Logo
178 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
