Question about Car Audio & Video
How do i turn the telephone celular mute off on my ripspeed dv 710 dvd player?
  • 11,896 Answers
Here is a link to the manual you can copy and paste it in your address bar.
https://www.2instructions.com
This manual does have the instructons.
Posted on Jul 29, 2009
Hi don't have a vid i have a ripspeed dv720 it will play CDs but not DVDs it keeps coneing up bad disc any ideas
ripspeed are prone to problems, just a cheap equivelent for an in car dvd, most likely the laser is goosed
Feb 05, 2013 | Car Audio & Video
I need a ripspeed dvd 733b manual
You may download a copy of the manual here.
Dec 15, 2012 | Televison & Video
I have a ripspeed DVD 720 when I wired it in the power button just flashed red for a bit and that's it it won't turn on or do anything?
Sounds like the power supply in the dvd player has failed. It works just well enough to turn on the led infront but as soon as you go to do anything it shuts off. This is common in cheaper dvd players. Unless you can troubleshoot electronics. Or know someone that can. Your best bet is to unplug the unit and disassemly and retrieve your dvd.
Oct 06, 2012 | Televison & Video
Hi just tried fitting my ripspeed dvd player power comes on for about 10 secs then says bye bye and goes off can any one help??????
Check the fuse on the red wire hasn't come loose.
Check the fuse on the yellow wire isn't blown.
Check both are connected simulataneously.
Common fault!
Feb 04, 2010 | Car Audio & Video
I need help wiring a sub to a ripspeed dvd-730 cd player.because it has to aux-in wires but 1 sub out wire.
the phono out is the feed to the sub, if your amp has high input socket then run feed from normal speaker feed from head unit, or pop into halfords and ask the ripspeed specialist
Dec 22, 2009 | Car Audio & Video
Instruction manual and installation manual for ripspeed dv725
fitted the dvd player but no sound could u help
Jun 07, 2009 | Car Audio & Video
Ripspeed in car dvd player
I had a similar problem with mine I have just had a technical fault with mine and the only solution i could find was through halfords. If its under warranty they send it off to their supplier AEL to solve. If its no longer under warranty like mine, they send it off at an initial £60 cost which could escalate if the problem is larger.
Feb 12, 2009 | Kenwood DV-605 Multi-disc DVD Player
Ripspeed dv-725 problem when trying to play dvd it says attention, do not use this function!
Your Player doesn't support DVD/CDs that are burnt on High Speed DVD/CD Recorders. To resolve this, you should either burn DVD/CDs at 4x(DVD) & 24x(CD) or go for a newer, higher end DVD Player.
Jun 25, 2008 | Televison & Video
I have a ripspeed dv920i in car dvd player but it has just turned off and wont come on again i carnt find any one to repair
I had the same problem, HALFORDS sent the unit away to have the firmware re-flashed and now it works perfectly again..... These units were re-called apparently due to problems with the software.
HALFORDS staff may be able to advise you about where the unit can be repaired.
Jun 20, 2008 | Car Audio & Video
VRX755VD "triggered audio mute for cellular telephones"
Well, it sounds like you need a new output IC, which is what produces sound to the speakers.
Aug 05, 2007 | Clarion VRX755VD Car DVD Player
Car Audio & Video Logo
476 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
