SOURCE: 94 S-10 Chev Brake problem
This is an easy fix un plug the abs sensor from spindle abs light will come on but the brakes will work only abs will not
SOURCE: I HAVE A 95 F250
You need to check wheel cylinders, the only way that the brake peddle will go to the floor like that is if there is a lose of fluid pressure somewhere .
SOURCE: brake peddle goes all the way to the floor. brake
first make sure there are no brake fluid leaks, sometimes the steel lines get rotted and start leaking. to test the booster with the engine off pump brake pedal about 10 - 12 times on the last pump hold the brake pedal down and start the car if the booster is good the pedal will drop alittle.
SOURCE: put in a new master
have you replaced the front and rear brake pads (for older vehicles, rear wheels use brake shoes instead of brake pads). if yes, check your calipers. completely remove it from your tire and have it cleaned.
if the problem still persists, then its time to replace your hydrovac
