Question about Gigabyte GA-945GCMX-S2 Motherboard
4 long beeps. what is the error? - Gigabyte GA-945GCMX-S2 Motherboard
  • Gigabyte Master
  • 4,806 Answers
Four long beeps indicates a RAM (memory) problem.
Take out the system memory, clean the brass pins and the RAM slots with a clean, dry, soft paintbrush then reseat the memory.
If it still won't boot up the RAM may need to be replaced.
Regards.
Posted on Jul 29, 2009
LETS REPLACE THE RAM(MEMORY)......OR CHECK YOUR RAM BY INSERTING TO ANY OTHER COMPATIBLE MOTHERBOARD TO CHECK EITHER YOUR RAM IS WORKING OR NOT....HOPE IT WILL HELP YOU.
Posted on Sep 16, 2009
3 log beeps on power on
Gigabyte doesn't list 3 long beeps as an error code, so I'm not sure if you're actually getting 3 short beeps or maybe 1 long and 2 short or... But, for reference, Gigabyte's error code list is as follows (depending on whether you have an AWARD BIOS or an AMI):
(AWARD BIOS)
1 short beep: System normal
2 short beep: CMOS Error
1 long beep and 1 short beep: Memory error
1 long beep and 2 short beep: Graphic card error
1 long beep and 3 short beep: AGP error
1 long beep and 9 short beep: Memory Error
Continuous long beep: Memory not correctly installed
Continuous short beep: Power supply unit failed
(AMI BIOS)
1 short beep: Memory Error
2 short beep: Memory parity check error.
3 short beep: Basic memory 64K address check error
4 short beep: Real Time Clock malfunction .
5 short beep: CPU error
6 short beep: Keyboard error
7 short beep: CPU interruption error
8 short beep: Graphic card error
9 short beep: Memory error
10 short beep: CMOS error
11 short beep: CPU cache memory malfunction
It might not be a lot of help, but it's somewhere to start... and at least this way you'll know what to be listening for.
Nov 30, 2013 | Gigabyte Computers & Internet
Tip
Tipical Computer/Laptop Post & Beep Error Codes
Error Code: Faulty Component:
_____________________________________________________________
1 short beep None (Normal Boot)
2 short beeps ( POST error)
Non-stop beep ( Power supply or system board)
1 long beep and 1 short beep ( System board)
1 long beep and 2 short beeps ( Video card)
1 long beep and 3 short beeps ( Memory)
3 long beeps ( Keyboard)
Non-stop short beeps ( Power supply or system board,a key on the
keyboard might also be stuck)
None ( Power supply,system board,or system
case built-in speaker)
______________________________________________________________
Visual POST Error Codes:
Error # Range: Component with Error:
100-199 System Board
200-299 System Memory (RAM)
300-399 Keyboard
600-699 Floppy Drive or Floppy Controller
700-799 Math Co-processor
900-999 Parallel Port (LPT1)
1000-1099 Parallel Port (LPT2)
1100-1199 Serial Port (COM1)
1200-1299 Serial Port (COM2)
on Oct 01, 2010 | Computers & Internet
Tip
Computer error beep codes
No Beeps
Short, No power, Bad CPU/MB, Loose Peripherals
One Beep
Everything is normal and Computer POSTed fine
Two Beeps
POST/CMOS Error
One Long Beep, One Short Beep
Motherboard Problem
One Long Beep, Two Short Beeps
Video Problem
One Long Beep, Three Short Beeps
Video Problem
Three Long Beeps
Keyboard Error
Repeated Long Beeps
Memory Error
Continuous Hi-Lo Beeps
CPU Overheating
you can now simply analyze if what is the problem of your computer...
on Feb 13, 2010 | Computers & Internet
What are the elitegroup Computer system Beep error codes
No Beeps Short, No power, Bad CPU/MB, Loose Peripherals One Beep Everything is normal and Computer POSTed fine Two Beeps POST/CMOS Error One Long Beep, One Short Beep Motherboard Problem One Long Beep, Two Short Beeps Video Problem One Long Beep, Three Short Beeps Video Problem Three Long Beeps Keyboard Error Repeated Long Beeps Memory Error Continuous Hi-Lo Beeps CPU Overheating
Jul 05, 2011 | EliteGroup Via P4M266A (P4VMM2 V7.3)...
Green light flashes, will not print. Checked all
Hi can gave you the truble codes
  • Light Orange - 2 beeps: Remove any paper jammed
  • Light Orange - 3 beeps: Remove any paper jammed
  • Light Orange - 4 beeps: Add Ink
  • Light Orange - 5 beeps: Re-install cartridge or replace it
  • Light Orange - 6 beeps: Re-install cartridge or replace it
  • Light Orange - 7 beeps: Re-install cartridge or replace it
  • Light Orange - 8 beeps: Waste is almost full
  • Flash 1 x Orange - 10 beeps (error code 6100): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 2 x Orange - 10 beeps (error code 6300): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 3 x Orange - 10 beeps (error code 6800): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 4 x Orange - 10 beeps (error code 5100): Make sure nothing is blocking the cartridge movement, if not requires service.
  • Flash 5 x Orange - 10 beeps (error code 5400): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 6 x Orange - 10 beeps (error code 5B00): Waste full (make a reset)
  • Flash 7 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 8 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 9 x Orange - 10 beeps (error code 5600): Replace the BJ Cartridge(Printhead) or reinstall it
  • Feb 01, 2010 | Canon BJC 4400 InkJet Printer
    I am getting three short beeps while booting
    The beep codes below may help you identify the possible computer problems. However,
    they are only for reference purposes. The situations might differ from case to case.
    gAMI BIOS Beep Codes
    *Computer gives 1 short beep when system boots successfully.
    *Except for beep code 8, these codes are always fatal.
    1 beep Refresh failure
    2 beeps Parity error
    3 beeps Base 64K memory failure
    4 beeps Timer not operational
    5 beeps Processor error
    6 beeps 8042 - gate A20 failure
    7 beeps Processor exception interrupt error
    8 beeps Display memory read/write failure
    9 beeps ROM checksum error
    10 beeps CMOS shutdown register read/write error
    11 beeps Cache memory bad
    g AWARD BIOS Beep Codes
    1 short: System boots successfully
    2 short: CMOS setting error
    1 long 1 short: DRAM or M/B error
    1 long 2 short: Monitor or display card error
    1 long 3 short: Keyboard error
    1 long 9 short: BIOS ROM error
    Continuous long beeps: DRAM error
    Continuous short beeps: Power error
    Nov 03, 2009 | Gigabyte GA-7VKML Motherboard
    Kenmore elite beeps all the time
    1 Beep/E10--Error: Water doesn't enter Cause: Water supply problem, Check kinks and faucets
    1 Beep/E10--Error: Water leaks Cause: Water connections loose,household drain clog,oversudsing. Correct problems.
    1 Beep/E10--Error: Dispenser drawer is open Cause: Washer will not operate if drawer is open.
    2 Beeps/E20--Error: Water dosen't drain. Cause: Drain is kinked or household clog. Correct.
    3 Beeps/E30--Error: Drum overfilled. Cause: Inlet valve,pressure switch or control board failure.Select drain/spin to remove water. Restart.
    4 Beeps/E40--Error: Door is open. Cause: Washer will not operate if door is open. Close door.
    5 Beeps/E50--Error: Motor is overheated. Cause: Wait 30 minutes to cool down. Restart.
    7 Beeps/E70--Error: Cold water doesn't enter. Cause: Hoses crossed,faucet problem.
    15 Beeps/EF0--Error: Oversudsing. Cause: Too much detergent,or improper detergent for machine.
    15 Beeps/EF0--Error: Hot water doesn't enter. Cause: Hoses crossed,faucet problem.
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
    Oct 05, 2009 | Kenmore Elite 45986 Front Load Washer
    Turn it on it beeps cdc
    You really aren't giving much info, so here are some beep - codes, also make sure nothing came loose on the motherboard or other components ( do this ONLY if you know how ) Safety first.
    BIOS Beep Sound core list
    AWARD BIOS
    1 short(Beep) System booting is normally.
    2 short(Beep) CMOS setting error
    1 long - 1 short(Beep) DRAM ERROR
    1 long - 2 short(Beep) Display card or monitor connected error
    1 long - 3 short(Beep) Keyboard Error
    1 long - 9 short(Beep) ROM Error
    Long(Beep) continuous DRAM hasn't inset correctly.
    Short(Beep) continuous POWER supply has problem.
    AMI BIOS
    1 short(Beep) DRAM Flash Error
    2 short(Beep) DRAM ECC Check Error
    3 short(Beep) DRAM Detect Fail
    5 short(Beep) CPU Error
    6 short(Beep) Keyboard Error
    8 short(Beep) Display card memory Error
    1 long - 3 short(Beep) DRAM Damage
    1 long - 8 short(Beep) Display card or monitor connected error
    Jul 16, 2009 | E-Machines T6520 PC Desktop
    At POST I get 2 short beeps
    it depends on the bios chip maker Here's some other beep codes:
    for Award and Phoenix BIOS:
    1 short beep: Normal
    2 short beeps: CMOS error
    1 long and 1 short beep: DRAM error
    1 long and 2 short beeps: Video card error
    1 long and 3 short beeps: Keyboard error
    1 long and 9 short beeps: ROM error
    Long continuous beeps: DRAM not installed correctly
    Short continuous beeps: Bad power supply
    AMI BIOS:
    1 short beep: DRAM flash error
    2 short beeps: DRAM ECC check error
    3 short beeps: DRAM detect error
    5 short beeps: CPU error
    6 short beeps: Keyboard error
    8 short beeps: Video card error
    1 long and 3 short beeps: Bad DRAM
    1 long and 8 short beeps: Video card error
    Invoking Beep Codes
    If the computer is actually functioning and the computer beeps continuously, then there is a problem with a voltage on the power supply being incorrect or the CPU overheating. IMMEDIATELY go into the BIOS and check CPU temperature, fan speed and voltages
    BIOS Beep Codes
    Annoying isn't it? You have built your computer you switch it on and then nothing happens except a few beeps from the PC speaker. Frustration sets in as you try to figure out what is wrong with it. If you didn't already know the computer has already told you the problem. It can't speak of course but it can direct you to the problem. Its all in the beeps. The BIOS can recognise when the problem occurs and sends a signal out to send a certain amount of beeps through the speaker. These beeps then tell you the location of the problem.
    Unfortunately not all the BIOS' use the same codes as each other. Two of the main BIOS manufactures AMI and Award (now Phoenix) have different codes for there errors.
    AMI BIOS
    # of Beeps Error Description
    1 Refresh Failure The memory refresh Circuitry is faulty
    2 Parity Error Parity error in the Base (1st 64K) of memory
    3 64K Base Memory Error Memory error in the base memory (1st 64K)
    4 Timer Not Operational Timer 1 is not functioning (also caused by error in base memory)
    5 Processor Error CPU error
    6 8042 Gate A20 Failure Unable to switch to protected mode
    7 Processor Exception Interrupt error The CPU on the CPU card generated an interrupt error
    8 Display Memory Read/Write Error Video adapter is missing, incorrectly seated or has faulty memory
    9 ROM checksum error The ROM checksum does not match that of the BIOS
    10 Coms Shutdown Register Read/Write The shutdown register for coms RAM has failed
    11 Cache Memory Bad The cache memory test has failed. Cache memory will be disabled. *** DO NOT enable it ***
    With the first 3 beep codes, its well worth re-seating the memory just to make sure that it's in correctly. 8 Beeps is probably the most common in my experience. Can be caused by a badly seated Graphics card. If you have re-seated it then check with another Graphics card in the board.
    Always check for loose components before sending the board back as this is the main cause of errors on the POST.
    Award BIOS
    Award states that they now only use one beep from there BIOS. This beep is one long beep and then two short beeps. This indicates a graphics card problem. Any other beeps should be treated as a RAM problem first and then the board sent in to be inspected.
    The reason that the Award BIOS only uses the beep code for display problems is that it tries to display the error on-screen if at all possible. If the BIOS cannot initiate the display adapter then this causes the BIOS to make the beep code for a display error, which must be corrected before any other errors can be determined. Memory Test fails and hard disk failures etc will all be displayed on screen
    IBM BIOS
    The IBM BIOS works with Short and Long beeps as well as the Award BIOS. However the IBM one does still have codes to work from.
    Beep Code Error
    1 Short Beep Normal POST, System booted OK
    2 Short Beeps POST Error - Code on Display
    No Beep Power supply or Motherboard error
    Continuous Beep Power supply or Motherboard error
    Repeating short beeps Power supply or Motherboard error
    1 short, 1 long beep System board error
    1 long, 2 short beeps Display adapter error (MDA/CGA)
    1 long, 3 short beeps Display adapter error (EGA/VGA)
    3 long beeps 3270 keyboard card
    Phoenix BIOS
    The Phoenix BIOS works on a slightly more complicated manor than the others. It does display an error code for you and produce a series of beeps. This BIOS produces its beeps according to the hexadecimal code the error produces. The Phoenix BIOS has many different codes for its possible errors and so many different beep codes. Rather than list the entire section here, I have provided a link to the official PDF file containing the codes and how they are derived.
    Phoenix BIOS Post Codes
    System board errors should be looked at by a specialist, Again always try to re-seat components to ensure they are in correctly. If necessary take all components out except for the RAM CPU and graphics card, then try the system. Re-seating components is the number one fix for getting past the POST screen. One badly seated components can cause the entire system not to function. so pick out your bios and follow the steps above to diagnose .hope this helps
    Jan 05, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
    Kenmore front load washer just beeps doesn't start error code says "lol"
    Jan 04, 2009 | Washing Machines
    Gigabyte GA-945GCMX-S2 Motherboard Logo
    1,390 people viewed this question
    Top Gigabyte Computers & Internet Experts
    David
    David
    Tony
    Matthew Spark
    Matthew Spark
    Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
