Question about Dyson Vacuums
My dyson V6 hand stick keeps pulsating and even after pushing the button in the centre of stick doesn't continually vacuum
  • 97 Answers
SOURCE: dyson - can't push the vacuum
try to see if the carpet setting is to carpet. i know this machine says that its a life time belt,but i would check this just in case. best way to tell if it's working is to lay the machine on its belly with the brushes pointing up and turn on the machine to see if the brushes are turning. (be careful not to put your face directly in front, just in case something is lodged in the brush and flies out )
Posted on Jul 29, 2009
TEVA Guru
  • 65 Answers
SOURCE: my dyson wont stay on
you have a defective switch, they are fairly easy to replace but i would call and sheck you probably still have it under warranty and can get it done for free
Hope this helps
Posted on Sep 15, 2009
Dysonteam
  • 167 Answers
SOURCE: My Dyson vacuum brush does not rotate even though the
Hi its Darran at Dyson.
Please contact our Helpline on 1866MYDYSON as it sounds as though we may need to arrange for the machine to be repaired. One of our advisors will be able to run through some checks over the phone with you so please ensure you have your machine with you when calling.
We look forward to hearing from you.
Kind regards
Darran
Dyson Customer Service
Posted on Apr 19, 2010
  • 10 Answers
SOURCE: I have a Dyson vacuum. The vacuum won't stay
My vacuum had this exact same problem, but was out of warranty because it was remanufactured. Thankfully, it's a very quick, five-minute fix.
  1. UNPLUG The Vacuum!
  2. Remove the cannister.
  3. Extend the handle and remove it.
  4. Remove the two torx (T-15) screws behind the power button, where the handle normally stows.
  5. There are four tabs holding the front plate containing the power button on; use your screwdriver to release them.
  6. Gently pull the front plate off.
  7. The switch on the right is the power button. Remove it, try clicking it a few times; if it sticks, great! Replace it and reassemble, otherwise you'll need to replace it.
Posted on Jul 28, 2010
askdyson
  • 2572 Answers
Official advice and support for Dyson technology
    Verified Fixya Pro
    SOURCE: My Dyson will not vacuum
    Sorry to hear you're having difficulties using your DC24 on this particular rug. You may find the cleaner's powerful suction causes certain lightweight rugs to seal closely with the soleplate, requiring a little more effort to push.
    Reassuringly, it sounds as if your cleaner is performing correctly, but if you have any further concerns about this issue, it's probably best if you get in touch with us directly. You can call us free on 08002980298 (UK), or 1866MYDYSON (US). One of our experts will be happy to provide the assistance you need.
    Kind regards,
    Jack
    Dyson Online Customer Support
    Posted on Aug 17, 2011
    Have 1 year old hand held v6 motorhead. When pressing the trigger to start. The unit surges on and off repeatedly on a 1 second pulse. How do this get corrected
    Hello, this is Ava with Think Crucial.
    There are a number of reasons why your Dyson cleaner is pulsating off and on. First, it can be due to a battery of the cleaner. Make sure that the power cable is properly plug to the power and seated properly from the unit while charging. If you find that the battery isn't charging at all, you may need to replace the battery. Second is to check the MAX button of your cleaner. If the button lights up and flashes when your Dyson keeps on pulsating, press and hold the power button and depress the MAX button to turn off the function. You may need to do it for a few times to get the hang of it. Third is to check for any blockages or clogs in the attachments. Look down through the tube and check to see if there are clogs on the sweeper end or if the roller is tangled up in fibers. Clean the roller brush are if it it's necessary. You may need to empty the dust bin of your unit as debris can build up in hard to reach places. Lastly, cleaning the filters may fix the pulsating of your cleaner. Remove the filter and rinse it with cold water and air dry it for 12 hours. Don't use detergent when washing your filters. If the pulsating doesn't go with the given quick fix, I suggest to contact Dyson for further assistance on this.
    You can purchase a wide variety of high quality Dyson replacement parts for your Dyson vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
    https://www.thinkcrucial.com/search?type=product&q=dyson
    I hope this was helpful.
    Ava B.
    Think Crucial Customer Care
    http://www.thinkcrucial.com/
    Feb 04, 2017 | Dyson V6 Motor Head Cordless Vacuum
    I have a dyson V6 Mot?rhead model Ju4-us-GBR7075 My machine when I push the power button the machine stops and goes
    Ava B.
    Jan 21, 2017 | Dyson V6 Motor Head Cordless Vacuum
    My dyson v6 animal surges when I push the button, the roller goes around then stops after about 4 seconds.PX6-us-HEA2023A, I put my manual away some where safe, I'm sure ill find it. Dec 2016
    Ava B.
    Jan 04, 2017 | Dyson V6 Animal Bagless Cordless Stick Vac
    My Dyson v6 motorhead vacuuem shuts off intermitently. How do I fix this
    There are a number of reasons why your Dyson cleaner shuts off intermittently. First, it maybe due to a battery of the cleaner. Make sure that the power cable is properly plug to the power and seated properly from the unit while charging. If you find that the battery isn't charging at all, you may need to replace the battery. Second is to check the MAX button of your cleaner. If the button lights up and flashes when your Dyson keeps on pulsating, press and hold the power button and depress the MAX button to turn off the function. You may need to do it for a few times to get the hang of it. Third is to check for any blockages or clogs in the attachments. Look down through the tube and check to see if there are clogs on the sweeper end or if the roller is tangled up in fibers. Clean the roller brush are if it it's necessary. You may need to empty the dust bin of your unit as debris can build up in hard to reach places. Lastly, cleaning the filters may fix the pulsating of your cleaner. Remove the filter and rinse it with cold water and air dry it for 12 hours. Don't use detergent when washing your filters. If the pulsating doesn't go with the given quick fix, I suggest to contact Dyson for further assistance on this.
    https://www.thinkcrucial.com/search?type=product&q=dyson+v6
    Ava B.
    Dec 17, 2016 | Dyson V6 Motorhead Bagless Cordless Stick...
    My Dyson V6 absolute is pulsating when I pull the trigger. I have cleaned the canister and checked for obstructions. I also cleaned the top filter.
    There are a number of reasons why your Dyson cleaner is pulsating off and on. First, it maybe due to a battery of the unit. Make sure that the power cable is properly plug to the power and seated properly from the unit while charging. If you find that the battery isn't charging at all, you may need to replace the battery. Second is to check the MAX button of your cleaner. If the button lights up and flashes when your Dyson keeps on pulsating, press and hold the power button and depress the MAX button to turn off the function. You may need to do it for a few times to get the hang of it. Third is to check for any blockages or clogs in the attachments. Look down through the tube and check to see if there are clogs on the sweeper end or if the roller is tangled up in fibers. Clean the roller brush are if it it's necessary. You may need to empty the dust bin of your unit as debris can build up in hard to reach places. Lastly, cleaning the filters may fix the pulsating of your cleaner. Remove the filter and rinse it with cold water and air dry it for 12 hours. Don't use detergent when washing your filters. If the pulsating doesn't go with the given quick fix, I suggest to contact Dyson for further assistance on this.
    Ava B.
    Nov 28, 2016 | Dyson V6 Absolute Bagless Cordless Hand...
    I have a Dyson V6 Slim about a year old. It's stopping and starting - not continuous power. I have cleaned the brush the canister and the filter and it's still not working right. Help!!!!
    Ava B.
    Nov 28, 2016 | Dyson Vacuums
    Dyson V6 animal powerhead starts and stops does not run continuously
    There are a number of reasons why your Dyson cleaner is pulsating off and on. First, it maybe due to a battery of the cleaner. Make sure that the power cable is properly plug to the power and seated properly from the unit while charging. If you find that the battery isn't charging at all, you may need to replace the battery. Second is to check the MAX button of your cleaner. If the button lights up and flashes when your Dyson keeps on pulsating, press and hold the power button and depress the MAX button to turn off the function. You may need to do it for a few times to get the hang of it. Third is to check for any blockages or clogs in the attachments. Look down through the tube and check to see if there are clogs on the sweeper end or if the roller is tangled up in fibers. Clean the roller brush are if it it's necessary. You may need to empty the dust bin of your unit as debris can build up in hard to reach places. Lastly, cleaning the filters may fix the pulsating of your cleaner. Remove the filter and rinse it with cold water and air dry it for 12 hours. Don't use detergent when washing your filters. If the pulsating doesn't go with the given quick fix, I suggest to contact Dyson for further assistance on this.
    Ava B.
    Nov 24, 2016 | Dyson V6 Animal Bagless Cordless Stick Vac
    My Dyson v6 animal is pulsating but has been cleaned and been on charge All night
    Ava B.
    Nov 20, 2016 | Dyson V6 Absolute Bagless Cordless Hand...
    Dyson v6 surges on and off
    There are a number of things you need to do that may solve the issue you're having with your vacuum. First, make sure that your battery is charging and working. Second, check the MAX button. If the MAX button lights up and flashes when your Dyson cordless vacuum keeps pulsating on and off, hold the power button and depress the MAX button to turn off that function. You may have to try a few times to get the hang of it. And lastly, look for any blockages in attachments because the pulsating is caused by a lack of airflow as the motor is protecting itself by pulsating and then ultimately cutting out.
    You can check this video tutorial which will teach you on how you may fix it:
    Ava B.
    Sep 18, 2016 | Dyson V6 Motorhead Bagless Cordless Stick...
    Vacuums Logo
    711 people viewed this question
    Top Dyson Vacuums Experts
    AskDyson
    AskDyson
    Manchester Vacs
    Manchester Vacs
    Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
