Question about Trenton Computers & Internet
How to fit the liner - Trenton Computers & Internet
  • 433 Answers
Please be more specific.
Posted on Aug 06, 2009
How do I go about fitting a headliner to a mk2 ford consul
Start with the first, front supporting wire / rod & feed it through the lining hoops & roof mounts, then work your way back along the roof doing the same for each rod. This rods fully support the liner & do most of the work.
When all the rods are fitted, start loosening any trim where required, push the liner under & re-seat the trim. Use a blunt tool to lift the edge of any window seals & run it slowly along the seal, inserting the edge of the liner as you go
Dec 10, 2014 | Ford Cars & Trucks
Missing stoneware liner for Rival Model 3960
I have a Tricity TSC09 6 litre Slow Cooker and I just love it . I smashed the lid and was so gutted I tried for hours online to find a replacement lid with no luck. I went shopping and bought a very cheap 6 to 7 Quart or 6 to 6.5 litre Slow cooker / Crock pot of the same shape the removable pot and lid fit. I bought a cookworks, signature, 24 euro 6.5 litre oval dog standard slow cooker and now I also have a removable pot replacement as well just in case I smash that too. Try buying a very cheap one of the same size and shape even a pot and lid a little bigger than mine still fit .
Nov 21, 2013 | Rival Crock Pots & Slow Cookers
Damaged plastic liner of wheel well rubs on tire when driving over bumps
Even if you popped the dent out, the liner may not fit back on tightly. They are usually held by plastic clips or plastic pins or even plastic screws that easily get distorted, or the hole they are held with gets enlarged from tearing. You could keep the liner up with a couple of machine screws drilled into strategic places....or, you could just remove the liner-it's not a safety issue-it just helps keep mud and dirt from building up in the wheel wells and fender corners. To remove it, first take the wheel off. Then you can see how it is held on Pull it off and throw it away.
If you pop the dent out and fender looks pretty good, and the liner appears it can be re-used with just a little help, all the better.
It;s up to you.
Nov 29, 2012 | Cars & Trucks
Can I paint over the blotched oven floor after the liner melted
Unfortunately there is no simple way to fix this, The original coating is a vitreous ceramic baked on enamel which cannot be repaired easily. There are some companies who sell kits that claim to be able to patch the oven liner but are not very successful. You will either have to put up with it or you can contact your local agent for your oven a price a replacement liner which won't be cheap and is a pain to fit.
Mar 02, 2012 | Cars & Trucks
Wire gets up to the nozzle and jams up then tangles in feed wheels in machine
Try removeing the tip before running wire threw liner. If this doesn't work, remove the defuser, run wire out . Replace the defuser, making sure the liner fits inside the defuser Replace tip. leave enough wire out so defuser & tip can be reassembled. Once you get to the tip you will find iff it is the proper size. If this does not fix the problem, remove the liner. Check to see if it has any kinks If so replace. When replacing the liner make sure not to cut to short. Put liner in gun, attach to machine.Make sure you have enough liner sticking out to make proper contact with the inside of your defuser Trim liner to fit. You should make contact with defuser just before defuser is fully tightened. This is where you eletrical power comes from. replace tip.
Jan 05, 2011 | Welding Tools
Need to replace the rear turn signal lamp, but can't find where to access it. How do I remove the light cover to replace lamp?
You'll need to remove the liner for the trunk to get to this lamp, which is mounted in a quarter-twist lamp socket which fits into the lens housing. The pieces of the trunk liner fit together one over the other... so look around for the hold-down nut on the side you need to service, then the liner pieces come out one over the other.
Nov 24, 2009 | 1996 Mercury Mystique
Parts for sale
booyahbaby.com has gorgeous stroller liners which fit many different stroller brands. I have a 20 year old Emmaljunga stroller & their liner fit my stroller beautifully.
Apr 10, 2008 | Silver Cross Durham Stroller
Replacemnet Liner for Crock Pot.. I want yours
We have a Elite 8 qt. crock pot minus the lid. Maybe between the two of us we can get a working crock pot. We would love to find a lid to fit it, but if not, will be willing to help with the liner.
Mar 10, 2008 | Rival 38651-C 6-Quart
Rival Crock Pot LIner replacement
I have a round, forest green stoneware liner for a Rival crock pot. The liner has no divider. The liner has no chips or cracks. Sorry but I cannot remember to which model number this stoneware liner fit; but I can tell you that the Rival crock pot I had was either a 5 to 6 quart and it fit a plastic lid.
Feb 10, 2008 | Rival 3145 4.5-Quart
Computers & Internet Logo
26 people viewed this question
Top Trenton Computers & Internet Experts
David Payne
David Payne
Are you a Trenton Computer and Internet Expert? Answer questions, earn points and help others
