Question about Dell Latitude D600 Notebook
Have exteranal usb card -
For some reason when I power off and transport laptop next time I power up the usb card is not recognized....? receive error that not firmly in .... ? ...
seems I have to almost force the usb card into the expansion slot and try several times before computer recognizes it is inserted.. then PC with external drives works fine? ...
Any suggestions as to why is is occurring or what might need to be repaired?
  • 88 Answers
Sounds like the daughter card may be partially disconnected from the main motherboard. The usb ports on this model are on a seprate daughter card, and connect using a small socket to the bottom of the main motherboard. If you can pull it all apart you will be able to easily re-seat this card. Another option is the daughter card is going bad, or the usb ports and or drivers are bad, but it sounds like the card is not properly seated.
Posted on Nov 24, 2007
  • Grant Cameron
    Grant Cameron Nov 24, 2007
    oops- if this is a pcmcia card- it may be a similar problem, but either a pin is bent on the pcmcia module, or the card, and or pcmcia module are not properly seated. have a look in the slot and see if there are any bent pins, obvious signs of damage, or any foreign objects in there.
Classic USB Drive 64GB not recognized so no format possible
Click the Start button, type power plan in the Search box, then click Choose a power plan.
Next to your currently selected plan, click Change Plan Settings.
Click Change advanced power settings.
Click the box to expand USB Settings, then expand USB selective suspend settings.
Click Plugged in, then click the drop down menu and select disabled.
If you're using a laptop, click Battery, then click the drop down menu and select disabled.
Click Apply, then click OK.
Dec 30, 2013 | Electronics - Others
I need the usb cable for my smartparts digital frame model sp92
hello, u can use any miniusb cable its not a special cable, so if u got an exteran hdd, or exteran card reader u can use that usb cable
best regards
Sep 22, 2011 | Computers & Internet
Sandisk is not being recognized on my computer
SOLUTION 1 - Verify if minimum system requirement is met.
SanDisk card readers support Windows Vista, Windows XP SP2 and Windows 2000 SP4.
For MAC users, see
Troubleshooting USB device on MAC
SOLUTION 2 - Verify the reader's status under Device Manager.
STEP 1 - Connect the reader to the PC
NOTE: It is recommended that you plug your card reader to the back USB port on your PC to ensure that there is enough power from the USB port for the card reader to be detected properly.
STEP 2 - Check under Device Manager
1. Right-click My Computer.
2. Select Manage.
3. On the left pane, click Device Manager.
NOTE: The card reader will appear in two places: Disk Drives and Universal Serial Bus controls as USB Mass Storage. If there is a yellow exclamation point (!) or question mark (?) next to the device, try to refresh the drivers.
STEP 3 - Refresh the drivers
1. Right-click the entry with the error mark, select Uninstall.
2. On the top menu, click Action, and then click Scan for hardware changes.
STEP 4 - Verify if the reader is detected
1. Double-click My Computer.
2. Look for the card reader under Devices with removable storage.
SOLUTION 3 - Try other USB ports.
A yellow exclamation point (!) under Device Manager usually means that the device is not receiving enough power. If the reader is not receiving ample amount of power from the USB port, it may not function properly.
SOLUTION 4 - Change the drive letters
NOTE: The SDDR-89 reader should show 4 drive letters under My Computer.
Mar 01, 2010 | SanDisk Sansa m250 MP3 Player
USB device not recognized
Please see the following blog article, as it describes the use of a card reader as a much easier, faster, and less error prone way to download your photos. In fact there are several important reasons discussed in the article for using a card reader vice downloading from the camera. USB Card readers are also very inexpensive these day, with cost virtually not an issue:
Jun 21, 2009 | Canon PowerShot A75 Digital Camera
Don't stay on
You might have a bad optical drive. One way to test this is to get an external usb drive, enter setup (bios) upon start up, and change the first boot device to usb device\exteranal drive, then use the exteranal drive. If it works, then you know you have a bad drive.
Mar 23, 2009 | HP Pavilion dv5000t Notebook
Does not recognize
Did you try the disk on a different computer to make sure the disk is functioning?
And if using a laptop, make sure that power is not an issue, an external power supply or 2 USB ports are always required.
Also check:
Maybe one of those troubleshooting suggestions can help you.
Mar 16, 2009 | Western Digital External USB 2.0 80 GB...
I have hp photosmart 1315 printer but the lead i have got does not attach to the laptop, any suggestions? also when i plug my sony memory card into the side it says card access error so i cant even print...
I assume you mean that the connectors of the cable you are using aren't fitting either into the the laptop. I went to and looked up the printer's specifications. It seems like a USB 1.1 (but not a USB 2.0) cable should work. Here's the reference:
Product Specifications
Since you say the cable doesn't attach to your laptop, make sure the USB connector is correct side up before trying to insert it (I apologize if this seems too obvious, but I've spent plenty of time wondering why a USB cable wouldn't fit into this port or that only to realize that I was holding the connector upside down).
As far as the memory card error, there are a number of different causes, mostly based on the card manufacturer. You say it's a Sony card, so that narrows it down some. I found a web page that addresses general memory card error issues:
Resolving a Card Access Error
I'm going to post links to the several other web pages I found that are related to card access errors, just to make sure you have as much information as I can provide:
Card Access Error when using Lexar CompactFlash
Compact Flash Card Not Recognized by Printer
Card Not Recognized Error Displays on Control Panel
Memory Stick Memory Card Error
Most of these don't have to do with your Sony card, but it couldn't hurt to go over them if the suggestions in the initial link don't work out. Sorry to bombard you with so much information, but you never know what piece of data might hold the key to resolving this issue.
Good luck and post back your results.
Oct 15, 2008 | Office Equipment & Supplies
Microsoft Wireless Notebook Optical Mouse Model 1023
Had the same problem. There are 2 reset/ connect buttons: 1 on the mouse, and 1 on the usb device. Press the button on the usb device, and it should start right up. Good luck.
Aug 19, 2008 | Microsoft Wireless Notebook Optical Mouse...
When loading new Map Update i get the following error: "an error occured while querying your garmin gps for information. Please ensure its softwre is current and retry setup" This is a new...
I had the exact same problem updating my GPSMAP496, despite several tries. I then found the details below on the Garmin web site in the support area in a topic titled "How do I use the update DVD with my Street Pilot 2620". After following these steps the update ran perfectly the next time through, so it looks as though the problem is with Windows turning off the internal USB root hub part way through to save power. FYI, I was running on Windows 2003 Server as I couldn't contact the Garmin server from my Xp workstation for some reason, but these steps still worked even though it says Xp only.
Steps 1-12 are for computers with Windows XP only:
  1. Please right click on the "My Computer" icon on the desktop
  2. Left click on "Properties"
  3. Click on the tab that reads "Hardware"
  4. Click on the "Device Manager"
  5. Scroll to the bottom of the list and click on the (+) sign next to "Universal Serial Bus Controllers"
  6. One or more lines will read "USB Root Hub", right click on the first one
  7. Left click on "Properties"
  8. Click on "Power Management"
  9. Make sure there is no checkmark next to "Allow the computer to turn off this device to save power"
  10. Click "OK" to save the change and close the PROPERTIES window
  11. Complete steps 6-10 for all the USB ROOT HUBS
  12. Close all windows and return to the computer Desktop.
  13. Right click on the screen and select "Properties"
  14. Click on the tab labeled "Screen Savers"
  15. Click on the button labeled "Advanced" or "Power"
  16. Under "Power Schemes", make sure all settings are set to "Never"
Apr 06, 2008 | Garmin zumo 550 GPS Receiver
My laptop does not recognize usb flash drives, while my desktop does. I have an HP Pavilion running windows XP. Are there any drivers to install so these flash drives/mp3 players/camerasmight be...
Some USB flash disks need to draw too much power for use on particular laptops,  as Laptops tend to have USB ports which only have a low current draw,
the only way around this is to buy a "Powered" USB Hub (IE a USB hub with it's own plugtop power supply).
My Portable HDD is exactly the same way, and doesn't work on some laptops for this very reason.
Oct 29, 2007 | Electronics - Others
Dell Latitude D600 Notebook Logo
59 people viewed this question
Alun Cox
