You might try cleaning the contacts with some fine 400 grit sandpaper or other contact cleaner. I have a 2 year old 680, and I cut a piece of this sandpaper to the same size as the sim card. I pushed it into the slot, and ran it in and out for half a minute. I also sanded the contacts on the sim. Not too much, mind you, but it cured my problem. Good luck...
I would strongly suggest not pushing sand paper into the SIM card slot. The circuits inside are (as with any small device) very delicate. If you so much as scratch a board trace or get fine bits of sand inside, you can end the phone's life very quickly. There is a sliding SIM tray for the card on this phone that blocks the internal contacts and should not be removed.
Clean the SIM card contacts with isopropyl alcohol on a soft cloth or q-tip. Also, make sure the card is seated correctly in the SIM tray (contacts facing down). If the card is clean and seated fully in the SIM tray and you still cannot get the card to read, then you have 2 final options. 1) have your cellular provider issue you a new SIM card and try that. 2) there is a hardware 'read' issue with the device (which has happened before for users).
You can also search our Palm forums for solutions at: Palmzone(dot)net.
I have a Palm Treo 680 phone that has windows installed on it, however I need to have windows 6.0...
(More)
I have a Palm Treo 680 phone that has windows installed on it, however I need to have windows 6.0 for my business. Can the updated version be downloaded or do I need to purchase another phone
Palm Treo 680, Light does not work, the light in the keyboards works and I can see the programs on...
(More)
Palm Treo 680, Light does not work, the light in the keyboards works and I can see the programs on the screen, but they are dark...I changed the Lcd screen twice,but the status is still the same..what else could if be?
