Question about Sony Video Cameras
How to eject tape manually sony vx 2000. camera is damaged and doesn't power up. i need the tape before taking the cam into a repair shop
5 Suggested Answers
sonyspares
  • 89 Answers
SOURCE: code 32:11 will not eject tape sony tvr67
The mechanism got stuck. Open the cassette compartment screws and apply external DC to the Power input and eject the tape. If this is not possible refer to a skilled technician. If you need the service manuals and mechanism for replacement write to us.
Posted on Dec 09, 2006
SOURCE: "Re-attach the power source" but tape is stuck, door open
I had the same problem. First, depress the reset button, located on the camera body (where the LCD screen closes over it). It is hard to see at first. It is important that the camera be set to the OFF position. When the camera is whirring after the reset, then hit the EJECT button so the tape comes out. Take the tape out and insert it back. That's it. My camcorder worked fine and let me record or plaback once I followed those steps.
Vic
Posted on Oct 26, 2008
SOURCE: Cannot insert tape into canon MV800. Always ejects
Hi Everyone,
our MV800 was doing the the same so i "accidentally" dropped it (i got a bit frustrated and it was out of warranty) and now it works fine. please note it dropped about half a meter on carpeted floor while it was off.
Hope this helps
Posted on Dec 18, 2008
SOURCE: can not eject tape
I had same problem, while transferring media from TRV-16 to DVD, tape would not play, then would not eject. This after transferring several tapes to DVD. I tried several things over the last couple months that did not work before finally getting it open today. It did me no good to remove several of the outer panels that were each held by two "tiny" phillips head screws each. Went to the internet, found your post, also found a post that referred me back to SONY page which follows.......
Follow this procedure to troubleshoot if the cassette compartment will not open or the tape is stuck and will not eject.
IMPORTANT: If your camcorder model has a RESET button, first try pressing this button. If there is no RESET button, or pressing the button does not resolve the issue, continue with the troubleshooting steps below.
  1. Turn off the camcorder.
  2. Remove the battery from the camera.
  3. Remove the AC power supply from the camera.
  4. Slide the power switch on the camera to the VTR , VCR or CAMERA mode for 15 seconds.
  5. Slide the power switch back to the OFF position.
  6. Connect the AC power supply to the camera.
  7. Attempt to open the cassette compartment.
"NOTE: If the issue is still unresolved after completing all of the troubleshooting steps, service may be required."
After I did this, I could hear a whirring sound when I hit eject, although nothing came out. While the whirring was going on, I pulled up and out with constant pressure and the cassette holder opened. The tape had jammed apparently as the little protective plastic tape guard was jammed partially open when I pulled the cassette out. Good Luck and don't be afraid to put a little pressure on the door if you can hear the door trying to open.
Now I turn to recovering the tape, but having grown up with cassette decks, don't believe it will be a problem.
Posted on Jan 23, 2009
Sony dcr-trv350 tape wont close
there is a risk of hardware damage.make sure you dont force the tape into the cassette compartment to avoid damage to the unit or tape.here's what you can do.
1.remove the tape from the compartment.
2.ensure proper type and size of tape is used.
3.ensure no packaging material or foreign material inside the compartment.
4.if attempting to record, make sure cassette tape rec/save switch is set to rec position.
5.reinsert the tape, make sure it's properly inserted.
6.if still won't close or tape ejected again,remove tape.
7.reinsert a diff tape.
8.attempt to close compartment.
9.if issue unresolved, press the tiny reset button while cam is powered on (located in the panel where the lcd screen goes to,just below all the other buttons). you may also do a power reset procedure: remove batt, remove ac adaptor,set power switch to vcr, leave the cam without power for at least a minute, switch power back to off, reinsert ac adaptor/batt and turn cam on, attempt to close tape compartment.
if issue persists, service would be needed. hope this helps.thanks:)
Mar 26, 2010 | Sony Handycam DCR-TRV350 Digital Camcorder
Sony PC-105 - camera won't charge, hence tape will not eject. Is
I just had the same issue except I left my camera out in the rain. My camera is a DCRF-HC32 Sony Handicam. There is a reset button on the side of the camera where the eject door is. Take a paper clip and hold the reset button in for 5-10 secs. The camera will beep, power on, open the door and it ejected.
Jan 21, 2010 | Sony Handycam DCR-PC105 Mini DV Digital...
I have a Sony CCD-FX410 8mm camcorder. It is in excellent condition. I was going to transfer all my 8mm tapes to DVD and decided I should get a head cleaner for it. Found one at BestBuy, put it in and it...
This is my 3rd try to get a solution. I have a Sony 8mm camcorder, CCD-FX410 and a head cleaning tape is stuck in it and I can't get it out. This camera is in EXCELLENT condition. I tried going to Sony's website and they no longer offer service on it. Both of the other people who answered this told me to turn power off, unplug cord, turn on to VTR and wait 15 seconds, then plug cord in again. It didn't work. After I put the head cleaner in, it wouldn't play and kept trying to eject. Finally it just started beeping and flashing an icon in the viewfinder. Manual says to send for repair. Any ideas on what I can do? Can not get tape ejected. Thank you.
I know CCD-FX410 camcorder was launched in July 1992 and I also know what is the reason of problem in your camcorder and I'm afraid it can not be solved because its an old piece now. Parts are no longer available and problem is leaky electrolytic capacitors on its circuit boards. Time factor is involve here, it is not operational mistake.
I can help you out to eject stuck head cleaner tape in camcorder. If you are looking to bring it back in business then it is not possible because an experienced camera tech can repair it and will charge you more then camcorder worth.
Hit "add a comment" button to assist you in ejecting tape. You need to apart camcorder and should have 4 or 6 volt DC supply in hand.
Thanks.
Apr 19, 2009 | Video Cameras
Sony Cam DCR-PC100, "eats" tapes and when ejecting, pulls tape
The take up spool is not working upon ejecting. I would take it to a Sony Service Centre for service.
Jun 03, 2017 | Sony Handycam CCD-TRV43 Camcorder
Error Code C:32:11 Tape does not eject
try removing the button cell battery, main battery, and any other power source from the camera and let it sit for one hour. THen using only the AC adaptor, see if the camera works, if it doesn't then you may have to take it to a repair shop, cause the cassette door has malfunctioned.
Mar 23, 2008 | Sony Handycam CCD-TRV37 Camcorder
Camera will not accept mini-dv tape anymore
Hello dear sir;
I have SONY handy cam(model 42E) that finger touch keys doesn’t work .what do I do now.
Please help me and send a procedure to repairing.
I am Iranian mechanical engineer.
Oct 24, 2007 | Sony Handycam DCR-HC42 Mini DV Digital...
Tape will not eject
You have mechanism damaged or broken some circuit board. It have to be opend to repair, but have to be one proficional to fixe it.
Sep 07, 2007 | Sony Handycam CCD-TRV35E Camcorder
Tape ejects every 60 to 90 seconds regardless of the mode the camera is in
The flip up cover over the cassette housing has the "eject" button built into it. Sony has had problems with the flexible harness that connects this door to the camera body. The harness rubs against the metal frame of the camera and causes various malfunctions such as the constant eject symptom you are having. Sony service in Laredo, TX can repair this for you, it is no big deal. Good luck, this is a nice camera! Joe Weibel customelectronics.org
Feb 11, 2007 | Sony Handycam CCD-TRV87 Camcorder
Code 32:11 will not eject tape sony tvr67
Dec 07, 2006 | Sony Handycam CCD-TRV67 Camcorder
Tape ejects a third of the way and stops
I believe that you have a problem where the tape is not being taken completely back into the cassette housing. Either the tape is bad and jammed or the idler is slipping. As it starts to eject pressure is put on the eject mechanism and it stops and reverses (as it is suppose to) to keep from damaging the camcorder. Unless you are familiar with camcorder repair you could do more harm than good forcing the unit open or trying to get the tape out. You should take it to a repair shop and let an expert take care of it. It shouldn't cost much to remove the tape and check for damage. Perhaps $50 to $100 US. Good luck.
Jun 11, 2006 | Sony Handycam DCR-TRV740 Digital Camcorder
Video Cameras Logo
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
