Question about ASUS Main Station P5WDG2 WS Professional (ASKU52233) Motherboard
After a resolution; "disconect the batteri on board" for reset,
My raid dosent work, I now have C. D. G. before my :C had all the programs, and :D all my files (data), and no :G How can I restore RAID
  • pb_musik Jul 29, 2009
    How do I enter Raid, it doesn't show up when booting as before
  • ASUS Master
  • 13,433 Answers
You need to configure the raid again from the raid config.. confugure it as it was, if you can't restore it use a file recovery software to recover your data..
I recommend File Scavneger, you will have to use it in raid mode.
http://www.quetek.com/prod02.htm
Posted on Jul 29, 2009
  • Ekse Jul 29, 2009
    Check if its turned off from bios, make sure raid is enabled.
  • Ekse Jul 29, 2009
    Since you removed the battery the bios restored to defaults, so the raid is most likely disabled and you just need to turn it on.
My car alarm disconected n it doesnt start
Disconnecting the alarm prevents the starter from turning and the fuel pump from running. Gotta fix the alarm system.
Oct 03, 2014 | Nissan Primera Cars & Trucks
Moter board n1996 raid mode how can i reset?
By reset I guess you mean you want to enable or disable raid. The BIOS might have the option or right after you start the PC watch for a key combo to access the software and modify some parameters.
Jul 13, 2014 | Acer Veriton 7600GT PC Desktop
I have sony vaio vgn-mw21jf and I dont know my bios password I need one time password when you contact me i will send my code thanx
you can try this either buy a password removal program which personally i dont think would work on the BIOS the only other solution is to locate the COSMOS battery un pug it for 24 hrs that should work remove the panels on the back of the pc after disconecting it from the mains aswell as the battery you will be looking for a round pice of plastic with a red and black wire and a white conector simply pull it out to disconect it doing this will reset the BIOS completely as new .
Oct 06, 2010 | Sony VAIO VGN-FZ470E/B Laptop
The battery in the key died does this mean the car cant be started?
CAN BE SO. BUT GENERALLY IS DUE TOO THAT C-LOCK DOSENT DISCONECT THE IMMO-ALARM WHEN YOU OPEN THE DOOR MANUALY,
Sep 26, 2010 | 2002 Mitsubishi Eclipse
My 2008 Buick Lacrosse will not start. The electrical system seems to be going crazy when I try - like unlocking the locks and trunk and the windshield wipers coming on.
I have a buick lacrosse and it wont crank it not saying anything everything woorks in the car but when i try to turn it over nothing happens
Sep 15, 2010 | 2008 Buick Lacrosse
Garage door dosent work whit remote control, but i works manuelt
check the remotes batteries and take a finger nail emery board and lightly sand the battery and remotes terminals,also try getting up close to the receiver with the remote maybe its a blocked signal,also make sure the antenna on the receiver is out in the open and not wrapped up somewhere,then also remove the receiver boards and check those connections too for corrosion and reinstall and see if this helps
Jun 20, 2010 | liftmaster Chamberlain Garage Door Opener...
Need raid pata driver for foxconn rc4107ma motherboard
Normally RAID setup on board, is handled in the BIOS settings.
Feb 21, 2010 | Computers & Internet
Program says it cannot find any previous programs and change to win 98 then it says to put win xp back in cd then back and forth confused!!
my MSI MOTHER BOARD model no. is K8MM-ILSR(601-6741-030)
MY PROBLEMis that ......... VIA SATA RAID Driver is not working. Without this ican't install OS in my system. this driver in floppy thats why floppyis corrupt. on my floppy writen like that ......... G72-VASA040 VIASATA RAID Driver For VT6420/8237. I Want this software. my mail id ismanishjee4u@gmail.com
i have msi mother board,amd athlon 64 bit processor,sata hdd 120GB,
May 04, 2009 | AOpen Computers & Internet
Raid
I might guess two things: 1. the battery failed (and has been replaced), 2. the motherboard has both SATA and IDE sockets for hard disks and you are using IDE.
If the latter, (and the BIOS settings were lost when the battery went) the BIOS setting would default to SATA hard disks and produce the mesage in the POST screen of, 'The number of disks is not adequate to create a RAID array' and no keys will work in the POST screen except ESC.
Repeatedly press DELETE (on most computers) on start up, ignore the POST screen, and the BIOS settings screen will come up. Check the date and reset, then goto INTERGRATED PERIPHERALS and reset SATA to IDE, save and exit. This cured my problem.
Feb 27, 2008 | ASUS K8V-MX Motherboard
Need help on SuperMicro SuperServer 7043M-6!!
ok, all you have to do is reset CMOS. the same thing happened to me once I tried to install windows on my supermicro board. What you have to do is load the bootable CD that came with the board and follow the instructions in your book.
What happens is that windows does not have the drivers for the supermicro RAID and SATA components. The board will recognize these on it's own until you go to install windows improperly. Windows does not have the drivers for those, realizes it, and says "Windows has stopped to prevent damage" but it does it anyway. Just clear CMOS, read the book with the board on how to install an OS, and try again.
Clearing CMOS: This can be done by taking out the 3.5v watch battery you see on the board for about 5 minutes. Another and riskier way is to clear CMOS by shorting the pads. On a diagram of your board, you should see CMOS Clear. Find those two pads on you board in that general area from the diagram. You'll know you've found it because the board has CMOS Clear printed near them. Just touch them with a screwdriver for 5-10 seconds. CMOS should be clear and ready to start new.
WARNING! Be careful when clearing CMOS with the pads, if you stick the screwdriver in the wrong place, you could damage your board. Be sure to unplug your power supply before working on your machine (I'm sure you know this.) and be sure to get the correct drivers for windows this time! Oh, and rechange any settings you changed in CMOS since it has been reset to the factory defaults.
Feb 06, 2008 | SuperMicro SuperServer 7043M-6
ASUS Main Station P5WDG2 WS Professional (ASKU52233) Motherboard Logo
29 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
