Power Macintosh G-3 minitower computer Hard Drive Replaced
Original SCSI hard drive replaced with an 80 GB CAVIAR EIDE ATA 100 hard drive.
After replacement, it starts up but nothing appears on the monitor.
Should there be some compenstion for the SCSI that was original with the computer?
  • Noraps Nov 24, 2007
    Thanks I will install the operating system.  I only installed the installation disk that came with the G-3.  Will let you know if this works.  Thanks again.
  • Noraps Nov 25, 2007
    This is a MacIntosh Computer.  I tried installing the operating system  9.0 for the Mac G3 computer, but nothing happened.
    Can I redetec the  BIOS on a MacIntosh Computer?
    Prodigy:
    An expert who has answered 500 questions.
  • 620 Answers
Hello Noraps
You have to redetec on BIOS and see if detec the new drive, depending on the BIOS, Brand PC, etc, to do this, and detect the EIDE drive. give more info
Posted on Nov 25, 2007
  • Carlos L. Burgos
    Carlos L. Burgos Nov 25, 2007
    hi Again Friend
    Well , yes, of course for reset to default, in case of any other hardware problem, then install the system let me know
    Carl
  • 34 Answers
NO you dont have an operating system yet.....please install windows or some operating system
Posted on Nov 24, 2007
My new Western Digital Desktop PATA EIDE 3.5 Inch Internal 250GB Hard Drive only shows 127GB on My Computer. I am running XP SP3 with IDE Connectors. Is the Mother Board too old to handle that many...
The motherboard BIOS most likely have a hard drive size limit. Yes you can create two or mare partitions to use the rest of the hard drive space.
Go to Control Panel - Administrator Tools - Disk Manager to create a partition and format this partition.
Aug 12, 2012 | Western Digital Caviar SE 250GB 7200rpm...
Can not read
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
Feb 05, 2011 | Seagate Barracuda 7200.10 ST3160815A -...
My pc can not find this drive
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
Jan 31, 2011 | Seagate Barracuda 7200.10 ST3160815A -...
I need to replace the hard drive in my v5000 Compaq laptop. it is currently a mk8025gas toshiba 80gb. how do i choose a newer updated hard drive to match? do i just install and turn back on with the xp...
Basically you insert a new drive and insert the Windows XP installation CD and follow the screen instructions.
The specification for hard drives for the Compaq V5000 are as follows :-
Table 6-3
Hard Drives
120-GB* 100-GB* 80-GB*
Dimensions
Height
Width
Weight
9.5 mm
70 mm
102 g
9.5 mm
70 mm
102 g
9.5 mm
70 mm
99 g
Interface type ATA-5 ATA-5 ATA-5
Transfer rate
Synchronous (maximum)
Security
100 MB/sec
ATA security
100 MB/sec
ATA security
100 MB/sec
ATA security
Sep 30, 2009 | Compaq Presario 1.8GHz Mobile AMD SempronT...
My Computer did not access Western Digital Hard Disk, Model No. WD 1600 AABB Caviar SATA.
Good morning! Please make sure that the drive’s power and SATA cables are properly connected. If the Serial ATA host adapter card is installed in a 64-bit PCI slot on the system motherboard, move the card to a 32-bit slot.
Verify that only one power cable (either SATA or legacy) is connected to the drive. Check to see that the power connector and SATA interface cable are securely attached and that the
SATA host adapter card is properly seated in the PCI slot.
The Serial ATA interface connects each drive in a point-to-point configuration with the built-in SATA port on the motherboard or with the SATA host adapter card; therefore eliminating the master/slave relationship as required with EIDE. Each drive utilizes its own
cable for data transfer rates. Jumper settings for Western Digital Serial ATA hard drives are mainly used for enterprise storage environments.
Most third party controller cards and RAID adapters are recognized as a SCSI device under Device Manager. This is normal and will not affect your drive or system performance.
To verify if the Serial ATA drive is recognized by the system, Right-click on the My Computer icon, select Properties, left-click on the Hardware tab, and click on Device Manager in the window. Double-click on Disk Drives. Your new Western Digital Serial ATA drive should be listed as a "SCSI Disk Device" or "Serial ATA Disk Device." If not, make sure that all cables are securely attached and that your system BIOS has been properly configured. regards
May 12, 2009 | Computers & Internet
Hard disk drive
try reading the hard disk drive myths....it may explain more.
http://www.techarp.com/showarticle.aspx?artno=84&pgno=1
Feb 04, 2009 | Seagate Barracuda 7200.10 - 250GB -...
Difference between HDD and SATA
Buying a new SATA hard drive is confusing if you don't understand the differences between the various drive types. Which hard drive should you buy?
SATA Hard Drives (Serial ATA) are the most popular drives being sold today. Alongside them in the store however you will also find boxes labeled Parallel ATA or SCSI. So what are the differences between these hard drives and which one should you purchase? Your decision is dictated by what your computer can accept. Check with your computer's manufacturer to see which drive style you can use. Most newer computers purchased within the last two years accept SATA connections. If your computer cannot accept one of the newer SATA hard drives you can purchase SATA adaptor cards that plug into an empty expansion slot on your computer's motherboard. You can purchase SCSI adaptors as well, so follow these tips to guide your decision.
SATA vs PATA: Serial ATA vs. Parallel ATA Drives SATA hard drives have many benefits over their older cousin, the Parallel ATA drive. Chief among these differences are:
  • SATA hard drives are faster and perform much better than traditional ATA drives and are better for high bandwidth applications such as video editing and multiplayer gaming.
  • SATA drives use a smaller, cheaper cable to connect to the computer's motherboard. These cables can also be up to three feet in length compared to eighteen inches with Parallel ATA cables.
  • SATA hard drives can be hot swappable, meaning that they can be disconnected and reconnected without powering down the computer. There are limits to this of course. You should never disconnect your boot drive while the computer is operating.
  • SATA cables are easier to plug in without damaging the delicate connecting pins on the drive.
  • SATA hard drives are significantly faster than external USB hard drives.
SCSI Hard Drives SCSI hard drives are the elders of the storage world. SCSI is one of the oldest specifications but it is also the fastest and thus has been widely used in network servers and other high speed, high bandwidth applications. Unfortunately this high speed storage has also meant much higher costs. SCSI drives were once standard in all Macintosh computers but have since been replaced by the cheaper SATA based hard drives.
  • SCSI drives are also hot swappable, similar to the SATA drives.
  • Some varieties of SCSI can be used with SATA
  • SCSI drives are often set up in a mirroring arrangment to allow for instant, continuous backups of the hard drives.
  • SCSI drives are still the most expensive drives on the consumer market.
Your basic rule of thumb should be to purchase a drive that is designed to work with your computer's motherboard. Try to avoid using SCSI adaptors or SATA adaptors unless absolutely necessary as the whole point of using a specific kind of hard drive is to get the most speed and storage for the money.
Thanks alot,
Sanjeev Kumar
Jan 22, 2009 | Tablets & eReaders
Ze4325us laptop...hard drive upgrade.....
I know the original question is over a year old, but here it goes for those just tuning in. Your HP ze4325us can only recognize a hard drive that is under 137.4GB. If you try to install a hard disk larger than 137.4, your computer will start to fail over time. I would recommend a 120GB hard drive, ata-100 / ide / eide, and spinning up around 5400 or 7200 rps. It would make your task easier. If you want to go bigger, use the hard drive manufacturers disk utillities programs (check manufacturer website) to partition and format before installation. So, if you were to puchase a 160GB drive, you could partition it at 137.4GB and 22.6GB. My advice, make it easy and just find a 120GB drive. Less hassles!
May 25, 2008 | HP Pavilion ze4325us Notebook
Whats the largest replaement HD I can put in my Presario
The HD capacity is defined by the bios software in the computer, if HP/Compaq tells you that 80Gb is the maximum capacity, then I think you should believe them, after all they should be the first one interested in selling more high price products, go for the 80Gb is .
May 03, 2008 | Computers & Internet
I need a new hard drive
You can go up to 120 GB for this model computer. Following is a link to Drive Solutions, Inc. It shows a 120 GB ATA drive available for your drive. ATA is the formal name for an IDE drive.
Here's the link:
http://www.drivesolutions.com/cgi-bin/shop/ug2store.cgi?command=listitems&kind=acl&pos=0&type=itemid&itemid=acl228
Good luck.
Mar 18, 2008 | Computers & Internet
Computers & Internet Logo
61 people viewed this question
David Payne
David Payne
