SOURCE: the digital clock seems to be set to 24 hr insted of 12 hr time
No Problem here ya go
To change the clock to 24-hour format:
1. Press and hold the CANCEL and Delay
pads for three seconds.
2. Press the More+ or Less - pad to select
12 or 24 hour.
SOURCE: Change watch setting from 24 to 12 hr clock
my 40/6703 has 4buttonstop left-light topright-st-stp bottom left mode bottom right reset can u help
SOURCE: Changing from 24 hr system to 12 hr system
SOURCE: change from 24 hr clock on sciphone i9+++
goto date and time settings in your phone take the time settings and change the clok from 24 hrs to 12 hrs it will work try it
SOURCE: I have a blue hat toy co. time and space
We also purchased the same alarm clock and I accidentally figured out how to convert to 12 hour (AM/PM) format from 24 hour format. Once the time is set correctly, and you are out of the time set mode, you can press the UP key and it will toggle between the formats.
To set AM/PM (12 hour) or Military (24 hour) time - Press the On/Off button once to turn your Wave radio off.
Press and hold Clock Set, and then press On/Off to switch between AM/PM (12 HR) or military (24 HR) formats
