Question about Hitachi 46F500 46" Rear Projection HDTV-Ready Television
Picture adjustment I just bought the Hitachi 46f500 used and want to know if there are any adjustment that i should make to enhance the picture quality. This is my first HDTV... Thanks
    Problem Solver:
  • 17 Answers
Re: picture adjustment
Usually there is options in the menu button on the remote to fix the brightness contrast etc also make sure your hdtv cables (make sure you have these if not you will not have good picture)are working and connected properly.
Posted on Nov 30, 2007
0 characters
3 Points
Have a 46f500 hitachi projection television. Started out with a blue reversed arc hanging down on upper right. Now images are not focused, and red, blue and green are layered. Double images. I looked...
It is a convergence problem and set uses two of the STK-392-150 CHIPS. Both will have to be replaced and the set adjusted.
for more information let me know if you can solder and your skill levels.
Jan 11, 2011 | Hitachi 46F500 46" Rear Projection...
My Hitachi 46F500 TV will not adjust either manually or in magic focus has green lines across top of screen and some red tinting in the picture this a gun issue or mirror in need of...
Replacing the lamp will do the job. It is the lamp that is faulty not the gun or the mirror.
It will cost just a few box to get a new lamp.
Take care and good luck
Oct 10, 2010 | Hitachi 46F500 46" Rear Projection...
My picture on the hitachi 46f500 is all small white line? when i try a dvd it is out of focus and all grren, blue, and red....
Ur convergence it dead.U know how solders?Buy a convergence kit use what in that kit.Tries Websites.Tv repair,
Dec 20, 2009 | Hitachi 46F500 46" Rear Projection...
Hitachi 46F500 TV has red and blurry picture.. what to do?
If this problem has been gradually getting worse, it is most likely to your picture tubes getting weak, and it is time to replace the set I'm afraid.
If the red is smearing off to the side of reddish objects in the picture it is most definately the tubes.
Nov 02, 2009 | Hitachi 46F500 46" Rear Projection...
I have a Hitachi 46F500 tv and the red crt bowed
I just had the convergence replaced and have a great picture
Aug 16, 2009 | Hitachi 46F500 46" Rear Projection...
Pictures very dark, Brightness all the way up. Contrast does not adjust
I have the same problem. I was able to temorarily fix the issue by taking the back cover off and blowing all of the dust out. But this only worked for two days. Now the problem is back. Did you fix the issue with your tv? Thanks.
May 28, 2009 | Hitachi 46F500 46" Rear Projection...
My wife let the Wii remote and broke the front plexi-glass.
You can find a new Hitachi replacement protective screen and screen assembly for a model # 46F500 from a major Hitachi distributor at the following links:
Hitachi 46F500 Replacement Part Screen Assembly
Hitachi 46F500 Replacement Part Protective Screen / Ultra Shield
Feb 03, 2009 | Hitachi 46F500 46" Rear Projection...
Hitachi 46F500
Having yellow and blue shadows outlines show up on picture.
Oct 03, 2008 | Hitachi 46F500 46" Rear Projection...
No picture, have sound
Dude, you dont have the same problem thanks for junking up my post.
Ok, so I have replaced the SUB power assembly and the SUB Defconvergence board, picture looks decent however magic focus just blanks the screen out and cannot adjust manually does the same thing.
Is there a way to enter the service menu and initialize the magic focus functions after servicing.
It must be using the saved ROM settings, but it wont let me adjust anything convergence wise.
Dec 28, 2007 | Hitachi 46F500 46" Rear Projection...
Picture is dark
Pull the back off and tap on the deflection board. Does it get brighter? If so, you have a bad connection and or cold solder joint.
Dec 07, 2007 | Hitachi 46F500 46" Rear Projection...
Hitachi 46F500 46" Rear Projection HDTV-Ready Television Logo
71 people viewed this question
Top Hitachi Projection Televisions Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Projection Television Expert? Answer questions, earn points and help others
