Question about Sony Playstation 3 (PS3) Console
Turn on power, then red led starts flashing on front of ps3
  • 51 Answers
Sounds like you have "the yellow light of death" and your system needs repair, call Sony customer support. Go to youtube.com and type *PS3 yellow light of death* and see if that's the same problem you are having.
Posted on Jul 29, 2009
How do you get the ps3 to pick up the blue tooth head set
Pairing the Headset with the PS3
Before the Headset can be used with the PS3, the two devices must be ‘paired’ so they can communicate with each other. Use a gaming controller for this procedure and ensure that the Headset is powered on (flashing blue LED light) and that it is not being charged via USB cable.
1. Power on your PS3 console.
2. Within the “Settings” menu, press X on “Accessory Settings.”
3. Press X on the icon labeled: “Manage Bluetooth® Devices.”
4. Scroll down and press X on the icon labeled: “Register New Device.”
IMPORTANT: Depending on your model of the 8860 Bluetooth® Headset, your power button is either an oval shape with an icon of a circle with a line going through it (5a) or it is a button with a phone icon (5b). Please follow the appropriate next step depending on your model of the 8860.
5a. Once at the next screen, prepare the Headset to be paired with the PS3 by holding down the K1 button until the LED flashes Blue and Red (hold K1 approx 12 seconds).
5b. Once at the next screen, prepare the Headset to be paired with the PS3 by tapping the pairing button located next to the volume controls on the side until the LED flashes BOTH Blue and Red.
6. Once the Headset’s LED indicator is alternately flashing Blue and Red (indicating the Headset is ready to be paired), press X on “Start Scanning.”
7. Once Scan is complete, the PS3 will recognize all Bluetooth devices within range.
8. Locate “8860” from the list of available devices and press X on its icon to be prompted for a Pass Key
9. Enter 0000 (four zeros) as the Pass Key and press X on OK
10. You should then be taken to a new screen stating: “Register completed”
Trouble Shooting
Q. The PS3 is unable find the Headset.
A. If the Headset has been paired with another Bluetooth device, the PS3 will have trouble finding the Headset. Either remove the Headset from the paired device or turn off the Bluetooth power on the paired device.
Source: www.madcatz.com/faq
Aug 11, 2010 | Mad Catz PS3 Bluetooth® Headset Wireless...
My ps3 wont go on. Red light flashes then goes off. Any ideas?
The best way is to fix red light flash and goes off by yourself! Learn the PS3 fixing technique by using this product here : PS3 Ultimate Fixing Guide This is a package of text and video tutorials written by a professional PS3 repairman. Follow his demo you can easily to unscrew your console and fix parts inside. When you have learned the repair skills, no need to ask anyone here again!
Aug 02, 2010 | Sony Playstation 3 (PS3) Console
The front LED flashes red & blue when I turn it on. What does this mean?
LED Indicators - LaCie 2big Network
The LED indicators above the drive bays and the front LED indicate drive status and activity.
During Startup
  • Front LED – blinks red/blue until both disks are powered on, then turns solid blue.
  • Rear LEDs – blinks red/blue until corresponding disk is powered on, then turns solid blue.
NOTE: If the device is not able to initiate the boot process following disk startup, the front is solid red.
During Bootup
  • Front LED – solid blue
  • Rear LEDs – solid blue
NOTE: If a disk is failing, both the disk’s corresponding rear LED and the front LED will be solid red.
During RAID Synchronization
  • Front LED – solid red
  • Rear LEDs – The LED corresponding to the original disk will be blinking blue and the one being synchronized is blinking red
  • Once both disks are synchronized, their corresponding rear LED and the front LED will be solid blue.
Apr 06, 2010 | LaCie 2 TB 2big Triple Interface External...
My playstation has the light trun green yellow flashing red light
With your PS3 turned off, press and hold the Power button on the front of the PS3 for about 10 seconds (the system will beep as normal as it starts up but after 7-10 seconds it will beep again). The video settings should now be reverted. Doing this will also reset any theme settings. try this? seems to fix alot of issues.
Jan 22, 2010 | Sony PlayStation® 3 (80GB) Console
System will not turn on
hard drive error get a new hardrive -might work or call sony for a replacement ps3
Aug 16, 2009 | Sony Playstation 3 (PS3) Console
Ps3 will not reconize intec in any way wireed or wireless. just invisible
CONNECTION A:
DO NOT INSERT BATTERIES INTO THE CONTROLLER; THE USB CABLE USED WILL SUPPLY THE POWER TO THE CONTROLLER.
STEPS # 1 – TURN THE POWER ON TO THE PS3 CONSOLE.
STEP # 2 – CONNECT THE USB CABLE TO YOUR PS3 CONSOLE AND CONTROLLER.
STEP # 3 – NEXT PRESSE THE SYNC BUTTON ON THE CONTROLLER, THE CONTROLLERS LED INDICATOR’S LOCATED ON THE FRONT OF THE CONTROLLER WILL START TO FLASH RAPIDLY.
STEP # 4 – CONNECT THE USB RECEIVER TO THE USB PORT ON THE PS3 CONSOLE.
STEP # 5 – WHEN THW CONTROLLERS LED INDICATOR’S LOACTED ON THE FRONT OF THE CONTROLLER START FLASHING SLOW PRESS THE HOME BUTTON.
WHEN THE CONTROLLER HAS ESTABLISHED A CONNECTION BETWEEN THE CONTROLLER AND THE USB RECEIVER ONE OF THE CONTROLLER’S LED INDICATOR’S WILL BECOME SOLID RED.
Jul 12, 2009 | Intec PlayStation 3 Turbo Shock III...
Ps3 nodisplay, although I reset output video
minhpham have to tried to insert any disc like moves, song differnt game frm call duty.
and if it dosnt work let me knw.
abdz
Sep 16, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
194 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
