Question about HP Compaq nc6320 Notebook
How to you remove the dvd drive on a hp compaq nc6320
  • 535 Answers
First shut down the computer and remove all cables and the battery.
Look underneath the computer for any screws near the approximate edge of the optical drive (image a square big enough to hold a disc). They may be marked, but whether or not they are marked remove them (there may only be one) and see if you can pull the drive out.
If this doesn't work, look for any screws which might hold the keyboard in place (these are opfen marked "K") and remove them. Then open the computer. Usually, the keyboard is held at the edges by some spring-loaded latches. Use a small screwdriver to both push each latch back and lift the keyboard slightly so that it is no longer held down. Sometimes there are latches on one side and tabs on the other, so first you release the latches then move the keyboard slightly in order to release the tabs. Fold the keyboard back carefully. You may then find a screw or two near the edge of the optical drive. Try removing these and see if the drive comes free.
If neither of these work, then you will have to look harder.
Assuming that you have got the drive out you will need to unscrew any fixing brackets and probably prise off the bezel (unless whatever is on the new drive is physically the right size). The bezel is normally held on by two or three plastic hooks which you can carefully release with a screwdriver. Then put the fixing bracket(s) and bezel on the new drive and install it.
Good luck.
Posted on Jul 29, 2009
  • 50 Answers
It will be held in place by a single screw. This can either be on the bottom of the machine just behind the drive (towards the center of the base) or under the keyboard.
Once the screw is undone, turn the laptop on, hit eject on the drive so it pops open, turn off the laptop and fully extend the tray - once the screw is removed it should slide nicely out.
3 Suggested Answers
sparkyuiop
  • 91 Answers
SOURCE: HP Compaq nc6320 PC bios password
Ok, as long as the high security level has not been set in the bios then the following will work to reset / disable the bios password.
1. Remove the battery and mains adapter.
2. Remove the memory cover on the back of the laptop and remove the 2 keyboard screws.
3. Open the laptop and at the top of the keyboard you will see 4 sliding tabs. They are located between the 'Esc & F1 keys' 'F4 & F5 keys' 'F8 & F9 keys' and 'F12 & delete keys'. Slide these down and lift the keyboard up and pull forward slightly so as to disengauge the bottom lugs. Be carefull as there is a ribbon cable at the bottom that does not need to be tugged or removed.
4. You will now see at the bottom behind the keyboard a small battery connected to the motherboard. Gently pull the small white plug upwards untill it is removed from the board.
5. Wait 5 minutes and re-connect the small battery plug.
6. Re-install the keyboard and push back the clips. You do not need to replace the screws yet.
7. Apply the DC jack and power on - DO NOT INSTALL THE MAIN BATTERY.
8. Turn the laptop on while pressing f10 repeatedly but slowly - Do not hold it.
9. If high security is disabled you should now be in the setup screen, select 'Restore Defaults' and press F10 to save.
10. The password is now removed.
If this does not work then HP say that there is no other way to reset it. Im not sure about that, there probably is by some method of de-soldering the bios chip. However the above method worked for me so I hope it does for you. Please rate if you have any luck.
Sparkyuiop.
Posted on Dec 03, 2008
SOURCE: Hp compaq nc6320 doesnt charge
I have had a similar problem and solved by another solution. I think you should try it before grabbing a soldering iron.
In my case my charger was not working from one day to another. So I bought a universal charger of Kingston. Worked without any problem for a long time ~6 months. Then same problem again. Checked voltage of the charger and that was okay. Strange thing with a charger of a friend, my laptop charged again! So I thought I needed to buy another one.
Still it was strange that two chargers broke in such short time and at the same time still have voltage around 19V and charging other laptops! So I checked a forum and there I found the follwoing solution (uninstall the AC adapter and reinstall it again in the device manager):
- go to control panel
- system
- device manager
- batteries
- uninstall the programm for the AC adapter
- go back to control panel
- check for new hardware and install the AC adapter software again
Problem solved! Even my old adapter works again!
Posted on Feb 18, 2010
How do i fix a problem of green power led continuously blinking in Hp compaq nc6320 laptop even when the battery is removed and the motherboard is outside the case?
HP Notebook PCs - Troubleshooting LED Blink Codes or ...
h20564.www2.hp.com/hpsc/doc/public/display?...na...
Hewlett?PackardHP Notebook PCs - Troubleshooting LED Blink Codes or Beep Codes During Startup or Boot ... HP Pavilion and Compaq Presario notebook computers built in 2009 or later use blinking LEDS to identify ... Press the power button to turn on the computer, and look for blinking LED lights on the keyboard. ... Continuous blink.Missing: green ‎nc6320
HP Notebook PCs - Computer Does Not Start and Emits an ...
support.hp.com/us-en/document/c01732674
This document pertains to HP and Compaq notebook computers. .... light next to thepower socket or the light on the AC power adapter and note its condition: off, blinking, or constantly on. ... Battery power LED off, and Caps Lock/Num Lock off.Missing: green ‎nc6320
HP 6735s won't boot, power LED blinks 7 times - HP ...
Feb 03, 2016 | HP Computers & Internet
Crack bios password on compaq nc6320 - please
You can crack dell bios password with Windows Password Recovery Tool 3.o . Here is a good post to help you:
http://www.windowspasswordsrecovery.com/crack-dell-laptop-password.htm
Oct 09, 2009 | HP Compaq nc6320 Notebook
If I take out my current hard-drive does it erase the memory?
no it does not as far as I am aware..please leave a vote for me..thanks..
Jun 12, 2009 | HP Compaq nc6320 Notebook
My Compaq nc6320 (hp) was damaged and said that the optical drive wasn't working or was missing, I took it in and had it repaired and the worker replaced the hard-drive for extra, it didn't say the...
Hi, removing the hard drive should not damage any component but be sure to touch something metal before you take it out as it will reduce the ammount of static discharge from the body.
Describe your HP Compaq nc6320 PC Notebook Problem
i have a Compaq nc6320 when i plug in the power cord the electricity led doesn't want to turn on i have changed the cords and the adapters and i doesn't power on or even charge the battery, did any one have an idea what to do in this problem?
Mar 31, 2008 | HP Compaq nc6320 Notebook
Big problem
to clear cosmos(reset bios) remove rtc battery for a few minutes then replace ;restoring bios to factory set.
battery looks like large digital watch battery.usually located(but not always) underneath keyboard.
Mar 18, 2008 | HP Compaq nc6320 Notebook
HP Compaq nc6320 Boot Disk
in case you can get a non boot disk , u can install it by using a start up floppy disk for win9x
Nov 15, 2007 | HP Compaq nc6320 Notebook
Can't reinstall xp pro on my hp compaq nc6320
Stephane, I ran into the same problem after wiping out my Compaq nc6320 and trying to install XP Pro. The fix is to disable SATA Native mode. To do this: Enter F10 Setup then System Configuration>Device Configurations>SATA Native Mode and disable it, save the changes and now you should be able to install XP Pro. Remember, when I did this the drive was blank, I don't know if that makes a difference or not. Best of luck! Bryan P.S. If you want to enable SATA native mode after you have installed XP Pro check out this link: http://forums1.itrc.hp.com/service/forums/questionanswer.do?threadId=1042050&admit=-682735245+1161793137260+28353475
Oct 04, 2006 | HP Compaq nc6320 Notebook
HP Compaq nc6320 Notebook Logo
392 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
