Question about Microsoft Xbox 360 Console
3 red lights - Microsoft Xbox 360 Console
  • 33 Answers
Sorry, but this is a hardware problem with the Xbox. There are a few solutions you can try to fix it on your own, but the best solution is to send it back to Microsoft for a repair. The warranty for this problem has been extended to three years, and any attempted repairs done by you may void your warranty or increase repair costs.
Get the serial number off of the sticker on the back of the console and call tech support at 1-800-4MY-XBOX to order a replacement.
Posted on Jul 29, 2009
  • 72 Answers
Looks like you have the "Red Ring Of Death"
You need to contact Microsoft as theres something wrong with your HDD. Its most likely your going to have to get a replacement or have it repaired.
    Sergeant:
  • 193 Answers
(copied fom a community forum cause i got tired of typing it out all the time)
The reason you're getting the e74 (3 red lights) error is because your console has a hardware malfunction which causes overheating. (the problem being microsoft’s cheep thermal grease) This is a problem that nearly 500,000 Xbox 360 owners will have to deal with. Luckily, it's easy to fix.
The first thing you need to do is shut off your console and let it cool down for several hours.
Then, clear off a table so you don't misplace any parts, and use a fine tip poker to remove the outer case (this will void your warranty), carefully remove the DVD drive and unplug the connection cable.
After the DVD drive is out, remove the fan and motherboard, along with the X clamp found beneath the heat sink. This will allow you to access the GPU and CPU.
Once you've can see the GPU and CPU, carefully clean them off and apply arctic silver compound on the GPU (get the arctic silver compound from a computer repair store near you for $1)
Let your console sit for 15 minutes, and then place 2 nylon washers on both sides of the heat sink screws.
After this, just put the system back together the same way you took it apart, plug it in and play.
Posted on Aug 14, 2009
Some keys on the keypad are not working, like the del key and the letter p
Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653Blackberry 8900 red light blinking call 9867635653
Feb 19, 2011 | RIM BlackBerry Bold 9000 Smartphone
Zanussi zwf 1430s,power going to machine but when button pressed green light does not come on just a red light nothing on display panel
Count how many times the red light flashes and how many the green light flashes.If its 1 green and 1 red thats water problems.If 2 flashes of red light check filter is clear and pump is free to turn.
Hope this helped.
May 18, 2010 | Washing Machines
System comes on and immediately red light flashes
PS3 flashing is not hard to fix. Do you want to fix it by yourself instead of pay $150 checking to Sony? Here's the solution :
PS3 Red Light Fixing Guide
Feb 21, 2010 | Sony Playstation 3 (PS3) Console
A red light keeps flashing and the screen says error when it comes on
If you have a red light flashing then you have one of the following: 1 red light e74, 2 red lights - overheating, 3 red lights GPU and the CPU, or 4 red lights you need to plug the av cable in.
For the 1, 2 , 3 red lights you can send it in to get it fixed or reapair it yourself with a good guide
Oct 26, 2009 | Microsoft Xbox 360 Console
A red ring is around my xbox start up button
How may lights are showing up?
3 red light is GPU and the CPU overheating,
2 red lights is general overheating
1 red light is E74 and 4 red lights is the av cable.
For the 1, 2, 3, red lights you will need to get it fixed you can either send it in to do this or repair it yourself
Plays games then stops when red lights start flashing
How may red lights are flashing?
1 red light normally E74 error message on screen
2 red lights overheating
3 red lights the GPU and the CPU have overheated.
4 red lights is the AV cable not plugged in properly.
You can fix the 1, 2, 3, red lights yourself or send it in for a fix
Oct 25, 2009 | Microsoft Xbox 360 Console
What causes the 2 red lights on xbox?
1 red light indicates that there is general hardware related problem with the console, 2 red lights indicate the overheating of the console, 3 red lights indicate the red ring of death and 4 red lights indicate that you need to tighten your AV console wire.
Oct 22, 2008 | Microsoft Xbox 360 Console
1flashing red light
one red light is also the E71 error as well.
Aug 04, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
157 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
