Question about Lanzar OPTI5.1 Car Component System
I have the lanzar opti1533d & it gets to hot to touch sometimes. y?
  • 3 Answers
Sounds like badair ciculation try an external cooler
Posted on Jul 29, 2009
What is the best vented/ported box size for my 15 sub that will give maximum output and maybe even more?
Unbless you are building a wall...I would never give up my back seat. I built "The Pace-Maker" which won IASCA Enhanced SPL Nationals in 91,92,93 & 94.
Sep 30, 2011 | Lanzar OPTI1533D Car Subwoofer
Installed lanzar 266 amp yesterday it went in protect mode on a song and now everytime i turn it on it is in protect mode
most commonly that means that somewhere there was an arc in the electrical either the pos or neg going into the amp or rcas or its the speaker wire from the amp to to the sub itself look especially for little wires touching opposit polarity wire (like a little +wire has moved and touched a - wire)
Oct 07, 2010 | Lanzar VIBE266 Car Audio Amplifier
Trying to install subs
If there is no red and black colored input wire connectors on the subs then it doesn't matter.Positive and negative does not really effect speakers and subs since it is DC anyways.
Jul 25, 2010 | Lanzar OPTI1533D Car Subwoofer
Can a rockford bass knob work on a lanzar amp
as long as the connections fit, or you can make the fit appropriately without the poles touching, it will work. All a bass knob is is a potentiometer ( analog dial). so they should all work with each other as long as you can make the final connection between the knob's plug and the amp.
GOOD LUCK AND PLS RATE THIS POST!!!!!!!
Jun 04, 2010 | Lanzar HTG244 Car Audio Amplifier
Subs wont work or do anything when hooked up
Check your safe light on your amp if it's green then the subs are **** but if you don't have a green light check your ground, just because it sparks when it touches dosen't mean it's a good ground so grind the paint off the bolt if need be. If all else fails get new subs, do your self a favor don't get lanzar products there horrible trust me on that one
May 11, 2010 | Lanzar (Pair) MAXP104D Max Pro Series...
How to wire 2 opti1533d by lanzar with the optidrive 2000d amp? how do i wire them if i put 1 amp on each sub
your speakers are 1 ohm per voice coil, dual oice coil. your amp is no lower than 2 ohms stable mono.
the proper way to wire this so that you do not burn out the amp is to run the 2 vioce coils in series. run the positive lead from the amp into the positive lead of one of the voice coils, then run a jumper wire from the same voice coil's negative lead to the same speaker's 2nd voice coil's positive input. then run from the 2nd voice coil's negative back to the amplifier's negative speaker lead.
you will be running for each speaker/amplifier set: amp + to terminal set 1 +, terminal set 1 - to terminal set 2 +, then terminal set 2 - to amp -
Oct 06, 2009 | Car Audio & Video
I have a lanzar vibe 286 its a very good anp and kick hard but it gets very very hot so hot you can **** an eeg on it what shud i doi know i can install a fan on it but were the back or front i dont know...
The impedence of the speakers does not match the amp operating impedence. This amplifier is made to run a 2ohms stereo stable which means 2ohms per channel or 4ohms bridged.
Jun 25, 2009 | Lanzar VIBE286 Car Audio Amplifier
When i hook up power sparks mosfets get hot real hot like a dead short i replaced the mosfets all eight were fryed big time most had burned right side leg off lanzar 1000 watt car amp
It is clear that there are serious internal issues with this amp, and that diagnosis - parts - labor could be upwards of $200.00 while it only retails for $99.00
Saving it is not cost effective.
Good luck
Aduz
Mar 28, 2009 | Lanzar 2CH 600W VIBERANT AMP Car Audio...
Lanzar vibe 230 400 watts amp
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
Jan 27, 2008 | Lanzar Vibe 235 Car Audio Amplifier
Lanzar OPTI5.1 Car Component System Logo
96 people viewed this question
Top Lanzar Car Audio & Video Experts
Radames Pagan
Radames Pagan
Joe Alexander
Joe Alexander
Jose Velazquez
Jose Velazquez
Are you a Lanzar Car Audio and Video Expert? Answer questions, earn points and help others
