Question about D-Link DP 301U (DP-301U) Print Server
D-link 301u using windows vista
Is there how tu install d-link 301u on windows vista? thank you
    Problem Solver:
  • 5 Answers
Primary solution is to enable all print services in Vista and XP. This is done through the control panel under Programs and Features or Add / Remove Programs. Enabled ALL print services, which is needed for LPR support.
Posted on Jul 31, 2009
I am using DP-301U print server and wanting to attach with hp 1020 plus. However the printer in not printing. what is the root cause and give the solution please...
Hello and welcome to fixya.
First off, I would like to provide you a link with the print server's manual to download it directly and have it as spare.
The printer you are trying to install is a laser printer (black/white only) and probably a bit old model.
Therefore, if you are trying to print from your computer over ethernet, and you have windows vista or 7 (64 or 32bit accordingly) you might have the inappropriate drivers for either the print server or the printer. You can find all of the HP printer's drivers HERE. Select carefully based on your OS.
As a SIDENOTE: If you just need the drivers installed and there are only larger setup execut. files available, you can use 7zip or winace to open up the *.exe file and navigate to the appropriate folder and extract only that one to your computer and install the driver(s) from there.
The D-Link DP-301U print server drivers are available HERE. Default username and password for the management console of the print server can be found at pdf manual page 25. The url to access the administration console is dlink-******,where the asterisks stand for the last 6 digits of the print server MAC address.
Overall, not to make things over-complicated (150+ PDF user manual pages) you need to do the following:
1. Install the appropriate drivers of your hp printer on the computer that will have also print serv. softare installed.
2. Install the appropriate software/drivers of the dlink print server on the same computer.
3. Plugin the usb cable of your printer to the print server's USB port.
4. Plugin the ethernet cable of your print server port to the ethernet port of your home router/switch.
5. Setup Fixed IP settings for your print server configuration (page 20 on the manual).
Let me know how that went. I believe you will manage to do it that way quite easily.
**Don't Forget to vote how helpful this was.**
Thanks.
Regards from FixYa.com
Apr 22, 2011 | D-Link DP 301U (DP-301U) Print Server
No documents are sent to the print queue when attempting to print to a printer through a DP-301U. Printing in Vista works fine, but not so much with XP.
Check and see if the drivers are installed correctly and configured on both pc's.Then see if the printer is installed and that sharing is enabled on the network. Mike tekman2300@yahoo.com let me know when you complete these steps and if it worked.
Aug 08, 2009 | D-Link DP 301U (DP-301U) Print Server
Using HP Laserjet P1006. Is it compatible with DP-301U
Yes. I just got mine working last night. Key is to enable print services for windows through the control panel. Without that LPR printing does not work.
Jun 08, 2009 | D-Link DP 301U (DP-301U) Print Server
Logon problem for dp301 U
Usually D-link routers use "admin" (without the quotes) as a default user ID and no password.
Thanks for using the FixYa Forums!
Mar 23, 2009 | D-Link DP 301U (DP-301U) Print Server
D-LINK PRINT SERVER DP-301U AFTER DOING A SYSTEM RESTORE ON MY DESKTOP COMPUTER (WINDOWS XP) I CAN NO LONGER PRINT TO MY SAMSUNG ML-2010 SERIES PRINTER ... PRINT JOBS ARE IN THE PRINTER QUEUE BUT WON'T...
- Kindly visit this web site for instructions:
http://support.dlink.com/faq/view.asp?prod_id=459&question=DP-100%20/%20%20DP-101P+%20/%20DP-300%20/%20DP-301P+%20/%20%20DP-303%20/%20DP-313%20/%20DP-301U%20/%20DP-311P%20/%20DP-311U%20/%20DP-311U_revB
Mar 12, 2009 | D-Link DP-301U (790069251979) Print Server
DP301U COMPATIBILITY
I have one of theses D-Link PD-301U. It soes NOT support most All-in-one printers like yours. According to D-Link's Web site, here are the HP Laser printers it supports (note the P1008 is NOT in the list):
LaserJet
  • 1200
  • 1500 (USB 2.0)
  • 2200
  • 2200D
  • http://support.dlink.com/faq/view.asp?prod_id=2135&question=DP-300U%20/%20DP-301P+%20/%20DP-301U%20/%20DP-311U%20/%20DP-G310%20/%20DP-G321
    Feb 09, 2009 | D-Link DP 301U (DP-301U) Print Server
    D-Link DP 301U Print Server not continuous print from vista
    Make sure you have byte counting enabled if you are printing through LPR.
    Dec 11, 2008 | D-Link DP 301U (DP-301U) Print Server
    D-Link 301U Printer Server using Windows Vista
    As shown here on the Dlink website, there is no support for either Vista 32bit or 64 bit
    Hope this helps - remember to rate!
    Oct 02, 2008 | D-Link DP-301U (790069251979) Print Server
    Migrating to windows vista
    No.... Drivers for windows Xp and Vista are not same... it will differ but dont worry... you can download the vista drivers from the following link
    http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=3694966&lc=en&cc=us&dlc=en&submit.y=0&submit.x=0&lang=en&cc=us
    Juz choose vista... and download drivers.... and enjoy working with Vista..
    Sep 16, 2008 | Compaq Presario 700 470024-192 Notebook
    Unable to setup printer driver fro D-Link DP-301U
    I'm not able to install the printer driver Officejet 5610 when conenct to D-Link DP 301U. It always prompt for missing file such as hpzimc09.dll hpzstw09.exe, I'm using the CD proviede when I purchase the printer and also try on the installtion file downlaod from HP website.
    May 22, 2008 | D-Link DP-301U (790069251979) Print Server
    D-Link DP 301U (DP-301U) Print Server Logo
    569 people viewed this question
    Top D-Link Computers & Internet Experts
    Prashant M
    Prashant M
    Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
