SOURCE: Set luggage lock
the lock is currently set to 000. To set your own combination and with the lock in the 000 position, open the case and on the inside of the lock mechanism you will see a red tab. slide this tab to the left and then move the digits on the front to your desired code. ie 123. then move the red tab back to lock in this new setting as your own personal combination. close the case and then move the digits away from our setting of 123 and this locks the case. only if the digitrs are 123 in this example will the lock now open.
SOURCE: I lost the instructions to reset the combination for two luggage
I lost the combination lock
SOURCE: Drilling out lock on scooter luggage box
if you have a new lock & key assembly,you can drive a small chisel or stout flat blade screwdriver into the old key hole about as far as a key would go. with a wrench on the chosel,turn it like you would the key to open it.now look inside,there is a clip or a nut holding the cylinder in place.R&R.
