Question about General Electric WSSH300G Front Load Washer
GE Washer model WSSH300G will not drain
My washer will start the wash and go through the entire cycles until the spin cycle. The washer cannot spin because the water does not drain and the error code comes out as water in the drum. Is there a filter or something similar where I can pull out as I believe the drain may be clogged after checking the hose and everything else. I just can't seem to find the filter anywhere. Any answers are welcome.
My answer so far as that I have had to manually remove the excess water in the drum. Although the washer will spin once the water is gone, so the spin cycle functions properly. Only problem is the drain issue. Thanks in advance
5 Suggested Answers
SOURCE: the spin cycle will not work. I think the drain is clogged and would like to figure out how to unclog the drain
If you unscrew the bottom front kick plate there is a black rubber piece to the right in front. In order to get to the filter make sure the washer has no water in it or it will spill all over the floor. The black rubber piece houses the filter. You need a phillips screwdriver to unscrew the clamp at the top of the black rubber piece. Once that is unscrewed you can pull it down and you'll see a white plastic filter inside. It is most likely clogged so it won't drain. When it is cleared it will work again. It is pretty easy but can be messy if there is water still in the drum. Just make sure that you put the rubber gasket back on with the clamp tightened.
Posted on May 09, 2009
  • 235 Answers
SOURCE: water pumping out at a trickle. stops in mid cycle
The timer seems to have gone out on you. Try to manually set it on spin and if that works then the timer is out.
Posted on Jun 30, 2009
woobie dog
  • 1273 Answers
SOURCE: WSSH300G0 won't spin - filter is clear
Check your lid switch, and the strike, which is the other half of the switch, and is attached to the lid (the switch is on the machine).
Regards!, --W/D--
Posted on Jul 20, 2009
SOURCE: My GE washer drains as it is filling but the spin
The standpipe that the drain hose drains into is too low. Make sure your drain hose is at least 36 " high.
Posted on Oct 10, 2010
The machine is not spin after wash, motor pump is work, and for wash is turn one shot left and one shot right and stop,...where is the problem???
Reasons Why Your Washing Machine Won't Spin
losangeleswasherdryerrepairservice.com > News
Apr 16, 2012 - When the washer enters the spin cycle but does not start to spin, you will need to see if there is ... West Los Angeles Washer and Dryer Repair Service ....After the water has drained, the spin cycle will start. .... Drive Motor, GE, Maytagwashing machine won't spin, spin bearing, washing machine clutch worn ...
Spin Cycle Not Working on Washer ' ThriftyFun
www.thriftyfun.com/Spin-Cycle-Not-Working-on-Washer-1.html
My washing machine will wash but the spin cycle will not spin or drain the tub what do I do to repair that? By Shelly H. ... Question: Washer Stops After It Fills for Rinse Cycle and Does Not Spin. By henryj ... Our GE washer will not spin when it has a load of clothes. It washes .... I have a Frigidaire stackable washer and dryer.
How to fix a washer that will NOT spin ONLY. THE EASY ...
? 3:56
https://www.youtube.com/watch?v=_8myOfPzGfM
Aug 4, 2012 - Uploaded by Brad Hyman
My washer did not spin but the belt drive worked to agitate the ...How to Fix a Washing Machine That Does Not Spin (Fast and Easy) - Duration: 8:45. ... Washer Top Load Not Spinning - Repair & Diagnostic- GE, General ...Missing: dryers
Feb 09, 2016 | GE Dryers
Why did my washer quit spinning out in spin cycle
Quite often the problem with spin cycles is that the cycle cannot start until a sufficient amount of wash/rinse water has drained. So what will often happen is that the washer drains, the cycle starts, a lot of water comes out of the clothes, it stops, waits for the water to drain, then restarts. If the drain pump or drain lines are restricted or blocked or the pump is faulty, the unit may never achieve spin cycle.
Sep 18, 2014 | Washing Machines
Water not draining from washer. cannot open door. isnt there just a spin cycle i could go to instead of the entire wash cycle? i have already put it through 2 more cycles hoping the spin would drain...
Hi lauraeuschwa,
I believe your drain pump filter is just clogged. The drain pump is trying to pump the water out before the Spin cycle, but can't. Usually this is caused by a foreign object that is obstructing the impeller. See my tip on how to access, drain & clean the Drain Pump Filter:
ACCESS, DRAIN & CLEAN THE DRAIN PUMP FILTER
After this, the Spin cycle will run, after the drainage procedure. If it does not, then you may need to replace the Drain Motor. Which is a easy task.
Kind Regards :-)
* If this solution helped you, please rate it
Jul 18, 2011 | Kenmore HE2 Plus Front Load Washer
My frigidaire front load washer will start a wash, complete the first cycle but then stop and flash all the lights and beep continously until I press "start" or "cancel". If I press "start" again it just...
Hello there:
If your cycle does not complete or The cycle doesn't advance
When the cycle should advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. than check the cold water supply line and the filter
Aug 15, 2010 | Frigidaire ATF6000ES Front Load Washer
Washer will not spin in wash cycle
I have a Kenmore washer that will not spin or drain.
May 31, 2010 | GE WBSR3140DW Top Load Washer
Washer won't drain.
My washer fills up with water and goes thru the wash cycle but when it's time to drain, it just sits there and clicks.
Oct 17, 2009 | Tecnik TKL9260 Front Load Washer
WATER WON'T DRAIN
Check the drain line , maybe plugged with a sock or drain line could be kinked
Jul 25, 2009 | General Electric WSSH300G Front Load...
Regards!, --W/D--
Jul 20, 2009 | General Electric WSSH300G Front Load...
General Electric WSSH300G Front Load Washer Logo
100 people viewed this question
Top General Electric Washing Machines Experts
Dan Webster
Dan Webster
Paul Bade
Are you a General Electric Washing Machine Expert? Answer questions, earn points and help others
