Question about NetGear - WG311 - 54Mbps 802.11g/b Wireless PCI Adapter (TGN1001486P)
Sir , my netgear WG311v3 pci adapter was working fine , last night i moved my cpu when it was on, since then it looses net connectivity and channel in its gui keeps changing and are not stable
  • 1,272 Answers
follow the steps below to configure settings on the computer with the adapter:
FOR XP :
1. Right click on My Computer icon and go to Manage.
2. Go to Services then go to Service and Applications.
3. Double click on Wireless Zero Configuration.
4. Change the Start Up Type to Automatic and click on Apply.
5. Click on Start and press OK to close the window.
6. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
7. Right-click on the wireless Network Connection icon and select 'Properties'.
8. Go to the 'Wireless Networks' tab.
9. Check the option 'Use Windows to Configure this Wireless Connection' and click 'OK'.
Now please perform the following instructions to connect to the wireless network:
1. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
2. Right-click on the wireless Network Connection icon and select 'Properties'.
3. Click on the 'wireless network' tab.
4. Under Preferred networks if you see any name in the list then highlight the name and click remove.Click OK.
5. Right-click on the wireless Network Connection icon and select 'View Available Networks'.
6. Look for the SSID (aka Network Name) of the Wireless router or access point.
4. Highlight the SSID from the list that you want to connect to.
5. Type the security Key here and click on the 'Connect' button.
6. You should have successfully established a wireless network connection.
For Vista:
1. Click START, Click Control Panel then click classic view in left hand side menu.
2. In the main screen, open up NETWORK AND SHARING CENTER.
3. In the left hand side menu open up MANAGE WIRELESS NETWORKS.
4. If you see any name in the list, please select the name and click remove.
5. Once the list is empty, click on ADD, select the first option, ADD A NETWORK THAT IS IN RANGE OF THE COMPUTER.
6. Click on your network name SSID and click on connect. If you have a Password setup on the router enter the security key.
7. This should setup the wireless network.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion with the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Posted on Jul 30, 2009
  • Anand Gupta
    Anand Gupta Jul 30, 2009
    FOR XP :
    For Vista:
    Regards
    Anand
There is no solution of this.this all are things useless.my money was wasted on this.so,i like advise you to dont connect a wireless adapter.
Posted on May 26, 2010
I need a driver for Netgear WG311v3 802.11g Wireless PCI Adapter for Windows 7 32bit
You can try downloading from this link:
http://netgear-wg311v3-802-11g-wireless-pci-adapter.soft32.com/
Nov 14, 2012 | NetGear WG311v3 802.11g Wireless PCI...
I need drivers for net gear wireless pci adopter wg311v3
click here to download the drivers....
good luck...
Please rate the solution, write a testimonial if you like the service....
May 23, 2011 | NetGear - WG311 - 54Mbps 802.11g/b...
54 mbps PCI Adapter Card limits my connection to 2 mbps
Wi if is the slowest form of connection and is shared with other devices. If you want good bandwidth you need to connect via ethernet cable directly to the router.
Examlpe... wi if 4 meg shared, Ethernet 100 meg..
good luck !
Mar 30, 2017 | NetGear WG311 (0060449028409) Wireless...
I'm unable to connect to the internet using my linksys wireless-g pci adapter to a Netgear router. It lists the router in the wireless network range, but cannot connect to it. Suggestions?
Go into the network settings through the browser. Go the where you change the "Channel" the router is transmitting with and change that to channel 6, instead of automatic. If you can access to router but not the internet, go to internet options through the browser and go to the connection tab and uncheck the box that deals with proxy server. That box should be unchecked and the box for automatically detect settings should be checked.
Oct 01, 2009 | Linksys : Wireless-G PCI Adapter with...
NETGEAR WG311v3 Wireless PCI adapter STUCK on scanning.
Hi
What you to do first verify that the device is installed properly for that ---
Go to Device manager-- click on Network adaptors -verify the your wireless adaptor is listed there without any yellow or red mark .If you see a yellow mark then you need to install and reinstall the adaptor
Second , You might see an icon for netgear adpaptor in right lower corner under taskbar and you need to Right Click on it , it will show you several options just look for use window to manage wifi or xp wifi client , like that .. sect that option ..
after that it will display a message wireless network detected , click on the messege , you will see your network . select and connect
Mar 29, 2009 | Computers & Internet
Unable to search internet
I've seen this trouble with G adapters connecting to Pre-N wireless routers....in the router...change your mode to G-only see if that works. Your adapter won't do N anyway so you're not missing out on anything. Good luck
Aug 27, 2007 | NetGear WG111T 802.11g/b (E82321) Wireless...
Netgear wireless adapter
When you say home bases, i assume you mean desktop pc's. If the channel you mention is the channel that the router works off eg channel 11 then all wireless adapters have to be set to channel 11, or the same channel as the router. The reason for one disconnecting from the internet will probably be the adapter losing the signal because of obstacles like walls and doors, as if the signal gets too low then the reciever cannot connect properly with the router, hence dropping the connection. Try the router in a different higher position or at a phone socket nearer the troubled pc. The connection accross the network should be atleast good and at 54 MBPS, anything less may not connect properly. The laptops will tend to have a stronger connection as most have a signal up booster built in the screen.
Apr 11, 2007 | NetGear WG111 802.11g/b Wireless Adapter
Computers & Internet Logo
410 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
