Question about Husqvarna Craftsman 36cc, 16 In. Gas Chain Saw
Craftman,36cc, 18" Gas Power Saw Blade
I need the pitch for a craftman, 36cc, 18" chain saw blade. I purchased this saw from a friend and need to sharpen the blade.
    Sergeant:
  • 384 Answers
Go to a home improvement store and buy a new chain, they are cheap!
Posted on Jul 29, 2009
HOW DO YOU REPLACE FUEL LINES ON A CRAFTMAN CHAINSAW MODEL 358355160
The lines are usually a tight fit in the fuel tank. This prevents leaks. They must be pulled out of the tank (one at a time) then cut the new lines end in a "v" pattern, this will allow you to push the new line through the tank. Long needle nose pliers are needed too.
May 09, 2014 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
How to remove a broken blade from a craftman recipricating saw shaft
Unplug the unit, us a stiff pliers ( a locking pliers if you have one) and yank! make sure any quick release mechanism is disengaged before you start.
Mar 03, 2011 | Craftsman 8.0 amp Reciprocating Saw
I have a Craftman scrooll saw, it came with pin end blade, but I want to use plain end blade and I don't know how, this machine only came with end pin blade.
Without model number of saw hard to tell. If yours in fact requires the pin, that's what you'll have to use. One usually buys the blades to fit the saw, not make the saw fit the blades.Your manual should tell you what kind of blades you can use in your saw. If you don't have that you can get one from www.searspartsdirect.com. Search for parts for your saw, then click over on the right side for manual. GOOD LUCK!
Jul 23, 2010 | Craftsman Saws
Cant get the cover back on chainsaw
The chain brake should have been released before removing the cover. You will have to release it with a large flat-blade screwdriver in the connector that runs the brake from the control handle. Hope this helps!
Jun 04, 2010 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
Why my chain saw always cuts at an angle
a lot of people have this problem with a chain saw and cant get a strate cut, most of the time its down to them trying to force the saw through the wood and in doing this the saw cuts around corners as there pull is not square to the cut,, let the saw do the work, not you, if your pulling on the saw to make it cut well then it has a very dull or blunt blade,,,is there any side to side "rock" on the chain in this new bar? how have you sharpend it? dose the chain have the same pitch on both side's? are all the teeth cutting at the same depth? if its cutting around corners it could still be the chain pitch worn out, if so the chain is past its best as well, but most of the time its all down to how hard and how squarely your pulling on the blade when cutting,,,the first thing in logging to lurn is to cut squarely no easy task that! just dont force the saw to cut!! it will cut just as fast or faster without forseing it,, if all this still dont get you cutting right change the chain for a new one,,,the only hard work with a chain saw is holding it up to the tree and humping it around not cutting with it, thats the blade's job to do so the faster you try to make it cut the more out of true the cut go's as all your doing is bending the bar out of alinement,,all in all, its two hands for the job and a very gentle pressure on the saw, start the cut with the blade spinning and dont stop the blade in the wood, cut right through
Mar 28, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Oil & Gasoline
Hi Thomas, you can find bar oil for the chain at just about any hardware store. Just tell them you need chainsaw bar oil. The oil that mixes with the gasoline is called 2- cycle mix. They will have that also. You can find the 2- cycle mix at a lot of gas stations too but a lot of guys caution not to use the 2 - cycle mix that is made for outboard motors. . Hope that answered your questions.
Jul 11, 2009 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
Husqvarna Craftsman 36cc, 16 In. Gas Chain Saw Logo
209 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
