Question about Ridgid Saws
Cant get the factory original blade off my miter saw...any ideas???
    Sergeant:
    Champion:
  • 246 Answers
Yes...Not sure about your brand of saw, but many come with a device to lock the spindle from turning, if you have one...refer to your owners manual. If your saw does not have this device, try this: with the saw unplugged, press the blade down firmly into a soft piece of pine wood while turning out bolt. Do same in reverse of course to install new blade.
Posted on Jul 29, 2009
Mastercraft miter saw parts
I have no idea but where did you originally buy the saw? Seller might be able to help you with that. What do you usually cut in your saw? I got circular blades from sawblade.com , check them out.
Jan 05, 2014 | Saws
Ryobi mitre saw jamming when cutting
There's a normal adjustment process of squaring the blade to the table, page 19 of your manual. If the blade is not square to the table then it will bind. Here's the link for the manual, see page 19.
http://manuals.ryobitools.com/system/files/400/original/TS1342_942_eng.pdf?2011
Dec 21, 2013 | Ryobi ZRTS1342L Factory-Reconditioned 14...
I have the blade bolt off of my ryobi miter saw but the blade wont come off of the spindle
tap the blade on the back side to loosen it off. The wood sap has probably dried out and is acting like a glue on the back flange washer.
Feb 13, 2013 | Ryobi ZRTS1342L Factory-Reconditioned 14...
Craftsman miter saw motor runs blade does not rotate.
YOU PROBLEPLY WORE OUT THE WORM GEAR.ALWAYS KEEP YOUR BLADES SHARP. I HAVE THE SAME SAW AND THE ONLY PROBLEM I HAD WAS I BROKE THE DUST BAG OFF, MY FAULT.
Jan 31, 2013 | Craftsman 12 In Miter Saw With Laser Trac...
I have a Craftsman 10" table saw model number: 137.248830. The saw doesn't make square cuts, it is more of a problem when using the miter. I have followed the alignment procedure so that the right...
I assume that your alignment procedure is about adjusting your miter gage. But you should first verify if the blade is parallel to the miter slot (the slot the miter gage slides in). This is adjustable underneath the saw, and sometimes comes crooked from the factory or comes loose later on. To check if the blade is parallel to the miter slot you can do this.....1. unplug the saw. 2. Raise the blade as far as it will go. 3. Clamp a piece of wood to your miter gage so that it just touches the blade as close to the front of the saw as possible. 4. Use a marker and mark that spot on the blade. 5. Now slide the miter toward the back of the saw, and rotate the blade by hand so that your piece of wood hits the same spot as where you checked in the front. You can see a large misalignment by eye. But you can get a little precise by using a piece of paper between the wood and the blade as a feeler gage. Or better yet, use a drop indicator instead of the piece of wood and you can measure the difference. If this isn't as close to parallel as you are able to measure it, you need to turn the saw over and find the bolts that attach the whole assembly under there to the table top. Once you have this in alignment, you should be able to set your miter to be square against any good square. If you don't have a high quality square, you can go to a tool store (Sears or whoever) with your miter gage in hand, and set it to be square against their most expensive square. If the square is square, and the blade is parallel to the slot and it still won't cut square you either have a bad blade or there is too much play in the saw's arbor. Try to wiggle the blade side-to-side - any wiggle at all is too much.
Jan 20, 2010 | Craftsman 10" Table Saw
Miter saw motor is running back wards
I'd say it was the new wiring that was reversed. Motors cant really start reversing themselves on their own and the only other way it would seem reversed is if the blade was put on backwards...
So yes I think you have the wires reversed when you re-wired the cord.
Please rate this solution on FixYa!
Jun 21, 2009 | Milwaukee Tool 10" Magnum Compound Miter...
How do I replace my mitre saw blade?
It should still easily fit a 5/8" blade. The arbor shape shouldnt have any effect on the type of arbor hole needed on the saw blade (only round arbor holes are made on saw blades. You will probably find the arbor securing nut has a shape that fits into the flat gaps between the saw blade and the arbor when fixed. So grab a 5/8" round arbor saw blade and give it a go. It should work fine.
It is the arbor nut that secures the blade onto the arbor via friction which holds it on.
May 29, 2009 | Ryobi ZRTS1342L Factory-Reconditioned 14...
Loose replacement blade
I completely removed the blade and put it back on, tightening the locknut, and now it works perfectly. The blade has not come loose and have used the machine for the last 3 months. The only thing I can think of is that somehow I didn't have the blade correctly installed in the first place, although it didn't wobble or anything.
Jan 25, 2009 | Ryobi ZRTS1342L Factory-Reconditioned 14...
How do I remove the guard?
Lift the guard up and you will see a nut holding the blade. You should not have to remove guard to change blade. Make sure unit is unplugged before working on it.
Dec 24, 2008 | Ryobi ZRTS1342L Factory-Reconditioned 14...
Saws Logo
115 people viewed this question
Top Ridgid Saws Experts
John Trevino
Jim Thurston
Are you a Ridgid Saw Expert? Answer questions, earn points and help others
