LG LHD45EL Dehumidifier Logo
Posted on Jul 29, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a LG LHD45EL and the compressor works, fins chill but fan won't turn at all. I took it apart and cleaned the armature of the fan, Used a non-contact device to ensure electric is present in the windings that make the fan armature spin. The fan motor still does not spin. Any help would be appreciated! The closest authorized center is 35 miles away. Thanks, Ty
  • tybled17 Jul 30, 2009
    I forgot to add that I tried this earlier, spun the blades but they did not keep spinning. Also, the fan blades are not bound in any way, they do freely spin.
    Thanks,
    Ty
t1m130
Level 2:
  • Expert 86 Answers
  • Posted on Jul 29, 2009
t1m130
Expert
Level 2:
Answers
86
Questions
0
Helped
36907
Points
178
Let the unit cool down
with power on try sticking something in there to spin the fan blade
if it spins and continues to work it is a bad capacitor (little shiny metal can sometimes oval or round)
if it doesnt spin i would have to guess the motor is bad
hope this helps
How do you check compressor on LG LHD45EL
If you just want to make sure the compressor is running, turn it to the lowest humidity extraction level setting, which is 35%. If the air intake filter is clean, and the water bucket is empty, the compressor should turn ON, in less than a minute.
Hope this helped you and thanks for choosing FixYa.
The compressor turns on, but the fan does not run. No water collects.
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
My LG LHD45EL all of a sudden
Short on refrigerant... or a failed compressor. are most likely or a system problem, causing it to trip off.
There may also be a failed electrical component, you need to check for voltage at the compressor.
cheers
7helpful
4answers
I've had the lg LHD45EL Dehumidifier for about 1.5 years now. I have used it every spring/summer. I turned it on this year and it runs but the water does not collect. Obviously something is wrong any idea...
I found the same thing. I've had my LHD45EL for 2 or 3 years. Worked great for my basement. This year I hear it run, but it doesn't collect water. I cleaned the filter and of course nothing. I took the back cover off, and tried running it. The condenser runs, but the copper tube leading up to the coil doesn't get cold. My guess is that the freon (or whatever refrigerant they are using) has leaked out. There doesn't appear to be any way to recharge it, the original tube has been crimped and soldered. Looks like junking it and buying a new one is the only option unless someone is good with a torch and solder. My question is whether to go LG or not.
1helpful
2answers
Fan will not come on.
The fan has to run if the compressor is running as the fan assists in removing the heat from the condenser coil. Can you spin the fan by hand? If there is full power(120 volts) to the fan and it isn't running then the fan motor is bad. Also, if the fan motor has a run capacitor this could keep the fan from running(if the capacitor is defective) so look for this first.
2answers
Kenmore dehumidifier 54501: Fan does not work. I
Call sears see if the compressor is under warranty
Runs but does not collect water.
compressor run but gas charge not enought
so it not very cool,and no water come out
2helpful
LG LHD65EL Dehumdifier Fan Noise
It sounds like the fan has etached from its hub. This usually is not repairable if that's the case. Replace the fan.
1helpful
No water is collecting on 2 year old lg humidifier
If when you turn your dehumidifier on the compressor runs then you should get moisture. Dehumidifiers work on the same principal as refrigeration. There is a bad control switch or the compressor start relay or capacitor is defective. If compressor runs and there is no effect then that is another problem. The filter should come out the front where the air goes in front and the filter should be washed by hand in warm degrease detergent water, dry and replace. If the disposable type filter I will help you contact LG.Thanks, Sea Breeze
Top LG Dehumidifiers Experts
ZJ Limited
ZJ Limited
Are you a LG Dehumidifier Expert? Answer questions, earn points and help others
