Magellan RoadMate? 1212 Car GPS Receiver
Problem for Magellan RoadMate? 1212 Car GPS Receiver
My magellan roadmate 1212 will not stay on unless plugged into
By edandem on Jul 29, 2009
my roadmate 1212 will not stay on unless plugged into the car, It works fine plugged in and says the battery is full, but will not turn on if it is not plugged in and will turm off if you unplug it? I have tried leaving it plugged in to charge and still does not work.
any ideas?
Best Solution
posted on Aug 14, 2009
Very Helpful)
palaboy
Rank: Wiz
Rating: 83%, 1228 votes
hi,
Please try to charge your unit using both the AC adapter and the Cigarette Lighter Adapter. If only one fails to work then that accessory needs to be replaced
If both fail to work, then the unit requires repairs, please click here , click on "Support/Repair Request", then login and complete the form for assistance.
hope this helps, thanks for using Fixya!
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Jul 30, 2009
Very Helpful)
imbmetz1
Rank: Guru  GPS  Expert
Rating: 90%, 364 votes
if its not charging the battery, the meter will say full even though the battery is dead..its a very common problem with alot of gps with the usb as a charging port. my solution is if this is still under warranty, i would send it back to magellan or where ever you bought it, because sooner or later the usb port is going to totally fail and wont even start up if plugged in and your going to be left with an expensive paper weight.
Was this helpful?
Yes
No
Popular Solutions for Magellan RoadMate? 1212 Car
Questions and Unsolved Problems for Magellan RoadMate? 1212 Car
Do you recommend Magellan RoadMate? 1212 Car GPS Receiver?
Answer
Answer
My Magellan Roadmate 1212 is always stuck on the last location that it is guided to. When I enter in... (More)
Answer
it wont turn on with the power outlet connected
Answer
I believe it has gone flat and now when I turn it on only the reset screen appears no other key is... (More)
Answer
Magellen 1212: when i enter a new destination, and after it routes it, it brings up a map of the... (More)
Answer
My Magellan Roadmate 1212 is always stuck on the last location that it guided me to. So the next... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top GPS Devices Experts
Top GPS Device Repairmen
in San Mateo, CA
(281) 371-2722
GeoQuip is a "One Stop Trimble Repair...
Gulf Coast GeoQuip
(408) 298-8188
Auto Nav 2000 Plus, Inc can repair most portable...
Auto Nav 2000 Plus  IS YOUR ONE Stop GPS Store
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
