Question about HP Photosmart 3210 Printer
Looking for the scanner assembly hinges - HP Photosmart 3210 Printer
    Scholar:
  • 97 Answers
About the only thing that I could suggest would be to try and find a defective one on ebay or some other such site and take the hinges out of those. Generally the manufacturer will not sell these small replacement parts to the general consume, however you may be able to find an electronics repair place that will order you these for a small fee.
Posted on Jul 29, 2009
Repace scanner CM4540
Remove the Control panel, scanner rear cover and adf. Open the scanner, lower the jam access cover and release the two scissor hinges. Disconnect two connectors and release safety cable (be careful at this point because scanner is no longer secured). Disconnect connector is rear and unhook from harness. From rear of device lift scanner assembly away from unit
Feb 27, 2014 | HEWLETT-PACKARD CM4540 AllInOne Laser...
Where to buy the Lexmark prestige pro top cover hinge of scanner
Lexmark doesn't sell or manufacture replacement hinges. If your printer is still under warranty, please contact our technical support team via phone so they can send you a replacement printer. If not, just remove the hinge and its assembly so you will be able to totally close the cover of the printer and be able to scan from the ADF.
Jan 23, 2013 | Lexmark 90T8005 Prestige Pro805 Wireless...
How to clean the underside of the scanner glass on an HP4400C flatbed scanner.
This is acutally easier than it looks. I just had the same problem with a cloudy film starting to form underneath the glass on my older HP 4400C scanner.
First completely remove the hinged top lid by lifting straight up on both long ends of the lid - notice the 2 hinges on the back end of the lid will come straight up and out of the body of the scanner, still attached to the lid.
Next look down inside the 2 hinge holes (on the main body of the scanner where the lid hinges just came out of) and you will see a screw in each hole. Remove both screws using a phillips screwdriver. This will allow the rear end of the scanner to come apart enough so you can now lift it up a few inches to separate it and get your hand inside there to clean the underside of the glass with a soft cloth - BUT JUST REMEMBER THE FRONT END OF THE SCANNER WILL STILL BE CONNECTED, so don't pull it too far apart because it could snap and break something that is still holding the front end together. (I could not figure out how to separate the front end piece, and then I realized I didn't have to).
So on the rear end of the scanner, now carefully pull the light upper colored plastic apart from the lower dark plastic just enough so you can get your hand inside the compartment and use a soft cloth to clean the underside of the glass. I just used a small piece of an old cotton t-shirt with a couple little dabs of water on it and then just kept rubbing the dirty areas on the underside of the glass over and over until all the dust film/streaks disappeared and the glass was once again clean and all clear.
Then gently lower the glass back down and line up the plastic pieces together on the rear end and put the 2 screws back in the hinge holes, and then reinsert the hinges in their slots and lower the lid back on top of the scanner glass and it is ready to go again !!
Hope this works for you like it did for me.
Nov 19, 2010 | HP Scanjet 4400c Flatbed Scanner
Expression 1680 Professional Flatbed Scanner: Transparency adaptor stuck in open position. The h...
Had the same problem. By lid I assume you mean transparency unit. To fix, it is necessary to remove the transparency unit from the scanner. Then IN A CLEAN AREA! with the glass side up unscrew the 6?screws that hold the top unit together. There will be a hinge assembly inside. You must remove it, clean it, and re grease it thoroughly. I used lithium grease from an aerosol can. Has not given me problem since. the whole process took about a half hour. just make sure you are gentle, and keep everything clean.
May 05, 2010 | Epson Expression 1680 Professional Flatbed...
My HP Photosmart 3210xi cartridge door is also locked in open
There's no sensor, it's just a spring and a plastic wedge thing.
Using a #10 torx driver, remove two screws holding the right-hand side panel from the printer. (one in the back, one on top underneath the ink access door.) Unsnap it and set it aside.
Disconnect 3 small ribbon cables and one 5-pin connector that lead from the printer to the access door/scanner.
Remove the lid from the flatbed, then remove the access door from it's hinges. Use the torx driver and unscrew the hinges from the main scanner body.
Lift the hinge assembly from the scanner and push the steel pin out, seperating the two parts of the hinge.
From there you should be able to loosen them up, remove the springs, lubricate them, or find whatever the problem is.
Reassemble and you're done.
Jul 16, 2009 | HP Photosmart 3210 Printer
8820DN hinge problem
To answer Meyerson's questions:
My symptoms did not include papers jamming in the ADF -- in fact, the ADF didn't work at all due to the broken left hinge.  :(  Also, I don't recall having any unusual problems with the ADF jamming frequently before the hinge broke to the point where the ADF didn't work at all.
I obtained the replacement ADF left hinge assembly by searching online for a parts dealer.  I believe I ended up ordering the part from Precision Roller.
I hope this helps,
-Barb
Apr 01, 2008 | Brother MFC 8820D All-In-One Laser Printer
Changing the CIS scanner
First remove the scanner control panel. pry the hinges out slightly and you can take off the control panel, then there are 4 or 5 screws and the top comes off. The 2 long rollers come out too. move the clip and slide them to the right. The scanner is the 3/4 inch wide 8 inch long scanner. ( the glass that reads your faxes to send ) It is coonected with a flat cable. It pops up when you push the clips holding it down. Lawrence
Mar 20, 2008 | Brother IntelliFAX 4100 Laser Fax
Locked Carraige
There are two locks on the scanner. One on the top right corner of the inner lid that locks the transparency assembly. The other for the bed is located on the side of the right hinge. Just turn them with a flathead screwdriver.
Nov 27, 2007 | CreoScitex EverSmart Jazz+ Flatbed Scanner
Brother MFC-8440 Doc. Cover Open Error Message
I had the same problem, found your site and all of your suggestions. I ordered the same left hinge assembly from Vance Baldwin Electronics
Part #LP2403001 for $11.03, shipping from FL to OK was $9.23 UPS, so less than $20 and my MFC-8440 is working again! I did have difficulty placing the screws without a second pair of hands so have someone help you hold the lid. Make sure you removed the set ***** from at least the back of the left hinge assembly so that you can remove the "case" that holds the springs and sticky white parts. (Yes, I am a girl) :-). My husband will be so suprised when he gets home and sees that it works now because it was on his honey do list this weekend. Also, make sure that you replace the set screws and clean the scanner appropriately before use. I really like this site, it saved me a lot of money this time. Take Care!
Aug 22, 2007 | Brother MFC-8440 All-In-One Laser Printer
HP Photosmart 3210 Printer Logo
149 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
