Question about Video Cameras
Grdv500 head cleaning and alignment
I have a grdv500 that will no longer play back. I would like to do a head cleaning and alignment
0 characters
1 Points
Camera will not play tapes
If you are getting a blue screen while trying to play back a tape that you know has a recording on it then its gonna be 1 of 2 things, No.1 your video heads have gotten dirty and you need to get a cleaning tape to run through the tape path to clean the unit, or No2 if your cleaning it doesnt help then you are going to need to have the video heads replaced. Usually once the heads are replaced they check the alignments for you as well and do a proper cleaning. I hope this helps
Sep 15, 2010 | Canon ZR-950 Mini DV Camcorder
I have a Samsung camcorder and when I play mini dv tape recordings from Canon camera I recorded on , the sound is distorted
If the tape plays correctly in the Canon camcorder, here are a couple of possible reasons for the issues you are having:
1. the Samsung camcorder has a cleaning issue - try running a dry head cleaning tape for about 5 to 10 seconds and see if that helps.
2. The alignment is off between the two different camcorders. Nothing you personally can do about that, but a repair center would be able to correctly align the tape path on both camcorders.
Do the tapes that you record on the Samsung have issues when you play them back on the Samsung? If so, you have a problem with that camcorder (may be cleaning, but could be a mechanism problem) Hope this has helped you.
Aug 30, 2010 | Samsung SC-D353 Mini DV Digital Camcorder
Tapes 4 years or older won't play - blue screen/no audio
Answer is No. 2. You probably had light clogged heads and by running couple of tapes, you have cleaned it somewhat. Now complete the cleaning using a new head cleaning tape. Run it for about 10 seconds but not more and you'll be ok. It is recomended to clean head by professional soon. Technician will be cleaning each head manually and you would be sleeping well for a lot longer. -James
Mar 29, 2009 | Sony Handycam DCR-TRV120BT Digital...
Old tapes won't play in different Handycam
Were your tapes recorded in extended play? Sometimes that will make it impossible for a different tape deck to play it back correctly. The tolerences on Hi-8 are very small so it is possible that a tiny alignment difference will make it impossible to play back a pre-recorded tape. Try fast forwording and rewinding the tape and try it again. Also try playing it from different parts of the tape. Go to the middle of the tape and try it there.
Jul 10, 2008 | Sony Handycam CCD-TRV608 Camcorder
Blue screen when I push PLAY, audio distorted.
The heads are clogged or the alignment is out. In either case, a professional cleaning and alignment should be done. This should not require any parts, just labor. Bring this to a shop as specialized equipment and tapes are required for proper alignment.
Jul 07, 2008 | Sony Handycam CCD-TRV87 Camcorder
Canon XL1s no longer records or plays back images
Hi Rick,
I think head is dirty.
Jan 21, 2008 | Canon XL1S Mini DV Digital Camcorder
Old Sony Handycam Video 8 CCD TR36
Head alignment (re-aligning the tracks) is not something we as owners can undertake - it has to be done professionally.
You can however quite safely clean the heads by using one of the dry cleaning tapes sold for the purpose. I have used an 8mm/Hi-8 cleaning tape made by TDK for a number of years with good results. Remember that if your heads are dirty both recording and playback will be affected and once you have cleaned the heads you need to test the camera by recording new footage and then playing it back to see if matters have improved. Good Luck.
Dec 27, 2007 | Sony Handycam DCR-TRV480 Digital Camcorder
5 Grey Horizontal Lines across the screen during play back and distorted sound.
Someone here recommended on another post to put the lense cap on & videotape the blackness in a quiet room for 5-10 mins. I tried this as a last resort & it worked. When I played back the tape, no more skipping or gray lines. I had 4-5 SOLID gray lines with skipping video & audio in between on every tape I put in. I think the person who helped me solve this said that it was a result of the tape alignment going off. My camera is a Canon zr80 digital camcorder. (Called Canon, they had me reset it & then recommended sending it in).
Jul 16, 2007 | Canon DV-MV830i Mini DV Digital Camcorder
Playback issues
try to forward a blank tape for cleaning until the head has being clean...repeat the procedure 5 times...if nothing happen may be the video head is weak already.....or need to align the camera
Jul 06, 2007 | Samsung SC-D353 Mini DV Digital Camcorder
No playback
your pal tapes played - in a separate pal player - shows whether your camera ' s tape guides are still in alignment ( your monitor must also be capable of playing pal ) ;
Apr 20, 2007 | E.Digital Sony DCR-TRV265E camcorder Pal
Video Cameras Logo
Top Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Video Camera Expert? Answer questions, earn points and help others
