Question about Brother MFC 210C All-In-One InkJet Printer
The printer says no cart. installed. Then I put all new ink cart in and it still says no cart for all 3 colors. Help
    President:
  • 2,306 Answers
Might need to remove all carts, power down and unplug for a few seconds, power up and install inks as they are asked for on the screen. Machine just gets confused...
Posted on Jul 29, 2009
My esp 3 kodak printer now has a printerhead problem after a year of use. When the printer does it's power up check I get a error with the ink cartridges indicator light lit up. When I remove the ink...
Your printer needs a service, in other words the waste ink sponges need to be cleaned and dried. They then need to be replaced and the printer reassembled. Then the Epson counter resetting software needs to be installed.
With this software the printer can be set to zero, it will work perfectly after this bit of attention.
It is a good printer, it's nothing that can't be repaired.
A computer technician will be more than happy to service your printer for you.
All the best!
damnor01
Feb 01, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
I have new photo (58) and color (57) carts and when I print wallet size (9 pics per 8.5x11 photo paper) the first 3 print true color and the last 6 are blue. I have cleaned the rollers and still do not...
hello, you are using the photo color ink cart, have you tried running a cleaning cycle or test print, the reason why i ask, is that maybe 1 of the colors is not printing, the test pages would prove what color is missing, if black not printing, it would print possible blue, or no black at all. i know you have put in new inks, but since the volume of ink in these cartridges run out according to usage, one color might run out before the others, and since black and yellow are the most used colors, without them your prints will show color faults.
Oct 07, 2010 | HP PSC 1350v All-In-One InkJet Printer
No color ink
To solve this issue what u can try is remove the ink cartridges from the printer. Unplugg and replugg the power cable. Clean the copper contacts of the carts using a dry paper towell. Snap the cart back to the printer and install the cart as the new cart. Print the alignment page. Also uninstall and reinstall the driver using the original CD, sometimes Windows can change to an "updated" driver with Windows update. It may have installed a B&W driver.
If all this fails it might be the issue with the encoder strip. Call Lex Tech Support and get help to fix the encoder strip.
Mar 02, 2010 | Lexmark X5470 All-In-One InkJet Printer
Error message reads: left cartridge incorrect.
hello there :
this error refers to the black ink cart not being detected .
possible the new cart has a some fault on it ., u can confirm it by checkin for any defetc , leak on the cart itself or test the printer with another black cart , (if u hav one ).
*if the old black cart is still detected by the printer though the ink is low ...then jus call dell tech support ., with the order # for ur purchase and the cart replaced .
each dell cart u buy has 2 yrs warranty on them .so use them
hav a gooday !
Jul 19, 2009 | Dell 924 All-in-One InkJet Printer
Problem with replacing color ink cart. #5
Is it the right Cartridge you are trying to install please check and then check if the sensors are working.
Mar 31, 2009 | Lexmark X2600 InkJet Printer
I have a Brother MFC 210C Multi-function printer, and I just replaced all the ink (black and 3 color cartridges) and my printer recognized the black ink, but still says my colors are all very low. How can...
I have a mfc 110c brother printer and I have changed the ink all the colors read full except the bk and I have put 2 new ink cart in it can I solve this problem?
Dec 29, 2008 | Brother MFC 210C All-In-One InkJet Printer
Color ink cartridge
hi, if your printer is telling you that you stillhave to replace the cart even if you have just replaced it with a new one, it might be that the one you are installing is defective. you can try installing a different cart. if this issues persist, then i suggest you contck kodak's tech support hotline 800.421.6699
Oct 23, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Printer cartridge missing
Make sure ur using the correct cartridge.....
for X2580 the cart number is 2 and 3
1.Cleaning the copper contacts on the carts as well as the copper contacts inside the cartridge carrier......
2. Remove the carts....and install the carts thru the solution center...(Start-programs-lexmark-solution center-maintenence -install carts
Clean the ink nozzel using a wet paper towel.....do not whip it ..just press and hold the nozzel....do this 3 or 4 times....
then
Install the carts...
open solution center.....click maintence tab...click on "clean to fix horizontal streaks"...
-----XXXX----
Apr 09, 2008 | Lexmark All-in-One Printer with PictBridge
Color prints too dark
1. Took out the color ink cart and clean the copper contacts of the ink cart with cotton swab, make sure that you do not touch the silver nozzle .
2. Try new ink color ink carts as someime this issue came up when the ink carts are about to finish up.
3. Replace the ink carts and do not us a refill ink.
Dec 26, 2007 | HP OfficeJet D135 All-In-One InkJet...
Lexmark X2500
2. Remove the carts....and install the carts thru the solution center...(Start-programs-lexmark-solution center-maintenence -install carts) while installing the carts choose the option "new carts"
Leme know if this has helped u
Dec 08, 2007 | Lexmark All-in-One Printer with PictBridge
Brother MFC 210C All-In-One InkJet Printer Logo
118 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
