Question about Frigidaire 20.3 Cu. Ft. Frost-Free Upright Freezer - White
In OF mode-wont come on - is new
Freezer is brand new when temp was changed, went into OF mode. we cant get it to come back on. have tried what book said-not working
I have a similar freezer under the Kenmore brand and experienced the same problem. Try raising the temp setting to +10 degrees. Unit should then start up again.
Posted on Aug 27, 2009
My defrost timer was replaced by a brand new one, two days ago -- the defrost light turns on for 1 minute, another few moments after, the green light turns back on again.. my temp wont go down and I am not...
sounds like a bad defrost terminator or timer wired wrong. won't make temp as the evap is not clear of ice/frost build up. check your wiring diagram for location and operation of terminator.
Nov 15, 2013 | Nor-Lake KLF7766C Commercial Freezer
We ve had the Bosch fridge-freezer (KGU3201GB/01) for about 10 years. Suddenly this morning the freezer started losing temperature, which rose to -13 degrees and the alarm went off. We put the...
Hi Robert, sounds like the unit is not defrosting.
Try this to indicate defost issues.
1. relocate food in the freezer, turn the unit off for 2 days and leave the door open, this will allow total defrost.
2. clean, then restart unit with door closed, after and every 2 hours check temp, I feel you may find it will get to its operating temp reasonably fast and should stay there.
If this is the case, I suspect the defrost heater element has failed and needs replacing, this is the most common cause of your type of issue.
Hope that helps and please dont forget to vote. Regards Russ
Mar 19, 2011 | Bosch 3.2 cu. ft. / 91 liter Upright...
Freezer defrost cycle
If the defrost timer sticks in the defrost mode,yes. Normal defrost time is 30 minutes or less depending upon which timer is installed.
If it happens again,locate the defrost timer and turn the dial manually to see if the compressor comes back on. If so,replace the timer.
It is probably on the rear near the compressor. Some are under the front behind the dust guard.
Feb 24, 2010 | Frigidaire 20 cu. ft. / 566 liter Upright...
Temp changes in freezer
If the temperature fluctuations occur (at least the ones to 20-30 degrees) at intervals of 6 hours or so then you are catching it in it's defrost mode which occurs on a timer. The timer shuts off everything except lights every 6 hours for an average of 20 minutes. This usually isn't enough to thaw things but I have seen it cause some crystale. Look closely at the back inside wall of the freezer for an accumulation of frost. If you see it there then you may have a defrost problem. Usually this is accompanied by steadily rising temperature in the freezer and fresh food secions both. The temps you listed (0to10) are fine. Good luck, AJ
May 22, 2009 | Freezers
Power went out, freezer will not turn back on
Hi Robert,
Happy to help.
You can go online to the manufacturers web site and download the manual!
I would advise you on this occasion to call service.
These guys are good!
A&E factory service does most brands warranty services.
They are open 7days/24hours nation wide.
call tonight! 1-800-905-9505
I am happy to assist you!
Neil
PS. Before you leave this site please leave a "Problem Solved" rating for me on fixya.com
Aug 15, 2008 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Brand new freezer
FIRST TURN THE TEMP CONTRAL ALL THE WAY OFF.LISTEN FOR A CLICK AND TURN TO HALF WAY SETTING IF IT CLICK IT'S ALLRIGHT, NEVER TO COLDEST,NEXT PLUG A RADIO IN THE PLUG TO MAKE SURE YOU HAVE POWER,DOES YOUR FREEZER HAVE A LIGHT ON FRONT TO TELL IF POWER IS ON?ALSO CHECK BREAKER BOX,THANKS-MIKE
May 19, 2008 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Brand New Freezer, won't cool
You did nothing wrong. I believe it was faulty at the time of purchase. Return for refund
Oct 21, 2007 | Frigidaire 5 cu. ft. / 142 liter Chest...
Frigidaire 20.3 Cu. Ft. Frost-Free Upright Freezer - White Logo
244 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Dan Webster
Dan Webster
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
