Make sure that your tv remote is working properly one try remove batteries from Ur remote and check one day again if its repeat then you replace the protects
its problem with the boad
I would start by removing the batteries from the remote to be sure that isn't turning it on, if that isn't the issue there may be an issue with the main board and it needs replacing.
SOURCE: TV switched itself off and will not come on.
try unpluging it and leaving it over night then try again and if not the tv might be stuffed
SOURCE: panasonic viera tv won't turn on. Power light
hello, you have a either your su, sd or sc boards fualty and it is a driver sos1 thats what the manual reads the best thing to do if your not electronically inclined or able to fix it is to get a service manual and make sure it is for your specific model and size you will find what the 7 blink codes mean, on my side i have a 42 in pana the service manual for this set and your is similar so since it is not the same model i cant tell you exactly what the truoble is but your best bet is to find a service manual find the 7 blink fualt then without getting ripped off you will know what the service man needs to do if you dont know or cant replace the parts yourself that is besides having to download firmware from your computer to a sd card and update your set but you need to solve the blinking code first it may solve the entire issue. the tv should come on when you resolve the blink codes or replace the fualty board or boards
SOURCE: Panasonic viera Plasma TV model TH-P42X10A The tv
The power supply board of the television is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
I hope this will help in solving the problem....
SOURCE: nececito el codigo para tv panasonic viera TC-L32X30A
Get in to this site "Electro-help". The site had all details you want. Serch for code by brand name. Four digit codes and synchronisation methods given in detail. Type in the site name, either to Google or Yahoo search box, and click search. The site is powered by Google.
Pull up older posts there.
Three digit codes for Panasonic are: 003/ 054/ 055/ 062/ 070/ 148/ 149/ 170/ 171
