Question about Dell Dimension 8300 PC Desktop
I press the power button on my dell 8300 Dimension and everything goes well until the CD goes to spin up at high RPM and then everything dies. Do you think it is the power supply?
    Master:
  • 404 Answers
No it is overheating, check your heatsink!
Posted on Jul 29, 2009
Al_096 can not start
remove all cables, wait until 30 sec and plug back in
Oct 23, 2011 | Dell Dimension 8300 PC Desktop
I am trying to re-install windows xp on a DELL dimension 8300 but it does'nt boot it can go to the BIOS and everything but it say Boot.mgr is missing
You should use the bootable Windows XP CD to start the installation.
To do that, you must first enter the BIOS in the Boot Options select the DVD drive as first (so that it will boot from CD/DVD first, instead of the hard disk). Save and Exit, insert the bootable Windows XP CD in the drive and when prompted to do so, "press any key to boot from CD-Rom".
Hope the above helps.
Mar 13, 2011 | Dell Dimension 8300 PC Desktop
UNPLUGED
Ribbons you should have 2 one for the cd rom drives and one for the harddrives, Look closley on the borad and it will say next to the connector which is which, the ata one will go to the harddrive and the ide one will go to the cd rom drive the end that only has one connector goes into the borad, the one with 2 connectors kinda close goes into the compoents, DO you have more than one hd if so you may need to find out which one is the master and which is the slave!
Nov 17, 2009 | Dell Dimension 8300 PC Desktop
I would like to reboot my dell dimension 8300
1.Press Start> ShutDown> Restart and OK. It will power down and restart (reboot).
If you cannot do that (for wathever reason), press the Power Down button for about 10 seconds. The computer will turn off. After that you will be able to turn it back on again.
Hope it helps
Aug 22, 2009 | Dell Dimension 8300 PC Desktop
How do I remove the power button on Dell Dimension 8300 desktop
open the side- and along the just inside the front exposed edge there are several tab that get push inward to release the front. They have a tendency to catch again when you go to the next one...you'll just have to play with it a bit. once that is open you'll see the other little plastic tab that holds the switch assembly . Don't forget to UNPLUG the power supply.
May 14, 2009 | Dell Dimension 8300 PC Desktop
Dell Dimension 8300 wouldn't start
Sounds like a power supply. You are getting the standby voltage and not the switched. plug all your wires in except the big 20 or 24 pin motherboard connector, take a small wire and short the green (PSU_ON) to black (ground) wires. This will simulate the computers "ON" signal. The fans should all spin up and your plugged in accessories should work, which means bad motherboard, if not bad power supply.
Mar 24, 2009 | Dell Dimension 8300 PC Desktop
Will not start
That's just about the opposite of what most systems would like. The colder they are, the better they run. There's a good chance your power supply is dying. Also, check and make sure the vents are not clogged with dust.
Dec 21, 2008 | Dell Dimension 8300 PC Desktop
Dell Dimension 4400 Won't Turn On
inside the pc there should be a green light. called flea light. if its not on.. then id say motherboard or power supply are bad.
take power cord off. and hold power button down for 10 ecs. then reconnect and retry. i think its abad psu.
Oct 09, 2008 | Dell Dimension 4400 Power Supply ** FREE...
Dell Dimension 8300 PC Desktop Logo
113 people viewed this question
Alun Cox
