Trying to Install Windows
Compaq Presario 1275 (AMD K6): Trying to reinstall windows for a friend. When setup cd boots, the computer hangs at the screen that says "Setup is starting Windows..." (BOTH 2000 and XP). Got Windows 98 installed tried upgrading to na avail. I'd really like to have at least Windows 2000 on this PC. Any thoughts why it hangs at that screen?
    President:
  • 1,383 Answers
Refix your RAM memory .
Aslo reconnect harddisk power cable and ide or sata cable.
I also face same problem in my pc i saort oout with Refix RAM memory.
Posted on Jul 29, 2009
When loading windows xp onto my compaq 1275 in freezes when i start to load windows pro
you meant Installing? every boot we load XP, well we dont you do.
as XP is a virus magnet and we stopped using it 3 long year ago.
nor is it fun to b Cyber-attacked forever, with XP, why use XP
sure it dont work its old, and fully infected,
seems like the HDD is bad to me.
let me guess, those Install disk are no HP real disks. are they.
upgrade the PC to SSD. ? if cash flush, wild abandon?
or is this post really "how to fix PC with no cash, QOD"?
it came with Windows 98 the old old pc.
hp does not support it now. its DEAD.
AMD K6-2 366 MHz
square screen 4;5
Like your friend id pitch it the trash, and go to goodwill
and find a w7 laptop for near NUTTN
really, life really does not incuded XP now, 2017. it does not.
or pure H3LL awaits you, IMO
carbon dated at 1999, its 18 years old.
and you want to fix this THING>?
why,
go to goodwill store
walk in and grab a $20 pc with a w7 COA sticker on the bottom
and run that. fix that, for the hope thing to happen.
http://pcdied.com/cheaper.html
Jun 30, 2017 | Compaq Presario 1275 Notebook
Trying to reinstall windows XP on Dell Dimension 8300....cant' start up using the CD drive...
Inpect the computers preexisting operating systems to ascertain compartibility to windows XP. Only XP computers would recognise XP operatign systems. Attemptign to install windows XP onto alternate system either windows 98, 2000, mellanuim or Vista XP or 7 is least achieveable unless the old system were erased or new empty storage disk drive were acquired and replaced.
Feb 03, 2011 | Compaq Presario 5000 PC Desktop
How to Install WinXp in Vista Platform
There is very simple procedure.
  • 1st restart your Laptop and enter in bios setup with the help of F2 key or F1 or Del key.
  • After entering in BIOS setup change the Boot order or Boot sequence.
  • Select the booting device 1st boot from CD Rom.
  • Save the setting.
  • Insert windows XP Cd in CD Rom.
  • Now Computer start from CD Rom.
  • You follow the instruction and install the windows.
  • Compaq Notebook Drivers
Mar 20, 2010 | Compaq Presario Notebook
How big of a processer can i put in it?
current specs:
366 MHz AMD-K6-2 processor with 3DNow! technology.
read this;
http://www.amd.com/us/press-releases/Pages/Press_Release_826.aspx
The K6-2 was an x86 microprocessor introduced by AMD on May 28, 1998, and available in speeds ranging from 266 to 550 MHz. An enhancement of the original K6, the K6-2 introduced AMD's 3D-Now! SIMD instruction set, featured a larger 64 KiB Level 1 cache (32 KiB instruction and 32 KiB data), and an upgraded system-bus interface called Super Socket 7, which was backward compatible with older Socket 7 motherboards. It was manufactured using a 0.25 micrometre process, ran at 2.2 volts, and had 9.3 million transistors.
Nov 26, 2009 | Compaq Presario 1275 Notebook
I wish to format my Compaq Presario v5000 and reinstall windows can you help
When you power up the computer press F1 or F2 or "del" key then you can enter in bios screen.
Make sure hardddisk is detected in bios.
Then check.
But still it not boot then you need recovery disk or windows disk toformatyour windows.
For that insert rcovery disk in cd/dvd rom .
then again follow above method for enter in bios.
Then go to boot option and set first boot device as your cd or dvd rom .
Then save and exit.
Then it boot with recovery disk.
Then follow the procedure on screen.
Then choose new installation of windows.
Then select 1 partiition to install windows then format with fat32 or ntfs.
Let me know if you need further assistance.
Thanks.
Nov 06, 2009 | HP Compaq Presario V5000 V5100 V5200 V5300...
How to install windows xp into compaq presario cq40
compaq cq40 is one particular model from compaq which is literally designed for vista and when you want to install win xp ;it doesn't work becoz the BIOS block it;the only way out is to downgrade the system BIOS which is a risky thing.check your bios model and version and google for a lower version and download it and flash the ealier BIOS.gooogle more on How to downgrade BIOS
Sep 21, 2009 | HP Compaq Presario CQ50Z-AMD Sempron(TM)...
System disc error Compaq Pesario 1275
This is either an issue with the CMOS batter which may need to be changed, I have seen this error on thinkpads and one way of resolving it is to install an older BIOS, you can download a BIOS from your machine and install it using there instructions
Hope this helps
Nov 24, 2008 | Compaq Presario 1275 Notebook
Reinstalling Windows
you must go to bios set up first and boot from cd.. then format and install
Oct 10, 2008 | Compaq Presario 2100 and 2500 ,NX 9000...
No operating system no os setup disk the bois is compaq verion686s4 relase date 25/07/2000 this computer is winwows 98 with a amd-k6-2 at 550MHz processor and a 15 gb hard drive [ i have a windows 98 40gb...
no sir,,u have reinstall the windows 98 in the swapped hard drive coz only when they gets installed registeries r set,,once u install the windows 98 continue installing the system driver n everyhting will be functioning fantastic
Jul 05, 2008 | Compaq Computers & Internet
Reinstalling Windows on Presario V2000
Well, you can install XP as long as you have a CD and your laptop has a COA with a key. Hit delete, F2 or F10 to start the system in setup, change the order of boot devices to make the CD your primary boot device. Restart, boot into the CD and follow the prompts. After you complete your installation you can go to www.hp.com SUPPORT and DOWNLOADS and find whatever drivers you are missing. Take your time and you'll do fine.
Sep 08, 2007 | HP Compaq Presario V2000 Notebook
Computers & Internet Logo
101 people viewed this question
David Payne
David Payne
