The Snow thrower you have uses a Tecumseh LH385SA engine. The ignition coil you're looking for is part number 35135A and a few places online have it available. Below is one online location.
Tecumseh LH358SA Snow Blower Engine Ignition Module Coil 35135A FREE...
SOURCE: can't get snow thrower to start
Does it have spark ??? I would check that first, and IF it does maybe add a tablespoon of gas down the sparkplug hole then try it..
SOURCE: snow thrower won't stay running
Replace the spark plug being sure to use the plug recommended in your owner manual, and the gap recommended. Then clean or replace the air filter. Finally use high test, new gasoline. Not gas that has been sitting around for months. good luck
SOURCE: ignition coil
Here you go. If the price seems high there are likely several more to be found on this page. Good luck with it.
http://cgi.ebay.com/36-136-137-41-141-142-HUSQVARNA-SAW-IGNITION-COIL_W0QQitemZ270389321883QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item3ef475a09b&_trksid=p3286.m20.l1116
SOURCE: I need to remove my number 6 ignition coil but
Hello. Here is the order of things for your truck. The engine firing order for either 4.6L or 5.4L V8 is 1-3-7-2-6-5-4-8. Cylinders are numbered, 1-2-3-4 on the passenger side bank of cylinders beginning at the front of the engine. Cylinders are numbered, 5-6-7-8 on the driver side bank again, beginning from the front of the engine to the back.
Soooooooo the number 6 is the second one from the front of the engine on the drivers side.
SOURCE: Simplicity Sno Away Snow Thrower Briggs 6hp engine No Spark
Check engine oil.
Remove wire from low oil sensor and the start.
Replace low oil sensor.
Hope this tip help solve your problem.
r/David
