Question about RCA D52W23 52" HDTV CRT TV
Convergence on my menu is no longer there
I was watching tv and my convergence went all out of place , i went to fix it from my remote and the convergence was not on my menu to fix , can you tell me what it could be or is it even worth fixing ; if so how do i go about fixing it myself
Thank you for your time and concern ,
Adrian
    Novelist:
  • 123 Answers
You need the service manual, I don`t know about these particular set, but on Toshiba`s, you had to press the menu button on the set and while holding that in, I think you pressed the red button on the remote. This got you into service mode. If the convergence went out while you were watching it, I don`t think adjustments will cure your fault, it sounds like the Driver chip may have failed which drives the convergence coils on the tube necks. Is it just one/two of the colours?? Is it out in the centre?? Is it out around the edges?? If you do intend adjust anything, make sure you write EVERY setting down first including EVERY mode, It is a VERY time consuming job and even then you`ll NEVER get it perfect. You have to repeat the whole setup in EVERY mode, eg: Widescreen, 4:3, Stretch, 16:9 etc. You`ll also need a signal generator to give you a steady picture while performing any adjustments and when you alter the brightness and contrast, this will affect the convergence also. DO NOT alter the binary settings of the set, these tell the micro what the set is fitted with, eg: Nicam, Freeview, NTSC, PAL etc, etc. If I remember correctly, there are about 300 settings which have to be performed in sequence and when you alter one setting in one mode, this can affect another setting in another mode. It`s a real nightmare, believe me. The only trouble is, if you do start to alter the settings and you find that there is a faulty component, You`ve got to try to get it back to the settings that they were before you started your tweeking. If you do alter the binary code settings of the set, then there`s a very good chance that the set won`t come back on. It took me three days to sort one set out once and even then the customer complained about the convergence. Ian
Posted on Jul 29, 2009
Picture looks dark
I have same model. First set went out of convergence, and I was able to adjust it. A few days later I had same problem and fixed it again. Then I was no longer able to adjust it. I watched TV the way it was. The picture got darker.Then I was watching TV, and there was a flash from the middle of the picture, and TV powered itself off. I unplugged TV and plugged it in 30 seconds later. I powered TV on, and red LED on front panel blinked a few times, and stopped. TV powered itself off.
From what I learned, the LAMP has to be replaced, and so do the convergence chips and convergence resistors. The TV shop charges around $300 and up just for the convergence chips. The TV is selling on craigs list for $150 to $200 in good working condition.
You have to decide if the repairs are worth your while. Probably not in mmost cases.
Sep 24, 2012 | Hitachi 50GX30B 50". Rear Projection...
My tv went multi colored take it as it looks like a 3d television
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 20, 2010 | RCA HD61W66 61" Projection HDTV
How to reset convergence? on mitsubishi ws 55511, has a shadow colored blue or yellow
There is an option in the user menu on the tv. Using either the remote or control panel on the front of the tv, press MENU then select SETUP. After you choose SETUP go to the 3rd column with the 3 icons. Here you can adjust the red or blue color or reset the convergence back to factory default.
After a few years the set will begin to show increasing problems with the convergence settings. When you can no longer adjust either red or blue horizontally or vertically an IC replacement will be needed. Your set uses (1) SANYO stk393-110 and you want to make sure it's SANYO and not a knock off brand as those usually fail prematurely.
Jan 23, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Hello
  • Screen looks 3D
Jan 03, 2010 | RCA R61WH76 61" HDTV
Blue convergence bows when watching tv, hdtv looks great
Below are two of the most common problems encountered with projection TV sets.
Problem #1 - CONVERGENCE PROBLEM
Projection TV2_bing.gif sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung2_bing.gif, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
  • Screen looks 3D
  • TV shuts off after powering on - TV may also make a chirping noise.
Note: If you TV has as flash2_bing.gif focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
Sep 14, 2009 | RCA HD52W58 52" TV
Concave tv screen colors distorted just had tv repaired one year ago for same problem
Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
  • Screen looks 3D
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
May 29, 2009 | Philips Magnavox 51MP392H Rear Projection...
I know that I need a convergence power supply board.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
  • Screen looks 3D
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Mar 27, 2009 | RCA R52WM24 52" HDTV Projection Television
Rca 52 inch convergence
You have a opened fuse FL231 next to flyback transfomer are 3 Fuses they look like small brown squares/ Fuse in the middle is bad when you do not have convergence listed in menu.You can pull the top off of these fuses .
Nov 06, 2008 | RCA P52960 52" Rear Projection Television
Samsung Tantus HCM 22 convergence problem
Check this website to buy the entire convergence amplifier board. Replacing the entire boars is a DIY since there isn't any soldering involve only open back cover of the TV and unplug a few wires to remove the old board and install the new one. Keep in mind that this board could be used or reburbished.
Samsung no longer has the assembly.
If you need more info let me know.
Aug 28, 2008 | Samsung HCM422W 42" Rear Projection...
Convergence adjustment @ 52MH84
press mute on the remote then while pressing mute press menu on the set.then you navigate with the instructions below.
3. KEY FUNCTION IN THE SERVICE MODE
The following key entry during display of adjustment menu provides special functions.
Screen adjustment mode ON/OFF: TV (ANT)/VIDEO button (on TV)
Selection of the adjustment items : Channel s/t (on TV or Remote)
Change of the data value : Volume s/t (on TV or Remote)
Adjustment menu mode ON/OFF : MENU button (on TV)
Initialization of the memory (QA02) : RECALL+Channel button on TV (s)
Initialization of the self diagnostic data: RECALL+Channel button on TV (t)
“RCUT” selection : 1 button
“GCUT” selection : 2 button
“BCUT” selection : 3 button
“SCNT” selection : 4 button
“SCOL” selection : 5 button
“TNTC” selection : 6 button
Convergence adj : 7 button
Self diagnostic display : 9 button
Jan 21, 2008 | Televison & Video
RCA D52W23 52" HDTV CRT TV Logo
243 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
