Question about HP DeskJet 5550 InkJet Printer
All 3 lights blink in sequence, then the light under the button marked "X" continues to blink. what does that indicate?
  • 724 Answers
Need to power down disconnect the Power then connect it and then power up what happens then since the light tell you that it has to be initiated and aligned
Posted on Jul 29, 2009
Standby button flashes tv not coming on trying to locate the reset button
The Standby/Power light of the TV blinks when there is any internal malfunction in the TV. The self-diagnostic function of the TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue.
Few examples are given below; some of the issues may be resolved without the need for service.
1 blink / 2 blinks / 5 blinks: - This indicates that there may be a power-related problem with your set.
3 blinks: - This indicates that there may be a power-related problem with your set. The set will need to be serviced to allow a technician to determine the specific issue that needs to be repaired. If the power light flashes three times in sequence in a Lamp TV, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
4 blinks: - This indicates that there may be a back light or lamp power problem.
6 blinks: - This indicates that there is some kind of audio problem with your set.
7 blinks: - This indicates that there is a temperature problem with your set. Please check to make sure that the air vents on the sides and back of the set are not blocked or clogged and there is adequate ventilation around the television. We recommend that you check and clean the vents periodically to make sure the set receives adequate air flow. If the problem continues, the set will need to be serviced.
8 blinks: - This indicates that there may be a video-related problem with your set. If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
Try the following steps to check if the issue can be resolved.
Turn off the television.
Unplug the television power cord from the electrical outlet.
Let the television remain without power for 60 seconds.
Plug the power cord back into the electrical outlet.
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
If the issue continues to occur, service may be required.
Thanks for using Fixya.
Aug 10, 2011 | Sony KP-41T65 41" Rear Projection...
What does the red blinking lights on the "standby"
Jul 18, 2011 | Sony BRAVIA KDL-V40XBR1 40 in. LCD HDTV
Red standby light is blinking 8 times on my sony bravia tv
I simply followed these steps with a surge protector
press the power button and hold up
Then hold up with the power button
then let go of up
and let go of power
worked with my kdl-55ex720
Jul 16, 2011 | Sony 55 KDL55EX720 3D LCD TV
We changed the toner cartridge and the toner light keeps blinking..
Press and release the Continue button (green button) to clear the light sequence and continue processing the print job. If the light is still blinking, the photoconductor is almost full and should be replaced
Jun 14, 2011 | Lexmark E260dn Laser Printer
Lexmark e260d printer 4th light orange is continuously flashing. New toner cartridge was installed. Not printing
If the blinking light is on Toner Low (4th light starting from left), press and release the Continue button (green button) to clear the light sequence and continue processing the print job. If the light is still blinking, the photoconductor is almost full and should be replaced.
For further assistance, please contact Lexmark Technical Support
May 13, 2011 | Lexmark E260D - QTY 4 - LMB OFFER Laser...
There is a blinking orange light on my printer but I replaced the toner not too long ago.
If the blinking light is on Toner Low, press and release the Continue button (green button) to clear the light sequence and continue processing the print job. If the light is still blinking, the photoconductor is almost full and should be replaced.
Apr 20, 2011 | Lexmark E260dn Laser Printer
Lexmark E260dn toner light is still on after changing the toner cartridge
Toner light is ON, I would assume that the light is solid and not blinking. You can press and release to clear the light sequence and continue processing the print job. With the printer turned off, remove the toner cartridge and shake it to extend its life. Check the replacement toner cartridge if it is the one suitable for your region.
For further assistance, please call Lexmark Technical Support.
Apr 12, 2011 | Lexmark E260dn Laser Printer
All of the lights are blinking in unisom and the printer ill not print
If all lights are flashing, it indicates an error on the printer. Please press the continue button to see the secondary error code. The secondary code will indicate the another light sequence indicating specific problem on the printer.
For further assistance, please contact Lexmark Technical Support.
Jan 12, 2011 | Lexmark E232 Laser Printer
Blinking lights and pwer down
Good Day;
Try this:
Symptom: All Front LED indicators are flashing in sequence: Power-->Temp-->Lamp-->Power......continuously
Cause: Replace Lamp . This symptom may happen all the time or it may be intermittent. It is normal if it occurrs from time to time, See OG under TV Front Indicators explanation notes.
Good Luck, big IRISH.
Jul 03, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Clean light is blinking
Watch the light closely. If it blinks 7 times then pauses, this indicates a heater or door latch issue.
Press the following buttons in sequence: Hi Temp Wash, Heated Dry, Hi Temp Wash, Heated Dry.
If this doesn't work, check the tech sheet. (should be stuck to inside of the bottom toe panel)
All lights should illuminate then a diagnostic sequence will start.
Listen carefully, as soon as you hear the water begin to fill, open the door and feel the heater. if cold, check the heater for continuity (should be around 10ohms)
Also, bend the door catch on the dishwasher tub downward, this will engage the door latch better. Don't bend too far as it will hit the door while closing.
Jun 15, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
HP DeskJet 5550 InkJet Printer Logo
192 people viewed this question
Seeker5211
Seeker5211
