Question about Gateway M-1628 Notebook
My gateway is offline. how do i get it online??
  • Albert Benjamin
    Albert Benjamin May 11, 2010
    what do you mean by "offline". Does power light come on ? or does it just not boot up to Windows ? 1)Does power light come on but screen stays black and you hear one or more beeps and you hard disk light stops flashing ? 2.) Does computer power come on and you see the "Gateway" screen, but Windows won't start ?
How does one start a payment gateway?
The global shift of business' focus to web markets has caused a consequential large-scale shift of payment modes. Today, it's possible to host a business in one corner of the globe and manage customers residing on the other side of the globe. However, every internet-based enterprise requires a reliable payment gateway to manage both online and offline payment processes including invoice generation, sending the invoice to customers and payment collection as well as payment reporting.
If you own an enterprise that intends to expand its market coverage to denser, far-flung locations or online markets, you will require a credible payment gateway to handle your payment collection process.
While the easiest and cheapest approach would be to seek the services of a white label payment gateway provider, this leaves you very limited room for customization as you are bound by their terms of service and features. The best approach is designing a personalized payment gateway.
May 12, 2017 | Computers & Internet
How to fix printer saying "offline" on some workstations, but it is really online?
You need to make an adjustment in the port settings on the problem computers. Take a look at my instructions here.
Sharp Printer Offline Solution
Sep 09, 2014 | Sharp MX-3501N All-In-One Printer
Why the offline message
Check the status of the printer at Control Panel. Set it to online if it's shown as offline. If this doesn't fix the problem, check whether installing the vista driver available at your printer manufacturer's website helps.
Step 1:
a. Click Start, go to Control Panel and select Hardware and Sound.
b. Click Printer.
c. If the Printer is offline, it shows "Offline" status. If the Printer is online it shows "Ready".
d. If the Printer is offline, set it to online.
e. Right-click on the printer and select "Use Printer Online".
f. The display should change to ready when the printer is set to online.
Read More....
How to Fix an Offline Printer eHow and HP Printer Support
Thanks,
Jul 16, 2014 | HP Officejet Pro L7780 Printer
Unknown pci adapter
Add in a standard PCI-interface network card (for which Windows has built-in support) and connect this card to your Internet connection. Then, run Windows Update, and it will search for a device-driver for the "missing" devices.
Mar 21, 2014 | Gateway E9422r E9522r Motherboard Amd...
Gateway computer serial # 0028346288 - Ports on front of computer do not work. Also, printer works but computer show, "printer offline". Any suggestions as to this problem?
You have not mentioned the Operating System on your PC and also the Printer which you are using.
First step is to Right click on the printer icon and click SET PRINTER ONLINE and Turn off the printer and turn on and try to print
If you are using Windows 7 Operating system,
Right click on the printer icon and Click on TROUBLESHOOT
Follow the instructions and this will resolve the issue.
Oct 12, 2010 | Gateway Computers & Internet
I have windowsvista and plugged my hp pcs1210 into my laptop with a usb and my printer box states my printer is offline
Reference: http://www.ehow.com/how_4796279_change-printer-offline-online.html
Go to Printer in the menu bar of the pop-up window and uncheck "Use Printer Offline." This action will change the printer from offline to online.
Open the Start menu and click on the "Printers and Faxes" icon. This will open a window with a list of the printers currently set up on your computer.
There's a small chance this might be your fix.
Hope this helps!
  • Step 2 Double-click on the icon of the printer you want to change to online. A pop-up window detailing all current print jobs will open.
  • Step 3 Go to Printer in the menu bar of the pop-up window and uncheck "Use Printer Offline." This action will change the printer from offline to online.
  • Read more: How to Change a Printer from Offline to Online | eHow.com http://www.ehow.com/how_4796279_change-printer-offline-online.html#ixzz0vK6bYiB5
    May 20, 2010 | HP PSC 1210 All-In-One InkJet Printer
    Gateway laptop (windows vista) internet won't work
    Within Internet Explorer, click FILE, and WORK ONLINE.
    Nov 14, 2009 | Gateway MX6920 Notebook
    How do you get an gateway that appers offline to apper online?x
    sounds like you are referring to the SSID broadcast. look for a setting in your router that mentions turning on or off the SSID broadcast. While off, that prevents your wireless network from appearing in the "wireless networks detected" window of users nearby.
    Aug 25, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
    Gateway appears to be offline
    It is best to use the reset button on the router to start over.
    if it then connects you will have to reset all the passwords and setting you had previously.
    Jan 26, 2008 | Gateway Belkin 54g Wireless DSL/Cable...
    Gateway M-1628 Notebook Logo
    199 people viewed this question
    Top Gateway Computers & Internet Experts
    Prashant M
    Prashant M
    Matthew Spark
    Matthew Spark
    Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
