Question about Goodman CKL24AR24 Air Conditioner
Changed the compacitor unit ran fine for half a day..then would not blow cold air..so i let it thaw overnight turned it back onit was fine..then after 5 hours..back to not blowing cold air..any suggestions?
  • 86 Answers
If you let it thaw it sounds like your coil froze up
a frozen coil is usually due to lack of air flow (a dirty air filter or bad blower motor) if both of these are ok then you probably are low on refrigerant
i would suggest finding someone who specializes in goodman or someone who is certified to handle refrigerant to check your refrigerant pressures
Posted on Jul 29, 2009
98 f150 4.6L Little heat and now overheats and blows resivour cap....Head gasket ?
you need to check the radiator,, there is a good chance that the lower half is pluged up
Mar 08, 2014 | Cars & Trucks
My york heat and air unit with emergency heat is blowing 30 amp fuses and sparking at the fuses and contactor when turn main breaker back on. I have replaced contactor, transformer and the compacitor on...
You either have something wired wrong or you have a direct short in the system. Are you starting the A/C or the furnace? If it's the A/C, it could be a shorted compressor, capacitor, fan motor or it's wired wrong.
Oct 30, 2013 | Heating & Cooling
I have a 2006 Gulfstream Cavalier 8'x 32' Fema Travel Trailer with a Dometic Duo Therm AC unit which I have recently replaced the fan motor on. Had the dealership bench test motor prior to lea
There is ice forming on the evaporator coils. This is either from a low freon charge or a leak in the seals or windows and doors. Could also be that the drains are not working and water is building up and freezing
Oct 10, 2012 | Dometic Heating & Cooling
Left door open, closed next day, but only blowing cool air now
You will need to turn the unit off and let it completely unthaw. There is frost that builds up in the ducts and behind the panels when the door is left open that will cause the unit to not cool or circulate where needed.
May 10, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
ONLY BLOWING SEMI COLD AIR> NOT REAL COLD LIKE IT SHOULD BE. cleaned front condencer still not ice cold. worked fine two days ago
return air ducts are iced up , unplug unit overnight or use a blow dryer in the freezer area. Ducts are behind rear panel left and right side
Nov 27, 2009 | Kenmore 53642 / 53644 Side by Side...
My side by side kenmore refrigerator, freezer isnt freezing
the fan in the freezer is not working to blow the cold air in the freezer you need a new fan you need a repair man it will cost you $300 good luck i have the same problem don't buy samsung they are useless that why home depot don't sale samsung
Nov 12, 2009 | Samsung RS265LABP Side by Side...
Our freezer is not making Ice and the refrigerator is not cold
have oiyu ried to thaw it out then plus it back in? also is there anything that could be blocking the air at all? The easiest way to thaw a freezer is to take a shop vac and turn the air around and blow it on the coils to thaw out the ice. go ahead and make sure t=hat its cpompletely thawed out them turn back on and check the air flow afrom the fan after its ran a little bit. Don't rae until your problem has been resolved then rate the best solutions please. Thanks for using FixYa.
Dec 31, 2008 | GE GDS18LBR Bottom Freezer Refrigerator
Freezer working fine, but no cold air to fridge
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer/control unit
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items. If it still has a problem then it might be the compressor and you should probably replace the machine.
Jun 29, 2008 | Whirlpool GB9SHKXL Bottom Freezer...
Goodman CKL24AR24 Air Conditioner Logo
119 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
