Question about Refrigerators
Not cooling, clicking sound from low
Lights on, fans running. Won't cool. Clicking sound coming from compressor compartment. Sounds like a relay failing to latch. Posts on /forum.doityourself.com suggest problem is compressor overload due to dirty coils and/or fan - very likely as this is the basement fridge. Should be cleaned soon or further damage can result. Alternatively, could be low on charge, which is R12. if so, then this fridge is scrap.
  • billslack Jul 30, 2009
    Follow-up: Unplugged unit and let relax for 3 hours. Compressor cooled to room temperature. Plugged in and clicking commenced within 15 seconds - compressor not yet hot. Unplugged. Removed plug-on relay and thermal overload disk from side of compressor. Dust balls on everything. Relay did not rattle. Fiddled with relay for few minutes then it started to rattle. Continuity checked OK. Consulted with local distributor of appliance repair parts. Relay obsolete and not available. Thermal overload disk scarce but available from other cities at ~$60 (exceeding value of fridge by ~900%.) Reinstalled everything. Fridge has worked fine for past 24 hours. Still, time to get new fridge.
  • 560 Answers
The cilcking sound is probably the klixon circuit breaker kicking out and resetting and kicking out again. If so, the unit is scrap as you have a compressor failure, electrical or mechanically related.
Posted on Jul 30, 2009
  • Cool Blue Services
    Cool Blue Services Jul 31, 2009
    Good job. The relay you got to rattle is a PSR..ie Potential Start Relay that is controled by the compressor winding current at startup. The LRC ie locked rotor current is high from a static start and the electromagnet in the PSR energizes a switch sending current to the start winding. Once the operating rpm is reached, the current lessens and gravity overcomes the magnetic fields ability to hold the solonoid core up. It drops and the switch opens, stopping current flow to the start winding. That is why it rattles when you shake it. If it was stuck, it was the cause of your issue.
My vinotemp vt60 starts cooling then stops
I sounds to me like the compressor is overheating. There is an overload on the compressor itself. Follow the wires where they go into the compressor. There will be a black wire going from the power cord to the overload. These can be purchased at appliance parts stores. Make sure there is no dirt build up on condenser coils or a kink in the tubing.
Jul 30, 2014 | VinoTemp (VT60GNV) Wine Cooler
Not freezing or cooling and compressor clicking on and off
From your description it sounds like the start components (start relay, overload and capacitor) are having problems. The clicking you hear is probably the overload kicking out to protect the compressor. It is quite possible that the compressor simply has gotten too hot and after sitting a while will restart when plugged back in. The start components are not generally considered 'user serviceable' parts. When the compressor has cooled to pretty much room temp, plug it in and be listening for those clicks. If you hear them, unplug it because it could eventually damage the compressor. Those components give the compressor an extra jolt to get the compressor running then they drop out of the circuit. If the compressor doesn't start, it creates heat until the overload drops out.
Mar 29, 2014 | Maytag MZD2766GES Side by Side...
Hi there, I have a Samsung RS21DCNS F/F. and have just moved house and connected it all back up. The LED display lights up, but the fridge and freezers won't cool and there's no motor or fan...
Was the fridge laying down? How long? Rule is if a fridge is laying down for an hour leave standing for a minium of an hour WITHOUT PLUGGED IN. ^hours laying equals 6 hrs standing. I tell everyone give it 24hrs of standing to eliminate problems. If you plugged it in without enough time for the oil in the compressor to return back to the compressor you may have fried your compressor. Now if you did leave it long enough and the oil in the compressor got back in compressor before plugging in. It could be in your defrost timer or your start relay. Does the fan in freezer come on? Push the switch to make the fridge think door is shut. If fan does not run it sounds like the defrost timer. If fan does run the check the start relay on compressor. Does the compressor turn on? Do you hear a clicking sound coming from copressor? If you hear a clicking noise than its your start relay trying to come on. Replace start relay and overload. The model number you gave me is not valid so get the full model number and check thru Searspartsdirect.com
If you need further assistance please feel free to contact.
Jul 24, 2011 | Samsung Refrigerators
My freezer is not working properly with clicking sound.
The clicking sound is probably the compressor relay trying to start the compressor. When the lights dim, the compressor is trying to start and hence, pulling power from the rest of the unit. If the compressor has a start capacitor, that could possibly be the problem. If not, the compressor itself should be replaced.
Mar 26, 2010 | Maytag MSD2454G Side by Side Refrigerator
Fridge question
Sounds like you mad have a bad relay or overload on the compressor. I would also check your condenser fan motor to make sure its running and blowing air on the compressor to cool it. If its not running the compressor may be overheating and shutting off on its overload. If the condenser fan motor is running I would assume that you would need a new relay and overload it will come in a kit. Usually it will make a clicking sound when the compressor is TRYING to start and then shuts off on its overload if the start components are bad.
Hope this helps _MJ_
Feb 07, 2010 | Kenmore 73952 / 73954 / 73959 Top Freezer...
Does not make cold, main compartment or freezer, replaced "relay/overload" capacitor (?) but still cycles/clicks off and on - lights on and motors run but no cold.
if clicking off and on I would say . the relay is working but the compressor is not starting . if comp will not start ( no cold ) the fan by the comp runs when the comp runs / but if comp does not start the fan does not know .. if comp runs the lines one is small and other is larger . the small one gets hot enough not to touch.it . not hot no cool . I think you have a compressor problem .. **** hope this helps . get back with me .. //mm
Jan 06, 2010 | Amana ABB1921DE Bottom Freezer...
2002 Dodge Ram 1500 A/C Blows Hot When Stopped and Clicking Sound
if the compressor is turning on and and off R1-34 level is low recharge system.
Aug 24, 2009 | 2001 Dodge Ram 1500 Truck 2WD
Freezer not working , clicking noise coming from fridge
Clicking was a relay. Replaced relatively inexpensive relay and now working fine.
Jan 17, 2009 | Jenn-Air JCD2389G Side by Side...
There should be a small relay switch near the compressor. Sometimes dust or (ugh) a bug may get in there and block the relay from starting the compressor.
Sep 28, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Relay clicking, not cooling either side
check you paperwork , and manual. sounds like a compressor issue, which "should" be covered by 5 year manufacture warr. reason i say "should" is hte warr's all changed jan1/06. only one year form there . but check your manual itll have the warr info in it
Mar 20, 2008 | Hotpoint HSM25GFRSA
Refrigerators Logo
186 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
