Question about Dell 2300MP Multimedia Projector
Dropped signal My Dell 2300 MP recognized a signal from my pc and then immediately drops teh signal.I ahve tried hooking it up to different pc's with teh same result.Does anyone know how to fix or where there is a reputable repair center in NYC area.
How do i do f my phone 2300 hve no signal?
Posted on Aug 17, 2008
What does it mean "tried changing the display to clone the image?" Probably its nice slange for profi, otherwise it has no sense for public.
Posted on Jan 14, 2008
  • 34 Answers
Have you tried changing the display to clone the image?
Posted on Dec 05, 2007
My used DEL 2300 MP doesn't seem to be compatible with my Compaq PResario CQ60. It keeps searching for a signal? Any suggestions?
Decrease the screen resolution of your computer to the minimum possible value and check.
Probably the projector does not support the resolution of the laptop. With a lower resolution it might work.
Oct 30, 2011 | Dell 2300MP Multimedia Projector
Dell 2300 MP turns on and the lamp turns on, but then the tempera
Ok you need to replace the thermo sensor on this now the thing is the replacment is not something "just anyone can do" Now what you can do is this you can take it into BEST BUY witch are EXPERTS to help you replace the sensor in this.
But for a end user to dig inside of this would not be wise. I would highly recommend a expert fix this due to the sensor. The sensor is on the ballast board.
I hope this FREE answer helps please do vote on it anyways and leave some feedback for us today!
Mar 05, 2010 | Dell 2300MP Multimedia Projector
Dell 2300 MP temp light flashes and projector turns off.
I am experiencing a similar problem with mine. It will cycle on and off without actually powering up fully and then after about the 4th or 5th time it will shut off completely and the lamp indicator light on top illuminates. i am reading in other blogs that this is a design flaw on this unit. let me know if you have found any fixes.
Jan 31, 2010 | Dell 2300MP Multimedia Projector
I recently moved and when i hooked all of it back
open it up check all the connections memory and add in cards for security.
connect it and try again. Sometimes the bios battery can cause wierd problems, they are usually a 2032 battery on the motherboard. replace it if it's suspect. I would then look at the power supply. Big heavy capitors don't like being dropped, (neither do hard drives for that matter).
Jan 10, 2010 | Dell Dimension 8200 PC Desktop
Dell m992 crt monitor
If it's getting no signal, make sure the monitor is set for the correct input. This would be either analog (if your cord has blue ends) or digital (if the connectors are white). Depending on wt yhat your monitor is, a button on the monitor will help you set that. If it's set for the correct input signal, then switch out a different cable to see if perchance you have a bad cable out of the box. If there is another PC or laptop setting around, plug your monitor into that to make sure it's good and maybe even plug THAT monitor into yours to make sure there is nothing wrong with your video card. Let me know what transpires. If this takes care of things, please help me out by rating it accordingly.
Jan 13, 2009 | Dell M992 19" CRT Monitor
Connection with the TV
It will work only if your TV has a Video OUT either in Composite RCA, S-video or in some other form although not all TV models have this feature.
Alternately, you can hook up your projector to an old VCR which definitely will have a Video OUT and use its built-in TV tuner. Of course you have likewise to connect a cable/aerial to the RF IN of the VCR.
Hope this be of some help/idea. Good luck and kind regards.
Dec 03, 2007 | Dell 2300MP Multimedia Projector
I need a cooling fan.
try to call dell spare parts. 800-3573355. there are no other suppliers for that. you can also get the manual from support.dell.com
hope this helps.
thanks.
Nov 18, 2007 | Dell 2300MP Multimedia Projector
Truemobile 2300 router
You may need to enable the wireless signal within the router settings, but you will have to connect to it via an RJ45 lan cable, as you would of when you first set it up. Type in the routers ip address in your internet browser and get into the routers settings that way.
Mar 24, 2007 | Dell TrueMobile 2300 Wireless Broadband...
Dell 2300MP Multimedia Projector Logo
155 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
