Question about KitchenAid 24 in. KUDI02IR Built-in Dishwasher
Dishwasher lights are all flashing
I have a kitchenaid dishwasher KUDC022RBL1 less than 2 years old. Will not work at all, lights either are all flashing or not flashing. Will not come on or even start to work. When hit cancel button it will try and drain even though there is no water. No idea what is wrong?
  • Anonymous Dec 15, 2007
    the dishwasher was working and then all the lights went out and it shut down.
    i check for power and i have power all the way up to the control panel.
    but it won't light up. thanks
If you do have the Touch Control Electronic Pad, then you do have a problem, moisture related. You need to open the panel, use a Hairdryer to dry the panel properly and replace. This sorts many of these Touch Control Electronic Pad.
Posted on Dec 05, 2007
The start light is flashing on my GE dishwasher?
What's the model number? How old is this dishwasher? The new GE dishwashers (less than 3 years old) have a weakness in the door switch/latch assembly, and that would cause the light to flash - it wants you to press Start and close the door, but it's not recognizing that the door is closed.
Feb 10, 2015 | GE Dishwashers
Dishwasher starts then pauses and drains.
Fixed! I had the issue where the cycle would start, the KUDS30IXBL8 would hum 4-5 times and then drain. Plastic folk pieces jammed in the disposer. These instructions took a few minutes (only 5 screws and a couple clips) to figure out how to take it apart, and it only took 60 seconds to put back together. How To Repair Dishwashers KitchenAid Repair Chopper Replacement
Apr 25, 2012 | KitchenAid Dishwashers
Cleaning Light flashes 7 times then repeats 7 flashes again. Cant find model #.... About 6 years old.. Thank you
342f192.jpg techbuster
  • Rank: Guru dishwashers_small.png
  • Rating: 92%, 2877 Votes
  1. Crack open door
  2. Within 3 seconds push Hi-Temp Scrub, Heat Dry, Hi-Temp Scrub, Heat Dry
  3. Close and latch door
  4. Press Cance
Try the above steps and also check the video in link given below to know detailed explantion on what the light means
Jan 19, 2011 | KitchenAid 24 in. KUDI01IL - Multiple...
First ensure that the arm is not getting stuck, and check that the orifices are free.
When the top arm is not spinning you may need to replace pump and motor assembly. First it is good looking for blockage in pump hose.
If the appliance is less than two year old, then it may be covered by limited warranty. Call Kitchenaid at the number listed in the owners manual to verify your warranty status.
Nov 20, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
Kitchenaid Dishwasher door wont latch
I have a brand new whisper quiet dishwasher model kudk02crbs4 I hook everthing up but the door does not lock what is worng I have no clue what wrong
Apr 14, 2009 | KitchenAid 24 in. KUDP02CR Built-in...
Streaks on stainless steel tub of both kitchen aid dishwashers
Hi, Emilychee1
Do you have city water or well water?
How old is you home and the plumbing?
How long do you have the stainless dishwasher and sink?
Ill wait for you reply!!
Sep 11, 2008 | KitchenAid 24 in. KUDI01FLSS Stainless...
Dishwasher not working - Cancel light flashing
If your dishwasher doesn't work at all, check these:
Power from the house
Door switch
Timer or selector switch
Power from the house Is there power getting to the dishwasher? This can be difficult to test, because dishwashers are usually wired directly to an electrical circuit, rather than plugged into the wall. But at least check for a blown fuse or a tripped circuit breaker.
Door switch The door switch is important because, if it's defective, the dishwasher won't work at all. To reach it, you need to remove the control panel cover, or sometimes the interior liner of the door. If it's defective, you need to completely replace it.
Wiring Often the main wiring connection from the house, at the dishwasher, burns and breaks the connection. If that's the problem, the wires must be repaired/replaced as necessary. If that's not the problem, check the wiring to the door switch, the wiring between the door and the lower part of the dishwasher, and the wiring to the timer. Repair any broken, burned, brittle, or defective wiring, using the proper appliance-grade wire and connectors.
Timer or selector switch Although it's uncommon, the timer or the selector switch may be defective. If so, you need to replace the defective part, because neither of these can be repaired.
Nov 27, 2007 | KitchenAid 24 in. KUDP01IL - Multiple...
Diswasher won't start
Try holding the reset button in for about ten seconds.
Nov 26, 2007 | KitchenAid 24 in. KUDP01IL - Multiple...
Dishwasher Kitchenaid KUDS25SHHBLO
It sounds like your touchpad is faulty. It can be removed by opening dishwasher door and removing 4 Torx screws along upper edge. Be sure power to unit is off before working on it.
Nov 09, 2007 | KitchenAid 24 in. KUDS25 Built-in...
KitchenAid 24 in. KUDI02IR Built-in Dishwasher Logo
525 people viewed this question
Top KitchenAid Dishwashers Experts
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
