Question about Royal VF880 Shredder
Royal 15mx paper does not feed. took apart and fond both gears to be turning, but cutter/roller not turning on (1) shaft. any solutions/parts sources/illustartions on how to fix
  • Alcus Nov 25, 2007
    Paper does not feed into shredder. Gears appear to be moving in reverse. Cleaned out all paper jams didn't fix the problem
You probably have the same problem we do.....the unit vibrated some of the mounting screws loose, causing the gears to disengage slightly and then strip one of them (plastic).....hence, no movement of the shredder, even though the motor is fine.  I myself am looking to Royal for a replacement gear.  I don't want to have to buy another one and it beats throwing the whole thing out....what a waste!  Maybe they should start using some glue on the mounting bolts!
Posted on Jan 28, 2008
How do I fix the rollers that won't turn when paper is inserted in shredder?
That shredder is as weak as they come - it is probably a broken plastic part inside the mechanism. Recommend you throw it away and get the Amazon Basics shredder, your experience will be much better. Sorry.
Jan 16, 2015 | Royal Office Equipment & Supplies
I have a Royal MC14MX paper shredder that has worked extremely well for almost 2 years. Until now. I normally leave it turned on 24/7, even when the office is closed. The other day I turned it off and
It maybe that the shredder cutters are jammed. Unplug from mains, and lift off top and
place upside down. Use a small screwdriver and poke at any compressed paper
wrapped around the blades - can take a while.
Give a quick spray to cutters with WD40 Replace - turn on - and run in reverse.
If all else fails, contact the maker
Feb 14, 2014 | Royal Office Equipment & Supplies
Cutter roller moves up & down with a 'popping' sound. It seems as if a shaft bearing has worn out
You will have to open it up to have a look inside...favorite is that teeth go out of the plastic drive gears or a gear cracks completely...once you can see problem contact Royal at 1-800-524-0799 for parts assistance.
Nov 05, 2010 | Royal VF1700MX Shredder
Our Royal 15 mx cross cut shredder will back out material, but there is no green light and no ability to feed in paper. Is this a gearbox problem? Is there anything we can do? Nothing appears to be stuck...
Does it sound like the motor is running forward or is it just "dead" when you try to shred paper..... if the motor is running.....then its a gear...but most likely you have lost the pcb in the machine...give Royal a call at 1-800-524-0799 for info on parts and prices.
Jul 22, 2010 | Royal 15MX Shredder
Gear needed
Call 1-800-524-0799 at Royal for parts assistance.
Jun 03, 2010 | Royal 15MX Shredder
Won't feed paper
empty out thr paper supply, check the paper feed area for debris, blow out area with compressed air (Computer Duster), fan paper carefully and re install.
retest machine
May 04, 2009 | HP PSC 1610 All-In-One InkJet Printer
Shredder rollers do not turn; motor works good; all gears go arou
Will it work in reverse? Can you see the gears are they all moving? Is there a set pin?
Apr 03, 2017 | Adler Royal HT500X Shredder
Replacement plastic gear for a Royal 150MX shredder
For parts call Royal at 1-800-524-0799; they should be able to help.
Don't forget to lubricate the cutting shafts on x-cut shredders.
Apr 02, 2009 | Royal 150MX Cross-Cut Shredder
Royal VF880 Shredder Logo
159 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Adorjani Laszlo
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
